Teaq
02.10.2012 18:29:19
2x Quadro 2000 probleem |
Tervist!
Selline probleem siis, et kaks quadro2000 kaarti ei saa hakkama (teeb aeglaselt) lihtsamate graafiliste ülesannetega.
Samas samasugused masinad peaksid ülesannetega üsna kiirelt hakkama saama.
Äkki mõni targem oskab öelda, mis probleem võib olla?
System Information
Time of this report: 10/2/2012, 18:23:48
Machine name: MADPRODUCTION
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
Language: Estonian (Regional Setting: Estonian)
System Manufacturer: Dell Inc.
System Model: Precision WorkStation T3500
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A14
Processor: Intel(R) Xeon(R) CPU W3550 @ 3.07GHz (4 CPUs), ~3.1GHz
Memory: 16384MB RAM
Available OS Memory: 16382MB RAM
Page File: 3576MB used, 29184MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA Quadro 2000
Manufacturer: NVIDIA
Chip type: Quadro 2000
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0DD8&SUBSYS_084A10DE&REV_A1
Display Memory: 721 MB
Dedicated Memory: 978 MB
Shared Memory: 3838 MB
Current Mode: 5120 x 1440 (32 bit) (59Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: DELL U2711
Monitor Id: DELA057
Native Mode: 2560 x 1440(p) (59.951Hz)
Output Type: Displayport External
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 8.17.0012.9670 (English)
Driver Version: 8.17.12.9670
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 4/27/2012 14:27:00, 17675584 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-4E98-11CF-A856-46281FC2C535}
Vendor ID: 0x10DE
Device ID: 0x0DD8
SubSys ID: 0x084A10DE
Revision ID: 0x00A1
Driver Strong Name: oem10.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section018:8.17.12.9670:pci\ven_10de&dev_0dd8
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: DELL U2711-1 (3- NVIDIA High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0011&SUBSYS_10DE0101&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvhda64v.sys
Driver Version: 1.03.0012.0000 (English)
WHQL Logo'd: Yes
Date and Size: 1/17/2012 15:45:56, 188224 bytes
Other Files:
Driver Provider: NVIDIA Corporation
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Speakers (SoundMAX Integrated Digital High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_194A&SUBSYS_10280293&REV_1004
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ADIHdAud.sys
Driver Version: 6.10.0002.7250 (English)
WHQL Logo'd: Yes
Date and Size: 4/23/2009 11:41:06, 497152 bytes
Other Files:
Driver Provider: AnalogDevices
Cap Flags: 0xF1F
HW Memory: 0
Description: DELL U2711-1 (4- NVIDIA High Definition Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (SoundMAX Integrated Digital High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Rear Input (SoundMAX Integrated Digital High Definition Audio)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x3A35
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 3/25/2011 06:29:26, 343040 bytes
| Driver: usbd.sys, 3/25/2011 06:28:59, 7936 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Vendor/Product ID: 0x413C, 0x2107
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 11/21/2010 06:23:47, 33280 bytes
| Driver: kbdclass.sys, 7/14/2009 04:48:04, 50768 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 7/14/2009 02:19:57, 105472 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x046D, 0xC05A
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/14/2009 03:00:20, 31232 bytes
| Driver: mouclass.sys, 7/14/2009 04:48:27, 49216 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/21/2010 06:23:47, 63360 bytes
| Driver: sermouse.sys, 7/14/2009 03:00:20, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 36.1 GB
Total Space: 114.5 GB
File System: NTFS
Model: KINGSTON SH100S3120G
Drive: D:
Free Space: 1430.7 GB
Total Space: 1430.8 GB
File System: NTFS
Model: WDC WD15EARX-22PASB0
Drive: E:
Free Space: 675.2 GB
Total Space: 953.8 GB
File System: NTFS
Model: ST31000524AS
Drive: G:
Free Space: 236.0 GB
Total Space: 238.4 GB
File System: FAT32
Model: ST925041 0ASG USB Device
Drive: J:
Free Space: 136.5 GB
Total Space: 476.9 GB
File System: NTFS
Model: Seagate ATA Device 00 IEEE 1394 SBP2 Device
Drive: F:
Model: TSSTcorp DVD+-RW SH-216AB
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (Estonian), 11/21/2010 06:23:47, 147456 bytes
System Devices
Name: Intel(R) ICH10 Family PCI Express Root Port 6 - 3A4A
Device ID: PCI\VEN_8086&DEV_3A4A&SUBSYS_02931028&REV_00\3&172E68DD&0&E5
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/21/2010 06:23:47, 184704 bytes
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A36
Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_02931028&REV_00\3&172E68DD&0&EA
Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7601.17586 (English), 3/25/2011 06:29:03, 30720 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/25/2011 06:29:14, 325120 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/25/2011 06:29:26, 343040 bytes
Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E
Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_02931028&REV_22\3&172E68DD&0&38
Name: NVIDIA Quadro 2000
Device ID: PCI\VEN_10DE&DEV_0DD8&SUBSYS_084A10DE&REV_A1\4&F067098&0&0038
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 224064 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 4/27/2012 14:27:00, 329156 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_amd64_neutral_bf586c8517ebd16d\NvCplSetupInt.exe, 1.00.0001.0000 (Estonian), 4/27/2012 14:27:00, 71608368 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\Nvd3d9wrap.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 236352 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 4/27/2012 14:27:00, 4096 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 182080 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\Nvd3d9wrapx.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 261120 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 4/27/2012 14:27:00, 4096 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 202752 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 4/27/2012 14:27:00, 21887 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 4/27/2012 14:27:00, 32471 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 4/27/2012 14:27:00, 202560 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 4/27/2012 14:27:00, 315712 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 4/27/2012 14:27:00, 61248 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.00.0000.0000 (English), 4/27/2012 14:27:00, 68928 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 14398272 bytes
Driver: C:\Windows\system32\nvapi64.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 2685760 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 25224512 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 8047424 bytes
Driver: C:\Windows\system32\nvcuvenc.dll, 6.14.0012.9670 (English), 4/27/2012 14:27:00, 2873664 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 2673984 bytes
Driver: C:\Windows\system32\nvd3dumx.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 17675584 bytes
Driver: C:\Windows\system32\nvdecodemft.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 364352 bytes
Driver: C:\Windows\system32\nvinfo.pb, 4/27/2012 14:27:00, 12780 bytes
Driver: C:\Windows\system32\nvinitx.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 260928 bytes
Driver: C:\Windows\system32\nvoglv64.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 25626432 bytes
Driver: C:\Windows\system32\nvumdshimx.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 962880 bytes
Driver: C:\Windows\system32\nvwgf2umx.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 9749312 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 2324288 bytes
Driver: C:\Windows\SysWow64\nvcompiler.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 17543488 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 5925184 bytes
Driver: C:\Windows\SysWow64\nvcuvenc.dll, 6.14.0012.9670 (English), 4/27/2012 14:27:00, 2438464 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 2518336 bytes
Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 15036736 bytes
Driver: C:\Windows\SysWow64\nvdecodemft.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 301376 bytes
Driver: C:\Windows\SysWow64\nvinit.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 215360 bytes
Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 19510592 bytes
Driver: C:\Windows\SysWow64\nvumdshim.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 813376 bytes
Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.17.0012.9670 (English), 4/27/2012 14:27:00, 7742784 bytes
Driver: C:\Windows\system32\nvdispco64.dll, 2.00.0025.0001 (English), 4/27/2012 14:27:00, 1737536 bytes
Driver: C:\Windows\system32\nvgenco64.dll, 2.00.0014.0000 (English), 4/27/2012 14:27:00, 1466176 bytes
Name: Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40
Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_02931028&REV_00\3&172E68DD&0&E0
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A35
Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_02931028&REV_00\3&172E68DD&0&E9
Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A
Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_02931028&REV_22\3&172E68DD&0&18
Device ID: PCI\VEN_10DE&DEV_0DD8&SUBSYS_084A10DE&REV_A1\4&165B8C32&0&0018
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_3A3E&SUBSYS_02931028&REV_00\3&172E68DD&0&D8
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/21/2010 06:23:47, 122368 bytes
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A34
Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_02931028&REV_00\3&172E68DD&0&E8
Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 1 - 3408
Device ID: PCI\VEN_8086&DEV_3408&SUBSYS_02931028&REV_22\3&172E68DD&0&08
Device ID: PCI\VEN_10DE&DEV_0BE9&SUBSYS_084A10DE&REV_A1\4&F067098&0&0138
Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_02931028&REV_00\3&172E68DD&0&D7
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 3/25/2011 06:29:04, 52736 bytes
Name: Intel(R) ICH10 Family SMBus Controller - 3A30
Device ID: PCI\VEN_8086&DEV_3A30&SUBSYS_02931028&REV_00\3&172E68DD&0&FB
Driver: n/a
Name: Intel(R) 5520/5500/X58 I/O Hub to ESI Port - 3405
Device ID: PCI\VEN_8086&DEV_3405&SUBSYS_02931028&REV_22\3&172E68DD&0&00
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0BE9&SUBSYS_084A10DE&REV_A1\4&165B8C32&0&0118
Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_02931028&REV_00\3&172E68DD&0&EF
Name: Intel(R) ICH10R LPC Interface Controller - 3A16
Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_02931028&REV_00\3&172E68DD&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 04:48:27, 15424 bytes
Name: Intel(R) ICH8R/ICH9R/ICH10R/DO SATA RAID Controller
Device ID: PCI\VEN_8086&DEV_2822&SUBSYS_02931028&REV_00\3&172E68DD&0&FA
Driver: C:\Windows\system32\DRIVERS\iaStorV.sys, 8.06.0002.1014 (English), 3/11/2011 09:41:26, 410496 bytes
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A39
Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_02931028&REV_00\3&172E68DD&0&D2
Name: Intel(R) 5520/5500/X58 I/O Hub System Management Registers - 342E
Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_00930028&REV_22\3&172E68DD&0&A0
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_02931028&REV_90\3&172E68DD&0&F0
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A38
Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_02931028&REV_00\3&172E68DD&0&D1
Name: Intel(R) 5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423
Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_00930028&REV_22\3&172E68DD&0&A2
Driver: n/a
Name: Broadcom NetXtreme 57xx Gigabit Controller
Device ID: PCI\VEN_14E4&DEV_1681&SUBSYS_02931028&REV_10\4&170BFACC&0&00E5
Driver: n/a
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A37
Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_02931028&REV_00\3&172E68DD&0&D0
Name: Intel(R) 5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422
Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_00930028&REV_22\3&172E68DD&0&A1
Driver: n/a
Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3403&SUBSYS_34031106&REV_01\4&1C991F90&0&0008
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7601.17514 (English), 11/21/2010 06:23:47, 229888 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
Overlay Mixer2,0x00200000,1,1,,
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Microphone (SoundMAX Integrated,0x00200000,0,0,qcap.dll,6.06.7601.17514
Rear Input (SoundMAX Integrated,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
SoundMAX HD Audio I,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
NVIDIA High Definition Audio,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
SoundMAX HD Audio O,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
DELL U2711-1 (3- NVIDIA High De,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DELL U2711-1 (4- NVIDIA High De,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: DELL U2711-1 (3- NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: DELL U2711-1 (4- NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (SoundMAX Integrated Digital High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
Speakers (SoundMAX Integrated D,0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
