praegune kellaaeg 08.11.2026 06:31:08
Chaza!
21.01.2014 14:49:28
Reported_Uncorrect - Kas tasub muret tunda? |
smartctl 5.41 2011-06-09 r3365 [x86_64-linux-3.2.0-4-amd64] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Device Model: ST2000DL001-9VT156
Serial Number: 6YD129DJ
LU WWN Device Id: 5 000c50 045808236
Firmware Version: CC43
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Tue Jan 21 13:52:46 2014 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 612) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x103f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 108 099 006 Pre-fail Always - 439279384
3 Spin_Up_Time 0x0003 095 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 232
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 075 060 030 Pre-fail Always - 32405153
9 Power_On_Hours 0x0032 080 080 000 Old_age Always - 18261
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 202
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 076 076 000 Old_age Always - 24
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 1
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 060 049 045 Old_age Always - 40 (Min/Max 38/40)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 197
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 237
194 Temperature_Celsius 0x0022 040 051 000 Old_age Always - 40 (0 12 0 0)
195 Hardware_ECC_Recovered 0x001a 026 011 000 Old_age Always - 439279384
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 24
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 24
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 215658897885022
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 2457738812
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 1170227380
SMART Error Log Version: 1
ATA Error Count: 24 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 24 occurred at disk power-on lifetime: 18102 hours (754 days + 6 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 08 ff ff ff 4f 00 17:35:54.002 READ FPDMA QUEUED
27 00 00 00 00 00 e0 00 17:35:54.002 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 17:35:54.001 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 17:35:54.001 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 17:35:54.001 READ NATIVE MAX ADDRESS EXT
Error 23 occurred at disk power-on lifetime: 18102 hours (754 days + 6 hours)
60 00 08 ff ff ff 4f 00 17:35:50.628 READ FPDMA QUEUED
27 00 00 00 00 00 e0 00 17:35:50.628 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 17:35:50.627 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 17:35:50.627 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 17:35:50.627 READ NATIVE MAX ADDRESS EXT
Error 22 occurred at disk power-on lifetime: 18102 hours (754 days + 6 hours)
60 00 08 ff ff ff 4f 00 17:35:47.264 READ FPDMA QUEUED
27 00 00 00 00 00 e0 00 17:35:47.264 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 17:35:47.264 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 17:35:47.264 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 17:35:47.263 READ NATIVE MAX ADDRESS EXT
Error 21 occurred at disk power-on lifetime: 18102 hours (754 days + 6 hours)
60 00 08 ff ff ff 4f 00 17:35:43.901 READ FPDMA QUEUED
27 00 00 00 00 00 e0 00 17:35:43.901 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 17:35:43.900 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 17:35:43.900 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 17:35:43.900 READ NATIVE MAX ADDRESS EXT
Error 20 occurred at disk power-on lifetime: 18102 hours (754 days + 6 hours)
60 00 08 ff ff ff 4f 00 17:35:40.542 READ FPDMA QUEUED
27 00 00 00 00 00 e0 00 17:35:40.542 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 17:35:40.541 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 17:35:40.541 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 17:35:40.541 READ NATIVE MAX ADDRESS EXT
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay. |
Probleemne? Mul on see Raidi mirroris, nii et data minekut väga karta pole.
_________________ Linux - Future
1984 was not supposed to be instruction manual |
| Kommentaarid: 59 loe/lisa |
53 |
