praegune kellaaeg 24.10.2026 21:01:32
olavsu1
külaline
12.05.2016 14:13:43
MSI 970A-G46 genereerib veebi lehitsedes müra. |
Uus komlekteeritud masin teeb müra veebis kerimisel ja muid naljakaid hääli. Eriti lärmakas on firefox.
mobo: MSI 970A-G46
CPU: FX6300
GPU: 2X Asus 9800GTX SLI
PSU: Corsair CS750M
Firewire: Dawicontrol DC-FW800 PCIe
Heli: Maudio firewire 410
onboard heli: keelatud.
On see toite või mobo probleem?
SF-diagnostika: http://www.upload.ee/files/5800028/SF_12-05-2016.zip.html
HWMonitor raport:
CPUID HWMonitor Report
Binaries
HWMonitor version 1.2.8.0
Monitoring
Mainboard Model 970A-G46 (MS-7693) (0x000003D6 - 0x12737B20)
LPCIO
LPCIO Vendor Fintek
LPCIO Model F71889A
LPCIO Vendor ID 0x1934
LPCIO Chip ID 0x1005
Config Mode I/O address 0x4E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 04 FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 10 05 31 19 34 00 00 92 00 07 CE F0 10 0E 00 00
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 04 80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0480
Hardware Monitors
Hardware monitor Fintek F71889A
Voltage 0 3.23 Volts [0xCA] (+3.3V)
Voltage 1 0.87 Volts [0x6D] (CPU VCORE)
Voltage 2 2.18 Volts [0x88] (VIN2)
Voltage 3 1.28 Volts [0x6D] (VIN3)
Voltage 4 3.11 Volts [0x4A] (+5V)
Voltage 5 14.78 Volts [0xA8] (+12V)
Voltage 6 3.23 Volts [0xCA] (VIN6)
Voltage 7 3.31 Volts [0xCF] (VSB3V)
Voltage 8 3.20 Volts [0xC8] (VBAT)
Temperature 0 32°C (89°F) [0x20] (TMPIN0)
Temperature 1 30°C (86°F) [0x1E] (TMPIN1)
Temperature 2 39°C (102°F) [0x27] (TMPIN2)
Fan 0 3650 RPM [0x19B] (FANIN0)
Fan 2 1184 RPM [0x4F3] (FANIN2)
Fan PWM 0 100 pc [0xFF] (CPU)
Fan PWM 1 65 pc [0xA6] (System Fan 1)
Fan PWM 2 70 pc [0xB2] (System Fan 2)
00 FF A3 00 00 01 FF FF 00 00 00 01 00 55 4C 00 30
10 00 00 00 00 00 00 06 FF FF FF FF FF FF FF FF FF
20 CA 6D 88 6D 4A A8 CA CF C8 FF FF FF FF FF A6 B2
30 7A D7 FF FF FF FF C9 C8 75 85 FF FF FF FF FF 00
40 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF
60 00 00 00 00 FF FF 04 00 00 00 FF 0A 40 26 FF 00
70 FF FF 21 FF 1E FF 27 FF 00 00 00 00 00 23 00 00
80 FF FF 50 55 6D 55 55 46 FF FF FF FF FF FF A8 FF
90 00 02 02 00 14 FF 17 FF 44 02 00 15 55 05 99 1A
A0 01 9B 00 FF 01 AB 3C 32 28 1E FF FF AC AC AC 0D
B0 0F FF 00 A6 03 FF 41 41 41 32 FF FF FF FF A6 1D
C0 04 F1 00 B2 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 00 00 00 00 00 00 00 00 00 FF FF FF 00 00 01 00
F0 00 00 00 00 00 00 31 FF 02 8C FF 00 FF 00 FF FF
Hardware monitor NVIDIA NVAPI
Voltage 0 1.15 Volts [0x47E] (VIN0)
Temperature 0 52°C (125°F) [0x34] (TMPIN0)
Fan PWM 0 35 pc [0x23] (FANPWMIN0)
Clock Speed 0 740.00 MHz [0x2E4] (Graphics)
Clock Speed 1 1100.00 MHz [0x2E4] (Memory)
Clock Speed 2 1836.00 MHz [0x2E4] (Processor)
Temperature 0 53°C (127°F) [0x35] (TMPIN0)
Processors
Number of processors 1
Number of threads 6
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
-- Core 4
-- Thread 0 4
-- Core 5
-- Thread 0 5
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.418 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 6 (max 6)
Number of threads 6 (max 6)
Name AMD FX-6300
Codename Vishera
Specification AMD FX(tm)-6300 Six-Core Processor
Package Socket AM3+ (942)
CPUID F.2.0
Extended CPUID 15.2
Core Stepping OR-C0
Technology 32 nm
TDP Limit 95.0 Watts
Core Speed 1399.9 MHz
Multiplier x Bus Speed 7.0 x 200.0 MHz
Rated Bus speed 2399.9 MHz
Stock frequency 3500 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
L1 Data cache 6 x 16 KBytes, 4-way set associative, 64-byte line size
L1 Instruction cache 3 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 3 x 2048 KBytes, 16-way set associative, 64-byte line size
L3 cache 8 MBytes, 64-way set associative, 64-byte line size
FID/VID Control yes
Min FID 7.0x
# of P-States 7
P-State FID 0x19 - VID 0x0E - IDD 17 (20.50x - 1.375 V)
P-State FID 0x16 - VID 0x15 - IDD 17 (19.00x - 1.287 V)
P-State FID 0x13 - VID 0x1D - IDD 12 (17.50x - 1.188 V)
P-State FID 0xE - VID 0x23 - IDD 9 (15.00x - 1.112 V)
P-State FID 0x9 - VID 0x2A - IDD 7 (12.50x - 1.025 V)
P-State FID 0x4 - VID 0x31 - IDD 6 (10.00x - 0.937 V)
P-State FID 0x10C - VID 0x3A - IDD 4 (7.00x - 0.825 V)
PStateReg 0x800001A8-0x00001C19
PStateReg 0x800001A8-0x00002A16
PStateReg 0x80000174-0x00003A13
PStateReg 0x8000015E-0x0000460E
PStateReg 0x8000014A-0x00005409
PStateReg 0x80000138-0x00006204
PStateReg 0x80000125-0x0000744C
PStateReg 0x00000000-0x00000000
Package Type 0x1
Model 00
String 1 0x0
String 2 0x0
Page 0x0
Base TDP 13 Watts
Boosted P-States 2
Max non-turbo ratio 17.50x
Max turbo ratio 20.50x
TSC 3500.1 MHz
APERF 3799.5 MHz
Attached device PCI device at bus 0, device 24, function 0
100 00000000 00000000 00000000 00000000
110 00000000 00000000 00000000 00000000
120 00000000 00000000 00000000 00000000
130 000000C1 00000000 00000000 00000000
140 00000000 00000000 00000000 00000000
150 00073900 00000000 00000000 00000000
160 00000000 00000000 00000400 0066E066
170 00000109 00000000 00000000 00000000
180 00000000 00000000 00000000 00000000
190 00000000 00000000 00000000 00000000
1A0 80000003 00000000 00000000 00000000
1B0 00000000 00000000 00000000 00000000
1C0 00000000 00000000 00000000 00000000
1D0 00000000 00000000 00000000 0000003E
1E0 00000000 00000000 00000000 00000000
1F0 00000000 00000000 00000000 00000000
Attached device PCI device at bus 0, device 24, function 1
120 00000000 00000087 00000000 00000000
130 00000000 00000000 00000000 00000000
150 00000000 00000000 00000000 00000000
160 00000000 00000000 00000000 00000000
170 00000000 00000000 00000000 00000000
1A0 00000000 00000000 00000000 00000000
1D0 00000000 00000000 00000000 00000000
Attached device PCI device at bus 0, device 24, function 2
100 00000000 00003E51 00000000 00000000
110 000001C4 00000000 044CA424 0CE00F41
120 00FC0CBA 00000000 00000000 00000000
130 C418A80C C0902014 C9BC44B2 1124BCF0
140 00000000 00000000 00000001 00000109
160 00000000 01F83EE0 00000000 00000000
170 00000000 00000000 00020000 18640028
180 000000A0 00800004 33000000 00020000
190 0B010000 0F48088E 8D0F4007 00000000
1A0 031D0200 00000000 00000000 00000000
1B0 0FC39001 480F7D05 00000000 00000000
Attached device PCI device at bus 0, device 24, function 3
140 00A11755 00000055 0000C12A 00000000
160 C00A0FFF 00000000 C00A0FFF 00000000
170 C00A0FFF 00000000 00000000 00000009
180 017003E3 00000000 08000210 00000008
190 00000000 00000000 00780400 00000000
1A0 00034144 00000000 00000000 00000000
1B0 20018A03 00000000 00141000 00000000
1C0 00000000 0003CCCC 00000000 00000100
1D0 00000000 00000000 002B170F 00000000
1E0 00000000 80001387 00000000 00000000
1F0 00080000 00000000 00000000 004C074F
Attached device PCI device at bus 0, device 24, function 4
100 00000000 00000321 00000000 0085014C
110 000FE001 00000000 0107000B 00000000
120 00000000 00000000 00000500 00000000
140 1159C931 0000034D 23A2DC39 0000079D
150 00000B68 00B4B490 00000000 00000089
160 00600F20 00000003 00000000 00000277
180 E000530F 00001004 00000000 00000000
1A0 0000001F 00000000 00000000 00000000
1B0 00000000 00000000 00350182 00000000
1C0 000000E0 00000110 00000000 00000090
1D0 00080000 0000FFFF 00000000 00000000
1E0 0B501C19 0B502A16 0AE83A13 0ABC460E
1F0 0A945409 0A706204 0A4A744C 00000000
Attached device PCI device at bus 0, device 24, function 5
120 00001111 80000000 0000913A 00000000
160 0000800D 00000000 00000000 00000000
170 00000608 00020030 00000000 00000000
190 2233457A 0000000B 00202020 00000000
Temperature 1 8°C (45°F) [0x7] (Package)
Power 0 40.40 W (Package)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02040008h
Max CPUID level 0000000Dh
Max CPUID ext. level 8000001Eh
Cache descriptor Level 1, D, 16 KB, 1 thread(s)
Cache descriptor Level 1, I, 64 KB, 2 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 6 thread(s)
CPUID
0x00000000 0x0000000D 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00600F20 0x00060800 0x3E98320B 0x178BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000000
0x00000006 0x00000000 0x00000000 0x00000001 0x00000000
0x00000007 0x00000000 0x00000008 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x000003C0 0x40000000
0x80000000 0x8000001E 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00600F20 0x10000000 0x01EBBFFF 0x2FD3FBFF
0x80000002 0x20444D41 0x74285846 0x362D296D 0x20303033
0x80000003 0x2D786953 0x65726F43 0x6F725020 0x73736563
0x80000004 0x2020726F 0x20202020 0x20202020 0x00202020
0x80000005 0xFF40FF18 0xFF40FF30 0x10040140 0x40020140
0x80000006 0x64006400 0x64004200 0x08008140 0x0040C140
0x80000007 0x00000000 0x00000000 0x00000000 0x000007D9
0x80000008 0x00003030 0x00000000 0x00004005 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00010000 0x00000000 0x00001CFF
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0xF040F018 0x64006400 0x00000000 0x00000000
0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000
0x8000001B 0x000000FF 0x00000000 0x00000000 0x00000000
0x8000001C 0x00000000 0x80032013 0x00010200 0x8000000F
0x8000001D 0x00000121 0x00C0003F 0x0000003F 0x00000000
0x8000001D 0x00004122 0x0040003F 0x000001FF 0x00000000
0x8000001D 0x00004143 0x03C0003F 0x000007FF 0x00000001
0x8000001D 0x00014163 0x0FC0003F 0x000007FF 0x00000001
0x8000001E 0x00000010 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000008
MSR 0xC0010061 0x00000000 0x00000040
MSR 0xC0010062 0x00000000 0x00000000
MSR 0xC0010063 0x00000000 0x00000000
MSR 0xC0010064 0x800001A8 0x00001C19
MSR 0xC0010065 0x800001A8 0x00002A16
MSR 0xC0010066 0x80000174 0x00003A13
MSR 0xC0010067 0x8000015E 0x0000460E
MSR 0xC0010068 0x8000014A 0x00005409
MSR 0xC0010058 0x00000000 0xE0000021
MSR 0xC0010015 0x00000000 0x09000011
MSR 0xC001001F 0x00404000 0x00810008
MSR 0xC0010071 0x01000006 0x4006744C
MSR 0xC0010070 0x00000000 0x4006744C
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x01060800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000011 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00800
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x02060800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000012 0x00000101 0x00000000 0x00000000
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x03060800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000013 0x00000101 0x00000000 0x00000000
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 4, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x04060800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000014 0x00000102 0x00000000 0x00000000
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 5, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x05060800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000015 0x00000102 0x00000000 0x00000000
Storage
Drive 0
Device Path \\?\ide#disksamsung_ssd_840_pro_series______________dxm06b0q#5&5760a7f&0&2.0.0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name Samsung SSD 840 PRO Series
Capacity 238.5 GB
SMART Support Yes
Drive 1
Device Path \\?\ide#diskwdc_wd5000aakx-001ca0___________________15.01h15#5&2e5723e1&0&3.0.0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name WDC WD5000AAKX-001CA0
Capacity 465.8 GB
SMART Support Yes
Drive 2
Device Path \\?\usbstor#disk&ven_generic&prod_usb_cf_reader&rev_1.01#920321111113&1#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Removable
Name Generic USB CF Reader
SMART Support Yes
Drive 3
Device Path \\?\usbstor#disk&ven_generic&prod_usb_ms_reader&rev_1.03#920321111113&3#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Removable
Name Generic USB MS Reader
SMART Support Yes
Drive 4
Device Path \\?\usbstor#disk&ven_generic&prod_usb_sd_reader&rev_1.00#920321111113&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Removable
Name Generic USB SD Reader
SMART Support Yes
Drive 5
Device Path \\?\usbstor#disk&ven_generic&prod_usb_sm_reader&rev_1.02#920321111113&2#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Removable
Name Generic USB SM Reader
SMART Support Yes
USB Devices
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x049F, product=0x0051
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x046D, product=0xC05A
USB Device OMNIKEY 1021, class=0x00, subclass=0x00, vendor=0x076B, product=0x1021
USB Device USB Mass Storage Device, class=0x00, subclass=0x00, vendor=0x058F, product=0x6377
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce 9800 GTX/9800 GTX+
Board Manufacturer NVIDIA Corporation
Revision A2
Codename G92
Technology 65 nm
Memory size 512 MB
Memory type GDDR3
Memory bus width 256 bits
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x10DE)
Model ID 0x0612 (0x0592)
Performance Level 3D Applications
Core clock 740.0 MHz
Shader clock 1836.0 MHz
Memory clock 1100.0 MHz
Display adapter 1
Revision A2
Codename G92
Technology 65 nm
Memory size 512 MB
Memory type GDDR3
PCI device bus 2 (0x2), device 0 (0x0), function 0 (0x0)
Monitor 0
Model SyncMaster (Samsung)
ID SAM0528
Serial H9MS900489
Manufacturing Date Week 37, Year 2009
Size 19.9 inches
Max Resolution 1600 x 900 @ 60 Hz
Horizontal Freq. Range 30-81 kHz
Vertical Freq. Range 56-75 Hz
Max Pixel Clock 140 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
_GPE
_L1B
_L1D
_L03
_L04
_L13
_L0B
_L0F
_L10
_L11
_L12
_L18
_PR_
SSDT
DCOR
TBLD
NPSS
HNDL
APSS
P001
TYPE
_PDC
_PCT
_PSS
XPSS
_PSD
PPCV
_PPC
_CST
_CSD
P002
TYPE
_PDC
_PCT
_PSS
XPSS
_PSD
PPCV
_PPC
_CST
_CSD
P003
TYPE
_PDC
_PCT
_PSS
XPSS
_PSD
PPCV
_PPC
_CST
_CSD
P004
TYPE
_PDC
_PCT
_PSS
XPSS
_PSD
PPCV
_PPC
_CST
_CSD
P005
TYPE
_PDC
_PCT
_PSS
XPSS
_PSD
PPCV
_PPC
_CST
_CSD
P006
TYPE
_PDC
_PCT
_PSS
XPSS
_PSD
PPCV
_PPC
_CST
_CSD
P007
TYPE
_PDC
P008
TYPE
_PDC
_SB_
PR00
AR00
PR20
AR20
PR21
AR21
PR22
AR22
PR23
AR23
PR12
AR12
PR13
AR13
PR14
AR14
PR15
AR15
PR17
AR17
PR19
AR19
PR1A
AR1A
PR1B
AR1B
PR1C
AR1C
PR1D
AR1D
PR0C
AR0C
PRSA
PRSB
PRSC
PRSD
PRSE
PRSF
PRSG
PRSH
PCI0
_HID
_CID
_ADR
_BBN
_UID
_PRT
CPRB
LVGA
STAV
BRB_
BRL_
IOB_
IOL_
MBB_
MBL_
MABL
MABH
MALL
MALH
MAML
MAMH
CRS1
CRS2
_STA
_CRS
AMDN
_HID
_UID
_STA
NPTR
_CRS
NPTS
NWAK
SMBS
_ADR
SMBS
REV_
I1F_
I12F
MT3A
EIDX
EDAT
G39E
G41E
G39O
G41O
WIDE
DUM1
SOPT
GPIO
G06E
G06O
G06I
G07B
G0BB
G0EB
G14E
G14O
G14I
G15E
G15O
G15I
G1CI
G2DE
G2DO
G2DI
G35E
G35O
G37E
G37O
G37I
GE05
GE15
GE16
GE22
GAAE
GAAO
GAAI
GAFB
GB0B
GPMX
G06M
G07M
G0BM
G0EM
G14M
G15M
G1CM
G2DM
G37M
G70M
G76M
GAFM
GB0M
IDEC
_ADR
UDMT
PIOT
PITR
MDMT
MDTR
IDE_
PPIT
SPIT
PMDT
SMDT
PPIC
SPIC
PPIM
SPIM
PUDC
SUDC
PUDM
SUDM
GETT
GTM_
PPTM
STM_
GTF_
PRID
_ADR
_GTM
_STM
P_D0
_ADR
_GTF
P_D1
_ADR
_GTF
SECD
_ADR
_GTM
_STM
S_D0
_ADR
_GTF
S_D1
_ADR
_GTF
SBAZ
_ADR
PCI_
DNSP
DNSO
ENSR
_PRW
SBRG
_ADR
RMBS
LR2S
LR2E
SMIP
SMIC
GPIO
CLPS
SLPS
FSCR
FSSR
ALLS
SPTS
SWAK
IPTS
S800
_HID
_UID
_STA
CRS_
_CRS
SIO1
_HID
_UID
CRS_
_CRS
DCAT
MUT0
ENFG
EXFG
LPTM
UHID
IOID
INDX
DATA
LDN_
CR20
CR21
CR22
CR23
CR24
CR25
CR26
CR27
CR28
CR29
CR2A
CR2B
CR2C
CR2D
ACTR
IOAH
IOAL
IOH2
IOL2
INTR
INTT
DMCH
RGE0
RGE1
RGE2
RGE3
RGE4
RGE5
RGE6
RGE7
RGE8
RGE9
OPT0
OPT1
OPT2
OPT3
OPT4
OPT5
OPT6
OPT7
OPT8
OPT9
CGLD
DSTA
DCNT
CRS1
IRQM
DMAM
IO11
IO12
LEN1
CRS2
IRQE
DMAE
IO21
IO22
LEN2
IO31
IO32
LEN3
CRS3
IRQT
IRQS
DMAT
IO41
IO42
LEN4
DCRS
DCR2
DCR3
DSRS
DSR2
DSR3
PMFG
SIOS
SIOW
SIOH
PS2M
_HID
_CID
_STA
CRS1
CRS2
_CRS
_PRS
_PSW
_PRW
UAR1
_HID
_UID
_STA
_DIS
_CRS
_SRS
_PRS
PIC_
_HID
_CRS
DMAD
_HID
_CRS
TMR_
_HID
_CRS
RTC0
_HID
_CRS
SPKR
_HID
_CRS
RRIO
RDMA
RMSC
_HID
_UID
CRS1
CRS2
_CRS
COPR
_HID
_CRS
NBRM
_HID
_UID
CRS_
_CRS
PS2K
_HID
_CID
_STA
_CRS
_PRS
_PSW
_PRW
TPM_
_HID
_CID
_STR
_UID
_CRS
TMMB
ACCS
TSTA
TBCA
TVID
TDID
_STA
TSMI
INQ_
DAT_
_DSM
SLIC
WMI1
_HID
_UID
_WDG
WMMX
P0PC
_ADR
_PRW
_PRT
GEC_
_ADR
_PRW
UHC1
_ADR
_PRW
UHC2
_ADR
_PRW
USB3
_ADR
_PRW
UHC4
_ADR
_PRW
USB5
_ADR
_PRW
UHC6
_ADR
_PRW
UHC7
_ADR
_PRW
SATA
_ADR
_INI
SACS
STB5
SPTM
PRID
_ADR
_GTM
_STM
_STA
PRIS
_PS0
_PS3
_PSC
P_D0
_ADR
_STA
S12P
_PS0
_PS3
_PSC
P_D1
_ADR
_STA
S12P
_PS0
_PS3
_PSC
SECD
_ADR
_GTM
_STM
SECS
_STA
_PS0
_PS3
_PSC
S_D0
_ADR
_STA
S12P
_PS0
_PS3
_PSC
S_D1
_ADR
_STA
S12P
_PS0
_PS3
_PSC
PE20
_ADR
_PRW
_PRT
PE21
_ADR
_PRW
_PRT
PE22
_ADR
_PRW
_PRT
PE23
_ADR
_PRW
_PRT
IOMA
_ADR
NBF2
DID_
MBAS
UMEM
_HID
_UID
CRS_
_CRS
PC02
_ADR
_PRW
_PRT
PC03
_ADR
_PRW
_PRT
PC04
_ADR
_PRW
_PRT
PC05
_ADR
_PRW
_PRT
PC06
_ADR
_PRW
PC07
_ADR
_PRW
_PRT
PC09
_ADR
_PRW
_PRT
PC0A
_ADR
_PRW
_PRT
PC0B
_ADR
_PRW
_PRT
PC0C
_ADR
_PRW
_PRT
PC0D
_ADR
_PRW
_PRT
RD8A
_ADR
NB2_
MI__
MD__
HI__
HD__
API_
APD_
NMEM
_HID
_UID
CRS_
_CRS
_INI
ITPD
TPDI
TVID
VIDT
ITPM
_HID
_CID
_STR
_CRS
TSMI
INQ_
DAT_
TPMR
ACC0
_STA
_DSM
BN00
PWRB
_HID
_UID
_STA
_PRW
PIRQ
PIDX
PDAT
PIRA
PIRB
PIRC
PIRD
PIRE
PIRF
PIRG
PIRH
PIRS
HDAD
GEC_
USB1
USB2
USB3
USB4
USB5
USB6
USB7
IDE_
SATA
GPP0
GPP1
GPP2
GPP3
KBDD
PD64
IRQC
INTA
INTB
INTC
INTD
BUFA
IPRA
IPRB
IPRC
IPRD
LNKA
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKB
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKC
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKD
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKE
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKF
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKG
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKH
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
RMEM
_HID
_UID
WMIO
WMIX
_HID
_UID
BUF4
BF00
BF01
BF02
BF03
_WDG
CMOS
CMIN
CMDA
WDFH
WMMI
_SI_
_TZ_
_REV
_OS_
_OSI
_GL_
SP1O
IOCE
IOCL
IO1B
IO1L
IO2B
IO2L
SMBB
SMBL
SMB0
SMBM
PMBS
PMLN
SMIO
GPBS
GPLN
APCB
APCL
SPIB
SPIL
HPTB
HPTL
GIOB
IOMB
SMIB
ACPH
ASSB
AOTB
AAXB
HIDK
HIDM
CIDK
CIDM
PEHP
SHPC
PEPM
PEER
PECS
ITKE
MBEC
PEBS
PEBL
SRSI
CSMI
SMIT
OFST
TRST
TPMF
TCMF
TMF1
TMF2
TMF3
FESI
FDSI
FSSI
SMIP
CISI
PICM
_PIC
OSVR
OSFL
MCTH
PRWP
GPRW
WAKP
DEB0
DBG8
DEB1
DBG9
SS1_
SS2_
SS3_
SS4_
IOST
TOPM
ROMS
VGAF
OSTY
ACMS
ICMS
DCMS
P80_
BS_A
CFGS
PCIE
GGN2
GECE
IR_E
OSCF
PRS0
DET0
PRS1
DET1
PRS2
DET2
PRS3
DET3
ABPS
GPPS
CMPT
CMID
GPCT
GP0I
GP1I
GP2I
GP3I
GP4I
GP5I
GP6I
GP7I
PCFG
PMSA
PMSB
PMSC
STCL
SMIE
SMME
RVID
SMB1
G31O
ACIR
PCMD
PMS0
TLS0
PMS1
TLS1
PMS2
TLS2
PMS3
TLS3
PMIO
INPM
DAPM
MMSO
P1EB
ERMM
GP51
GP55
GP59
GP62
GP64
GE11
GE12
BATS
CLPS
G15A
SLPS
EPNM
DPPF
PWDE
ALLS
PHYD
US5R
GECD
ABIO
INAB
DAAB
RDAB
WTAB
RWAB
CABR
GENC
GHPS
GEN2
GEN1
P1E0
RTCS
PEWS
WSTA
PEWD
SPTS
SWAK
TRMD
CPMS
MSFG
KBFG
HPET
_HID
CRS_
_STA
_CRS
WOTB
WSSB
WAXB
_PTS
_WAK
OMSC
_HID
_UID
_S0_
_S3_
_S4_
_S5_
PTS_
WAK_
siven
12.05.2016 14:16:55
oleneb mis hääled on nagu pinin või miski?
toide võib teha häält ja võib ka video kui vaatad mingit flashi või midagi ja fps on suur seal tekib video coil whine.
endal olnud toitega ,et nagu vilistab loadi all.
149 |
olavsu1
külaline
12.05.2016 21:14:31
podiseb rütmiliselt nagu tühikäigul harrikas, kerimisel uriseb.
tegin salvestuse: http://www.upload.ee/files/5800298/noise.flac.html
pistsin kõlarile mikri ninaalla. firefoxis oli lahti HV leht ja kerides teeb sellist urinat.
vist miski lahendus leitud. helikaardile eraldi toide järgi ja müra kadunud. enne (ja vanema moboga ka) tuli toide üle firewire kaabli.
Braien
12.05.2016 21:15:45
hmm... Proovi AMD cool'n'quiet maha võtta vms.
Lugesin kuskilt, et osade toidetega võib niimoodi teha.
90 |
725 |
pealuu
13.05.2016 10:38:57
Re: MSI 970A-G46 genereerib veebi lehitsedes müra. |
| olavsu1 kirjutas: |
see tundub tal juba nagu piisavalt väline olevat
| Kommentaarid: 213 loe/lisa |
172 |
725 |
olavsu1
külaline
14.05.2016 20:31:22
Case closed.
mobo on nüüd garantiis, kuna lõpetas töötamise bios'i uuenduse järel.
siven
14.05.2016 20:36:41
| olavsu1 kirjutas: |
Case closed.
mobo on nüüd garantiis, kuna lõpetas töötamise bios'i uuenduse järel. |
selline asi läheb garantii alla? kas pole mitte nii ,et biosi update omal vastutusel ja kui bricked siis on oma süü?
149 |
olavsu1
külaline
14.05.2016 22:06:58
No näed, läheb garantii alla, MSI tahtis pärast äpardust seda mobo endale ja teatas, et kui neil ei õnnestu bios'i taastada siis saadavad uue mobo.
muidu neil oli taoliste äparduste tarvis selline juhend, et pane BIOS'i fail mälupulga juurikale ja boodi masin nii, et muid kettaseadmeid küljes ei ole.
siven
14.05.2016 22:33:22
| olavsu1 kirjutas: |
muidu neil oli taoliste äparduste tarvis selline juhend, et pane BIOS'i fail mälupulga juurikale ja boodi masin nii, et muid kettaseadmeid küljes ei ole. |
tore teada ise kasutan ka enamus asju MSI toodangut ... nii ,et võib julgelt katsetada rohkem asju nüüd
149 |
725 |
Mihkel.
15.05.2016 11:48:14
| Kuskil on lihtsalt halb maandus ma eeldan. Salvestust kuulata ei saanud kuna tööarvutisse ei viitsi tirida flaci suutlikku asja. Järelikult eelmisel emaplaadil oli selle konkreetse ühendusviisi maandus paremini lahendatud. Kui helikaardi väline toide probleemi lahendab, siis soovitangi seda kasutada. Tõenäoliselt teeb ka uus emaplaat sama asja.
| Kommentaarid: 92 loe/lisa |
Mnator
15.05.2016 14:03:54
| olavsu1 kirjutas: |
see juhend sobib kõigi tootjate emaplaatidele katsetamiseks kui muud lahendused ei tööta
15.05.2016 21:23:22
Jah, vanasti oli flopi selle jaoks. BIOS fail flopi juurikasse ja "pime boot".
Nüüd on flopi surnud ja USB mälupulk seda asendamas. Loomulikult peab mingi pimebootimise võimalus olema.
olavsu1
külaline
31.05.2016 20:42:27
| uus mobo saabuski ja hoopis teine. MSI 970 Gaming.
725 |
olavsu1
külaline
31.05.2016 22:45:12
laurx, põrin kadund ei ole kuid on vaiksem ja mure lahendab lõplikult helikaardi välise toite kasutamine.
nüüd on küll case closed
