praegune kellaaeg 14.09.2026 01:28:27
sama123
| Kommentaarid: 23 loe/lisa |
22 |
labidas
31.03.2015 00:22:05
kella üle
| Kommentaarid: 34 loe/lisa |
34 |
sama123
31.03.2015 22:27:14
| labidas kirjutas: |
| kella üle |
Seda saab siis teha kui sagedustele lisaks annab pinget tõsta......peenike värk. Minu juhul annab ainult sagedust tõsta ja seda saab teha minimaalselt olemasoleva pinge korral. Muidu jookseb kokku
FX 3700M -75W
FX 3800M -100W
22 |
labidas
31.03.2015 22:52:25
google:
A. If you have a card made for the later "...10" vbios, your card can be flashed to a GTX 280m and will work 100% at 1.05v!
B. If you do NOT have a card made for this vbios (they usually have a sticker below the core) then you cant flash it to a gtx 280m (until we further modify it) BUT you CAN flash it to the newer ".10" vbios which will overclock in a remarkably more stable fashion!
34 |
sama123
22 |
