uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  Probleem Nvidia GTS 450iga märgi kõik teemad loetuks
saladpunch
sõnum 22.09.2013 18:12:31 Probleem Nvidia GTS 450iga vasta tsitaadiga
Niiet, põhimõtteliselt algas probleem sellest kui lasin Vistal peale service pack 1, enne seda video kaart töötas, näitas Device Manageris et oli olemas ja sai draivereid vahetevahel uuendada, aga kui SP1 peale lasin siis kadus video kaart Device Managerist ja Display settingute all oli hoopis Generic PnP monitor/Default Monitor, samuti viskab Intel(R) 945G/GZ/GC/P/PL PCI Express Root Port -2771 ette Error 35, mis nõuab et uuendaks BIOSi vms.
Dxdiagis viskab ette (kuni Display Adapterini)
System Information
Time of this report: 9/22/2013, 18:49:25
Machine name: MARTIN-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
Language: Estonian (Regional Setting: Estonian)
System Manufacturer: ECS
System Model: 945PT-A2
BIOS: Default System BIOS
Processor: Pentium(R) Dual-Core CPU E5200 @ 2.50GHz (2 CPUs), ~2.5GHz
Memory: 4096MB RAM
Available OS Memory: 3584MB RAM
Page File: 1154MB used, 6010MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name:
Manufacturer:
Chip type:
DAC type:
Device Key: Enum\
Display Memory: n/a
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 1280 x 1024 (32 bit) (1Hz)
Driver Name:
Driver File Version: ()
Driver Version:
DDI Version: unknown
Driver Model: unknown
Driver Attributes: Final Retail
Driver Date/Size: , 0 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B70EE0-4340-11CF-B123-B03DAEC2CB35}
Vendor ID: 0x0000
Device ID: 0x0000
SubSys ID: 0x00000000
Revision ID: 0x0000
Driver Strong Name: Unknown
Rank Of Driver: Unknown
Video Accel:
Deinterlace Caps: n/a
D3D9 Overlay: n/a
DXVA-HD: n/a
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
Kuigi arvutis on pilt veel ees tundub nagu jookseks intergreeritud videokaardi peal. Ja kui Windows 7 peale lasin ei muutunud midagi, sama jama mis Vista SP 1-2. Videokaart täpsemalt on Club3D Geforce Nvidia GTS 450, üks asi mis ise suutaks pakkuda mis tundub mingit moodigi loogiline on see et kuna arvutis on sees 450W toiteplokk ja kaardi miinimum on 400w siis äkki selles kuigi kuna miinimum on täidetud siis ei usu eriti.
Videokaart ise on 1024 mb DDR3
ja lõpuks Display Adapter üldse puudub device managerist ja ise väga proff ei ole, aga BIOSis muutsin ära
PCI vms settingute alt PCI Card pealt PCI-E peale lootes et muudab midagi aga .... jah icon_sad.gif Praegu on Windows 7 peal aga kui see probleem lahendatud ei saa siis arvatavasti lähen tagasi Vista peale kuni saan uue emaplaadi või siis lähimal ajal toiteplokki kui tulebki välja et see probleemiks (ntks liiga vähe voolu vms)
reints
reints
sõnum 22.09.2013 18:56:53 vasta tsitaadiga
Sa nagu nvidia driverid jõuga proovisid peale lasta ?
http://www.geforce.co.uk/drivers
saladpunch
sõnum 22.09.2013 19:19:07 vasta tsitaadiga
No, põhimõtteliselt dravieri installil viskab ette Cannot find compatible hardware ja kõik (ntks kõige uuemaga mingi 327.23 vist), peale selle pole proovinud
lopes39
lopes39
sõnum 23.09.2013 20:23:12 vasta tsitaadiga
32.7.23 whql tuli siin just miski sel nädalal välja. Pigem proovi vanemaid drivereid.
saladpunch
sõnum 26.09.2013 13:05:13 vasta tsitaadiga
kõige vanema mis netist sain 267.46 kätte ikka ütleb et cant find compatible hardware. Kaardi antud draiver ka ei tööta, põhimõtteliselt on ikka praegu perses icon_smile.gif.
