uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  Kui arvasite, et coil whine on 900 seeria puhul halb siis... märgi kõik teemad loetuks
MelGibson
sõnum 02.12.2014 22:46:51 Kui arvasite, et coil whine on 900 seeria puhul halb siis... vasta tsitaadiga
Case #1 https://forums.geforce.com/default/topic/792706/geforce-900-series/nvidia-is-there-a-fix-coming-or-not-very-disappointed-new-customer-970-low-usage-/
Case #2 https://forums.geforce.com/default/topic/793336/geforce-900-series/possible-gpu-utilization-fix/
Case #3 https://forums.geforce.com/default/topic/781982/gtx-970-possible-gpu-load-and-low-fps-issues-with-344-16-driver/
Case #4 http://www.reddit.com/r/nvidia/comments/2nuuqr/gtx_980_problems/
see ka midagi huvitavat : https://forums.geforce.com/default/topic/793160/geforce-900-series/gtx-970-gaming-performance-degrading-after-a-certain-period-of-time/
Mõnel mehel ei tööta Anti-Aliasing https://forums.geforce.com/default/topic/793179/geforce-900-series/no-anti-aliasing-in-any-games-gtx970-/
Esimene batch gtx 970neid on läbisegi suure praagiseeriaga?
ja nii edasi.. terve nvidia forum täis kisa selle kohta et gpu töötab mingi 50-60% koormuse pool ja kaart ei tööta täis potentsiaalis.
https://www.youtube.com/watch?v=zaC9F02iRDA
viimati muutis MelGibson 02.12.2014 22:52:02, muudetud 1 kord
ThedEviL
ThedEviL
sõnum 02.12.2014 22:49:50 vasta tsitaadiga
Lõhnab AMD meeste reklaami moodi.
Palju sulle selle eest makstakse?
MelGibson
sõnum 02.12.2014 22:55:10 vasta tsitaadiga
ThedEviL kirjutas:
Tundub lihtsalt asi mida peaks teadma tiba enne kui pea 400 eurise investeering teed kuhugi.
Quote fudzilla: "Some of the cards suffer from Coil Whine but at the same time, it is hard to hear this unpleasant noise in a closed case. It turns out that some components probably R22 inductors are to blame and not all the cards are affected. A lot of people wanted to RMA their cards as they didn’t like the noise.
The Geforce GTX 980 cards are not affected by the issue as all the GTX 980cards are manufactured under Nvidia supervision. One can imagine that Taiwanese partners decided to use cheaper components to make slightly larger profits as higher end components don’t get affected by the issue."
ThedEviL
ThedEviL
sõnum 02.12.2014 22:59:56 vasta tsitaadiga
Veider on see, et geforce foorumis vingujad on kõik novembris registreerunud kasutajad.......
MelGibson
sõnum 02.12.2014 23:13:12 vasta tsitaadiga
ThedEviL kirjutas:
massive conspiracy või saadi just kaart kätte / mängiti sisse ja avastati mingi pask icon_razz.gif official release oli 19 september.
ja ega sa muidu ei registeeriks ennast kuskil nvidia saidil, kui sul kaardiga mingit jama poleks
sõnum 03.12.2014 00:32:07 vasta tsitaadiga
Tundub, et siin foorumis on inimestel kaartidega hullult vedanud icon_lol.gif
priitpa
sõnum 03.12.2014 22:51:19 vasta tsitaadiga
jeesus188 kirjutas:
minul kahjuks mitte
Kommentaarid: 25 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 21
heretic666
heretic666
sõnum 04.12.2014 00:03:34 vasta tsitaadiga
Kirjuta googlesse 290X problems või FX5200 problems. Sa leiad iga asja kohta probleeme.
Killhoven
OC`er
Killhoven
sõnum 04.12.2014 12:11:08 vasta tsitaadiga
Probleemidest tuleb rääkida. Meie kui tarbijad kokkuvõttes võidame sellest. beer_yum.gif
Kommentaarid: 409 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 351
Wordmc9
sõnum 04.12.2014 12:22:37 vasta tsitaadiga
coilid välja vahetada icon_smile.gif garantiiga tootele seda muidugi ei tee, toite otsa siluda et ei tekitas colile ebameeldivat sagedust icon_biggrin.gif
Kommentaarid: 344 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 286
