Kilpa
04.01.2013 21:25:51
HD7970 ja 6pin küsimus |
Tere,
Selline küsimus, et kas võib kasutada 8pin kaabli asemel 6pin kaablit ajutiselt?
Kas see kahjustab videokaarti kuidagi?
Ette tänades
Kilpa
| Kommentaarid: 26 loe/lisa |
25 |
heikis
04.01.2013 21:30:37
| kindlasti on see manualis kirjas!
| Kommentaarid: 339 loe/lisa |
291 |
onni
Kilpa
25 |
onni
04.01.2013 23:30:00
Raske küsimus ,ise kasutan gigabyte 6750 1giga ddr5 mälu ja kasutab 6 pin pesa.äkki keegi targem oskab öelda.iga abi oleks ju ikka abiks.looda,et aja möla
heikis
04.01.2013 23:56:30
| ega need lisa 2 auku nagunii 12V liini peal ei ole- mõlemad on groundid.
291 |
onni
05.01.2013 00:13:06
Arvan,et tasub proovida 2x6 pinni äkki aitab
UrmoZ
05.01.2013 02:53:01
Ega need 2 pin-i asjata lisatud ei ole.
HD7970 on 250W kaart - PCI-E siin võimaldab 75W, 6pin 75W, 8pin 150W.
http://www.jonnyguru.com/forums/showthread.php?t=1220
| jonnyGURU kirjutas: |
The two extra wires on the 8-pin, compared to the 6-pin, are an extra ground and a +12V sense. PSU's that are "retrofitted" to the 8-pin PCI-e that do not natively have any +12V sense circuitry leading back to the PWM will have two extra grounds (you can never have enough grounds.)
6-pin PCI-e connector capable of drawing +12V up to 6.25A
8-pin PCI-e connector capable of drawing +12V up to 12.5A |
| tomshardware kirjutas: |
| The sense signals are used so that the graphics card can detect what types of connector(s) are attached, and therefore how much total power is available. For example, if a graphics card needs a full 300 W and has both an eight-pin and six-pin connector on board, if you were to attach two six-pin power supply connectors, the card would “sense” that it had only 225 W available and, depending on the design, it could either shut down or operate in a reduced functionality mode. |
Ainult kahe 6pin ühendusega ei soovita katsetama hakata. Kasuta vähemalt sobivat adapterit.
_________________ Amazon - will not buy!
12VHPWR or 12V2x6 GPU power connector - will not touch.
Müügiteemale PS pakkumisi ei aktsepteeri! |
| Kommentaarid: 226 loe/lisa |
206 |
Kilpa
05.01.2013 03:49:21
Hästi, eks ma siis kannatan veel
Suur tänu vastuse eest igatahes.
25 |
