uus teema   vasta Uudised »  Pealtkuulamine ja tsensuur, ACTA, DMCA, GDPR »  ACTA siiski elab: Euroopa Komisjon tahab kasutada CETA kaubanduslepet tagauksena ACTA elustamiseks?! märgi kõik teemad loetuks
sõnum 10.07.2012 00:16:12 ACTA siiski elab: Euroopa Komisjon tahab kasutada CETA kaubanduslepet tagauksena ACTA elustamiseks?! vasta tsitaadiga
Kuigi ACTA lükati Euroopa Parlamendis eelmisel nädalal tagasi, plaanib Euroopa Komisjon kolumnist Michael Geistile hiljuti kättesaadavaks saanud dokumentide andmeil kasutada Kanada-Euroopa Liidu vahelist kaubanduslepet CETA tagauksena ACTA elustamiseks. Allikaks on hiljuti lekkinud dokumendid, mille järgi CETA ja ACTA paljudes osades kattuvad. Paistab, et Euroopa Komisjon tahab hoolimata rahva ja Euroopa Parlamendi ning komisjonide vastuseisust ACTA iga hinna eest elustada ja selle Euroopas kehtestada.
The EU has also proposed incorporating ACTA's criminal enforcement and co-operation chapters into CETA. The criminal provisions were the target of European Parliament criticism for their lack of proportionality and uncertain application.
Canada has similarly pushed for the inclusion of ACTA provisions, proposing identical digital lock rules as well as ACTA-style Internet service provider provisions that raised privacy concerns from the European Data Protection Supervisor. In fact, Canada would like to extend ACTA by mandating an anti-camcording provision (a similar provision is currently voluntary in ACTA).
The European Commission strategy appears to be to use CETA as the new ACTA, burying its provisions in a broader Canadian trade agreement with the hope that the European Parliament accepts the same provisions it just rejected with the ACTA framework. If successful, it would likely then argue that ACTA poses no new concerns since the same rules were approved within the Canadian trade deal.
The backdoor ACTA approach creates enormous risks for Canada's trade ambitions. Given the huge anti-ACTA movement, the Canada - EU trade deal could face widespread European opposition with CETA becoming swept up in similar protests.
Loe edasi Michael Geist blogist.
HV-s ID-kaardiga autentimine
viimati muutis Tanel 15.07.2018 01:06:32, muudetud 2 korda
ufo56
ufo56
sõnum 10.07.2012 02:50:06 vasta tsitaadiga
Järjekindlus uskumatu.
 Lae pildid -> pilt.io
sõnum 10.07.2012 07:44:25 vasta tsitaadiga
HPN
HPN
sõnum 10.07.2012 07:59:09 vasta tsitaadiga
Tuleb lihtsalt sama lolli järjekindlusega vastata (nii palju kui igaühel võimalik kaasa rääkida on). Hea, et nad veel neid asju mitme "seaduse" peale ära pole otsustanud jagada, sest siis on tõenäosus suurem millegi salaja läbi lipsamiseks.
Leinö
Leinö
sõnum 10.07.2012 08:39:46 vasta tsitaadiga
Kahjuks nii palju kodanikke ei saaks enam kokku, et petitsioon allkirjastada jne. Rahvas hakkab tiba väsima sellest kemplemisest ja paistab, et see ongi EU kollide taktika.
sõnum 10.07.2012 09:11:37 vasta tsitaadiga
Selline pidev elushoidmind ja j6uga pähepeksmine, kuni asi on paigas, on tüüpiline USA turundusv6te. Ja nii meile neid Acta-kloone ette pannakse, kuni m6ni neist alla neelatakse.
Postitatud Sony Ericsson mobiililt
Killer-Bea
Killer-Bea
sõnum 10.07.2012 09:24:53 vasta tsitaadiga
USA's tehti näiteks selline lüke http://www.trueactivist.com/obama-seizes-control-of-all-communications-systems-with-executive-order/
Aga siin eurotsoonis, inimeste väsimine oleks lubamatu. Samamoodi nagu neid 4ja tähelisi akte ette lükatakse tuleb neid sama järjepidavalt maha tampida.
Üleüldiselt tuleks euroliidus juba sisse viia mingi seadus mis paneb üleüldise ban selliste aktide parlamenti saatmise üleüldse.
Dinkz
sõnum 10.07.2012 09:26:44 vasta tsitaadiga
Eks seda oli ka arvata ju, et peale ACTA't jonni ei jäeta. Oli veel mitmeid muu nimetusega üritusi.
Orlando
sõnum 10.07.2012 15:50:10 vasta tsitaadiga
http://falkvinge.net/2012/07/10/alarm-over-ceta-appears-premature/
Diesel157
sõnum 11.07.2012 14:17:54 vasta tsitaadiga
Eks nad pressivad seda jama seni, kuni inimesed lõpuks ära väsivad ja enam protestida ei viitsi. Nendel ju aega on... . Kujutab keegi ette seda, et me järjest protestime siin iga "uue" versiooni vastu siin järgmised 5 aastat kopp.gif
sõnum 11.07.2012 14:24:16 vasta tsitaadiga
Diesel157 kirjutas:
Kui neil lõpuks miski jaburdus läbi läheb, siis, usu mind, et inimesed lõpuks ei viitsi tarbida igasugu "intellektuaalomandit". Vot ei tea mis siis ette võetakse kuna ACTAde ja muude mambodzambode peale on raha läinud ja narr oleks, kui edaspidi ei hakkagi enam kasumit tulema niipalju kui praeguse mudeli järgi loodetakse saada "Piramise" eest...
Mnator
sõnum 11.07.2012 14:26:11 vasta tsitaadiga
Loodavad, et kasvab uus põlvkond peale, kes vanadest headest aegadest ja kommetest midagi ei tea.......
sõnum 11.07.2012 17:29:45 vasta tsitaadiga
Voi siis ongi esialgne plaan alguses pakkuda meelega ylepingutatud punktidega leppeid, siis tehes neis parandusi ja punkte lodvemaks lastes pressitekase labi. Kuigi alguses oligi plaanis need lodvemaks lastud punktid labi pressida, aga rahvale jaab mulje nagu oleks miskit nende survel ara parandatud.
sõnum 12.07.2012 18:21:28 vasta tsitaadiga
Ei tea, kas see siia sobib, kuid interneti-info põhjal elustatakse SOPA-t läbi uuestisünni uue nime all IPAA.
http://arstechnica.com/tech-policy/2012/07/sopa-architect-now-pushing-for-ip-attache-legislation/
http://www.neowin.net/news/sopa-rises-from-the-grave-once-more
d_m
sõnum 16.10.2012 14:59:29 vasta tsitaadiga
CETA tahab tulla tõesti: https://www.eff.org/deeplinks/2012/10/ceta-replicates-acta
"It is disguised as CETA, the Canada-European Union and Trade Agreement. A comparison of the leaked draft Canada-EU agreement shows the treaty includes a number of the same controversial provisions, specifically concerning criminal enforcement, private enforcement by Internet Service Providers (ISPs), and harsh damages."
sooty
sõnum 27.10.2016 14:49:19 vasta tsitaadiga
Tehti ära:
http://arileht.delfi.ee/news/uudised/el-i-kanada-vabakaubandusleppe-ule-saavutati-lopuks-belgia-sisene-kokkulepe?id=76067585
sõnum 15.07.2018 01:00:48 vasta tsitaadiga
https://majandus24.postimees.ee/4969869/trump-pole-ainus-vabakaubandsulepete-vastane-itaalia-ei-ratifitseeri-kanada-ja-euroopa-liidu-vabakaubanduslepet
«CETA (Comprehensive and Economic Trade Agreement) läheb varsti parlamenti, aga enamus lükkab selle tagasi ning ei ratifitseeri seda,» ütles Di Maio Roomas toimunud põllumeeste ühenduse kogunemisel, vahendab Reuters. «Kui vähemalt üks Itaalia ametnik ... jätkab selliste lepete, nagu on CETA, kaitsemist, siis eemaldatakse ta ametist,» lisas ta. Di Maion on ka populistliku Viie Tähe Liikumine juht.
CETA ehk Euroopa Liidu ja Kanada Vabakaubanduslepe jõustub ametlikult septembris ja selle peavad ratifitseerima kõik 28 liikmesriiki.
Kuid Kanada sõnul on 98 protsenti leppega kehtestatud tariifide alandamisest ja eemaldamisest juba ellu viidud.
Lisaks: https://edri.org/european-canadian-civil-society-groups-call-rejection-ceta/
Part of the Agreement is stricter enforcement of intellectual property, including liability for Internet Service Providers, a ban on technologies that can be used to circumvent copyright, and other provisions similar to controversial ACTA, DMCA, PIPA, and SOPA, as below: Electronic Frontier Foundation stated that this "trade agreement replicates ACTA's notorious copyright provisions".
