7 :: |
364 |
02.11.2011 07:49:41
Ubuntu ei pruugi "nututeleris" veel joosta, kuid linuxilised on teleritootjatel oma seadmetes sellegipoolest jooksmas.
LG puhul on jäänud silma sõna "SQUASHFS ", selles võin muidugi eksida.
131 |
Ho Ho
02.11.2011 09:42:17
Esimene versioon KDE tahvlitele-mobiilidele orienteeritud softipaketist Plasma Active'i näol valmis suts rohkem kui kuu tagasi. Ei tea kas Ubuntu hakkab toda kasutama või aretavad mingi omaloomingu
87 |
meybo
02.11.2011 11:50:05
Kui ma ei eksi, siis juba üsna pikka aega on enamuse nutikama koduelektroonika tarkvara baseerunud Linuxi kernelil.
_________________ www.meybo.ee |
| Kommentaarid: 22 loe/lisa |
20 |
02.11.2011 12:27:36
Ja Android on nende arvates mis?
196 |
02.11.2011 14:35:13
Võõrkeelsed infokanalid ütlevad hoopis pigem seda, et tegu on võitlusega Google Androidi ning Mirosofti tulevase Windows 8 ülemvõimu vastu.
Tsitaat:
Shuttleworth sees “Android as its primary competitor. But, from the industry viewpoint,Google acquisition of Motorola Mobility has shook up the hardware vendors, so some of them are looking for non-Android alternatives…”
As for the other alternatives, “OEMs have tough choices. They can build their own operating system, such as what HP did for a while with webOS or work in a consortium, Consortiums [such as the one behind the now effectively defunct MeeGo] can’t win. They can’t take a forceful, direct view with their products. The smartest OEM strategy is to play people off against each other. Thus, some OEMs want to have Ubuntu as a disruptive element. A strong Ubuntu can be both more co-operative with OEMs than a larger company and give them leverage with Google and Microsoft.” Finally, and this is telling, “Ubuntu has shown that we can hit deadlines and innovate. We can deliver a good plan and products.”
November 1, 2011, 7:35 AM GMT
Ubuntu Versus Android for Phones and Tablets
http://blogs.wsj.com/tech-europe/2011/11/01/ubuntu-versus-android-for-phones-and-tablets/
211 |
jaco
03.11.2011 10:33:53
Mina aiman midagi sellist:
Kuni nad ei loo süsteemi, mis võimaldaks kasutada android marketis olevaid appe, hakkavad seda asja kasutama vaid üksikud fännid.
Kuni seda kasutavad üksikud fännid, ei hakka suurem osa appide tootjad välja andma ubuntule sobivat versiooni oma appist...
| Kommentaarid: 39 loe/lisa |
37 |
TT
03.11.2011 11:13:59
Või teeb mõni üksik fänn programmi mis teeb androidi asjad söödavaks
_________________ Things ThaT You own end up Owning you! |
276 |
Ho Ho
03.11.2011 11:18:36
Aliendalvik peaks jooksma suht suvalise *nixi peal
87 |
vortex
03.11.2011 11:33:19
| Plasma Active One näeb praegu veel välja nagu paras õnnetus.
| Kommentaarid: 42 loe/lisa |
37 |
Ehhr
layr
14.11.2011 14:02:40
| Jap, nii kurb kui see ka pole. Kui ma õigesti aru saan, siis Win8 on sammu samas suunas astunud, mis imho GUI desktopile sobimatuks muudab. Jah, see võib kokkuvõttes olla isegi ergonoomilisem, tootlikum ja whatnot, kuid kui on võimalus, siis ma ei hakka ümber harjuma (vihje Unityle).
7 :: |
364 |
krist2an
41 |
Max Powers
03.01.2013 18:45:14
Tundub päris ilus.
Dokkimine ja arvutina kasutamine oleks hea.
182 |
woox2k
03.01.2013 19:17:25
Uurisin kah mingivahe, muidu nagu androidi ees eelist polegi aga kui arvestada, et Androidil on tv out niisama naljapärast siis Ubuntuga võib isegi täitsa kasu olla ja mine tea, mõnel pole lauaarvutit vajagi kui see olemas
Küsimus ka: Kui nad reklaamivad seda kui täisfunktsionaalset lauaOS'i isegi koos winega. (Dockis muidugi) Kuidas nad programme sinna ARMi peale saavad? x86 jura ei tohiks ju ARM peal toimida. Kas nad said kuidagi need toimima või ongi ainult 2-3 programmi sellel ja kogu lugu?
_________________ Mess with the best, die like the rest! |
| Kommentaarid: 20 loe/lisa |
18 |
