matu111
09.10.2015 12:55:46
Intel hd 4000 vga out max reso ? |
Tere,
võhikule näkku ei lööda küsimuse eest
kas inteli hd4000 kannab full hd pilti 1920 x 1080 läbi VGA->VGA eraldiseisvasse monitori ?
| Kommentaarid: 11 loe/lisa |
NAIRI2
09.10.2015 13:09:26
https://communities.intel.com/message/246677
17. Re: Intel HD 4000 HDMI 2560x1440 resolution???
Robert_U Devotee
Robert_U Aug 11, 2014 9:17 AM (in response to crapme)
All, I have confirmed the supported resolutions and refresh rates for HD 4000. This issue is a hardware limitation of the HD4000 chipset. It does not support a pixel clock greater than 225MHz on HDMI. The following are the supported rates.
DVI :
Intel HD4000 Max Pixel Clock supported on Single Channel DVI is 165Mhz. So max supported is 1920 x 1080 (60p Hz) On DVI
HDMI :
Intel HD4000 Max Pixel Clock supported on HDMI is 225Mhz. So max supported is 1920 x 1080 (60p, 85p) On HDMI
Note : 2560 x1440_ (60 Hz) is not supported on HDMI as it Exceeds the max Pixel Clock supported by our Intel 4000 Hardware ( 225Mhz)
Driver will enable and support 225Mhz based on HDMI Panel’s (HDMI Registration ID supplied by panel )
DispalyPort :
Intel HD4000 Max Pixel Clock supported on DisplayPort is 348 Mhz
So, 2560 x1440_ 60 and 2560 x1600_ 60 is supported on DisplayPort Interface only. |
_________________ Tehnikadoktor. |
| Kommentaarid: 37 loe/lisa |
Rauno266
12.10.2015 10:17:53
| Mul on hetkel Lenovo X230 (HD4000) läpakas, mille taga on 1920*1080 monitor läbi VGA. Kõik töötab kenasti ja probleeme pole.
| Kommentaarid: 46 loe/lisa |
42 |
Riivo
12.10.2015 15:25:05
| Isegi HD 3000 kannatab VGA FullHD + DVI FullHD välja anda. Kolmandat ekraani 3000 seeria siiski enam ei suuda. Järgmine põlvkond manab ilusti pildi kaks FullHD + läpaka enda ekraan.
221 |
KrikU
12.10.2015 16:47:19
Kui siin teemaks läks, siis endale ja teisteke hea infoks teada edaspidiseks.
Kas FullHD ongi nende max või tuleb sealt ka 16:10 suhe ehk 1920x1200 läbi DVI-ga?
119 |
Riivo
13.10.2015 09:03:12
| Jah, 1920x1200 tuleb ilusti läbi nii DVI kui ka VGA isegi HD3000 puhul juba. Isegi korraga.
221 |
