praegune kellaaeg 15.11.2026 15:24:56
ArisBane
19.11.2013 14:24:13
SiS Mirage 3 driverid |
Tere, mure järgmine
chip: sis 672
Peale oma ORDI Enduro 761X Win7 installimist ning draiverite uuendamist jäi screeni reso 1440x900 peale "kinni". Olen proovinud erinevaid draiveri versioone (hetkel peal sisi kodulehelt uuem tõmmatud draiver 5.29 lõpuga), kuid normaalselt funktsioneerima pole veel saanud. Resolutsiooni on vaja muuta selleks, et kõik vanad 2D mängud käima saada. Olgu mainitud, et XP peal töötas asi laitmatult. Ehk oskab keegi midagi tarka öelda/aidata ?
Parimat
siin on minu DxDiag:
System Information
Time of this report: 11/19/2013, 14:07:12
Machine name: XXXXXX-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130801-1533)
Language: Estonian (Regional Setting: Estonian)
System Manufacturer: clevo
System Model: M7x0S
BIOS: BIOS Revision: 1.00.21
Processor: Intel(R) Pentium(R) Dual CPU T3200 @ 2.00GHz (2 CPUs), ~2.0GHz
Memory: 2048MB RAM
Available OS Memory: 1790MB RAM
Page File: 2095MB used, 1482MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: SiS Mirage 3 Graphics
Manufacturer: Silicon Integrated Systems Corp.
Chip type: SiS672 series
DAC type: Internel
Device Key: Enum\PCI\VEN_1039&DEV_6351&SUBSYS_08011558&REV_10
Display Memory: 376 MB
Dedicated Memory: 248 MB
Shared Memory: 128 MB
Current Mode: 1440 x 900 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: ___0000
Native Mode: 1440 x 900(p) (60.000Hz)
Output Type: Internal
Driver Name: SISGRUMD.dll,SISUMD32.dll,SiSClone.dll,SiSFunc.dll,SiSKrl.dll
Driver File Version: 8.14.0010.5290 (English)
Driver Version: 7.14.10.5290
DDI Version: 9Ex
Driver Model: WDDM 1.0
Driver Attributes: Final Retail
Driver Date/Size: 12/15/2010 14:12:40, 4339200 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71ED9-2011-11CF-4262-0B28B1C2C535}
Vendor ID: 0x1039
Device ID: 0x6351
SubSys ID: 0x08011558
Revision ID: 0x0010
Driver Strong Name: oem85.inf:SiS.Mfg.NTamd64:SiS6350:7.14.10.5290:pci\ven_1039&dev_6351
Rank Of Driver: 00F62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeVC1_B
Deinterlace Caps: {BF0537E8-CD1C-42AA-831A-8567DE8FD576}: Format(In/Out)=(YUY2,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_FieldAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBLineReplicate
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBLineReplicate
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{BF0537E8-CD1C-42AA-831A-8567DE8FD576}: Format(In/Out)=(YV12,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_FieldAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBLineReplicate
{BF0537E8-CD1C-42AA-831A-8567DE8FD576}: Format(In/Out)=(NV12,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_FieldAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBLineReplicate
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
kalvis
19.11.2013 15:59:30
Naised saunas rääkisid, et selline totrus olla vistal VGA liidesel - videokaart küsib monitorilt parima resolutsiooni ja paneb selle jõuga peale, ilma võimaluseta muuta. Rohuks olevat VGA pistikus andmevahetuse pin katki hammustamine.
Teine variant on, et videokaardi draiver lubab resot muuta vaid oma utiliidiga. Seda viimast on ette juhtunud küll.
ArisBane
19.11.2013 18:43:35
Kahjuks selle draiveri oma utiliid on viimane hõkkhõmm, mis ei luba miskit teha.
Kui mingi skeemid/asjad leiaks võiks ju pini katki hammustada, kuid lihtsam variant tundub XP OS-na olevat.
Tänud sellegipoolest
kalvis
21.11.2013 08:59:23
VGA pistiku pin on üsna lihtsalt leitavad. Google annab kiire vastuse
Seda VGA pistiku reso lukustumine vista ja 7 juhtumis on netis palju kajastatud koos rohkete vandesõnadega kompanii aadressidele, enne kui lammutama lähed, loe võimalikult palju. Äkki on mingid häkkdraiverid olemas.
