-vodafone-
03.10.2011 10:56:06
HTTP Error 403.7 - Forbidden: SSL client certificate is required. |
The page requires a client certificate
The page you are attempting to access requires your browser to have a Secure Sockets Layer (SSL) client certificate that the Web server will recognize. The client certificate is used for identifying you as a valid user of the resource.
Please try the following:
Contact the Web site administrator if you believe you should be able to view this directory or page without a client certificate, or to obtain a client certificate.
If you already have a client certificate, use your Web browser's security features to ensure that your client certificate is installed properly. (Some Web browsers refer to client certificates as browser or personal certificates.)
Internet Information Services (IIS)
Technical Information (for support personnel)
Go to Microsoft Product Support Services and perform a title search for the words HTTP and 403.
Open IIS Help, which is accessible in IIS Manager (inetmgr), and search for topics titled About Certificates, Using Certificate Trust Lists, Enabling Client Certificates, and About Custom Error Messages. |
Lehelt annab küll sert. alla laadida ja ka nagu installida, aga ligipääsu lehele siiski ei saa. Serdile jääb hüüumärk juurde. Varem on lehele ligipääs olnud olemas. Tegu siis ID kaardiga sinna lehele minekuga. Milles probleem?
IE 8
217 |
A.S.
03.10.2011 11:07:36
| Sellist elementaarset asja, nagu arvuti kuupäeva, oled ilmselt juba kontrollinud?
| Kommentaarid: 34 loe/lisa |
34 |
-vodafone-
03.10.2011 11:13:33
| A.S. kirjutas: |
| Sellist elementaarset asja, nagu arvuti kuupäeva, oled ilmselt juba kontrollinud? |
Jah, kuupäev on õige, samuti näitab sert. et ta kehtib aasta lõpuni.
217 |
03.10.2011 11:38:24
Milline opsüsteem?
| Kommentaarid: 759 loe/lisa |
569 |
-vodafone-
03.10.2011 11:52:57
| XP
217 |
03.10.2011 13:02:18
Kas sert on trusted igat pidi? Internet Options > Content > Certificates?
569 |
-vodafone-
03.10.2011 13:04:50
| Jah.
217 |
Andrus Luht
itimees.ee
318 |
-vodafone-
03.10.2011 13:12:17
| Ta on Other user people all miskipärast ? Peabki olema? Või mida sa mõtled konteineri all.
217 |
Andrus Luht
itimees.ee
318 |
-vodafone-
03.10.2011 15:40:40
| Kuidas ma saan ta sinna. Expordin ja siis impordin sinna?
217 |
03.10.2011 15:44:28
Valid Import ja näitad sertifikaadi asukoha kätte.
569 |
-vodafone-
04.10.2011 11:49:19
ei ilmu sinna
217 |
04.10.2011 18:39:26
The page you are attempting to access requires your browser to have a Secure Sockets Layer (SSL) client certificate that the Web server will recognize. The client certificate is used for identifying you as a valid user of the resource. |
Jutt on kliendi, mitte serveri sertifikaadist - sinu isiklikust sertifikaadist (õigemini selle avalikust võtmest), mis asub ID kaardi kiibi sees ja mille brauser peaks serverile esitama.
Kui seda ei juhtu, siis on võimalusi tõrkeks üsna mitmeid ja ma parem ei hakkaks kohe midagi oletama.
Kas on paigaldatud uusim ID-kaardi tarkvara installer.id.ee lehelt?
Millist antiviirust kasutad ja kas oled seda ise seadistanud? (HTTPS protokolli kontrolli ei tohi sisse lülitada, kui ID-kaardiga autentimist kasutada tahad või pead ID-autentivad lehed erandina loetlema kui mittekontrollitavad leheküljed (exceptions))
Kui on uusim ID-kaardi tarkvara, siis proovi mõne muu brauseriga (Firefox, Chrome). Olenevalt katsetuste tulemusest saab ehk natuke paremat aimu, kust viga otsima hakata.
-vodafone-
217 |
Andrus Luht
itimees.ee
318 |
05.10.2011 17:08:41
| Andrus Luht kirjutas: |
| -vodafone-, tõmba omal id-kaardi utiliit käima ja registreeri oma sertifikaadid uuesti ära. |
Ja lisaks sellele - vastamata jäi minu küsimus antiviiruse kohta. ESET tooted ja Kaspersky ning vist ka Avast on kolm kindlat toodet mida ma tean, millega ID-kaardi kasutamise saab edukalt ära blokeerida. Tõenäoliselt on sarnaseid AV tooteid tänasel päeval juba rohkem, lihtsalt pole mul nende kohta konkreetset infot.
