uus teema   vasta Tarkvara »  Turvalisus »  HTTP Error 403.7 - Forbidden: SSL client certificate is required. märgi kõik teemad loetuks
-vodafone-
-vodafone-
sõnum 03.10.2011 09:56:06 HTTP Error 403.7 - Forbidden: SSL client certificate is required. vasta tsitaadiga
The page requires a client certificate
The page you are attempting to access requires your browser to have a Secure Sockets Layer (SSL) client certificate that the Web server will recognize. The client certificate is used for identifying you as a valid user of the resource.
Please try the following:
Contact the Web site administrator if you believe you should be able to view this directory or page without a client certificate, or to obtain a client certificate.
If you already have a client certificate, use your Web browser's security features to ensure that your client certificate is installed properly. (Some Web browsers refer to client certificates as browser or personal certificates.)
Internet Information Services (IIS)
Technical Information (for support personnel)
Go to Microsoft Product Support Services and perform a title search for the words HTTP and 403.
Open IIS Help, which is accessible in IIS Manager (inetmgr), and search for topics titled About Certificates, Using Certificate Trust Lists, Enabling Client Certificates, and About Custom Error Messages.
Lehelt annab küll sert. alla laadida ja ka nagu installida, aga ligipääsu lehele siiski ei saa. Serdile jääb hüüumärk juurde. Varem on lehele ligipääs olnud olemas. Tegu siis ID kaardiga sinna lehele minekuga. Milles probleem?
IE 8
Kommentaarid: 245 loe/lisa Kasutajad arvavad:  :: 1 :: 3 :: 216
A.S.
sõnum 03.10.2011 10:07:36 vasta tsitaadiga
Sellist elementaarset asja, nagu arvuti kuupäeva, oled ilmselt juba kontrollinud?
-vodafone-
-vodafone-
sõnum 03.10.2011 10:13:33 vasta tsitaadiga
A.S. kirjutas:
Jah, kuupäev on õige, samuti näitab sert. et ta kehtib aasta lõpuni.
sõnum 03.10.2011 10:38:24 vasta tsitaadiga
Milline opsüsteem?
Kommentaarid: 742 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 560
-vodafone-
-vodafone-
sõnum 03.10.2011 10:52:57 vasta tsitaadiga
XP
sõnum 03.10.2011 12:02:18 vasta tsitaadiga
Kas sert on trusted igat pidi? Internet Options > Content > Certificates?
-vodafone-
-vodafone-
sõnum 03.10.2011 12:04:50 vasta tsitaadiga
Jah.
Andrus Luht
itimees.ee
Andrus Luht
sõnum 03.10.2011 12:09:13 vasta tsitaadiga
On see user cert sul õiges konteineris?
Kommentaarid: 377 loe/lisa Kasutajad arvavad:  :: 5 :: 1 :: 318
-vodafone-
-vodafone-
sõnum 03.10.2011 12:12:17 vasta tsitaadiga
Ta on Other user people all miskipärast ? Peabki olema? Või mida sa mõtled konteineri all.
Andrus Luht
itimees.ee
Andrus Luht
sõnum 03.10.2011 12:29:46 vasta tsitaadiga
Need võiks näha olla siin:
-vodafone-
-vodafone-
sõnum 03.10.2011 14:40:40 vasta tsitaadiga
Kuidas ma saan ta sinna. Expordin ja siis impordin sinna?
sõnum 03.10.2011 14:44:28 vasta tsitaadiga
Valid Import ja näitad sertifikaadi asukoha kätte.
-vodafone-
-vodafone-
sõnum 04.10.2011 10:49:19 vasta tsitaadiga
sõnum 04.10.2011 17:39:26 vasta tsitaadiga
Jutt on kliendi, mitte serveri sertifikaadist - sinu isiklikust sertifikaadist (õigemini selle avalikust võtmest), mis asub ID kaardi kiibi sees ja mille brauser peaks serverile esitama.
Kui seda ei juhtu, siis on võimalusi tõrkeks üsna mitmeid ja ma parem ei hakkaks kohe midagi oletama.
Kas on paigaldatud uusim ID-kaardi tarkvara installer.id.ee lehelt?
Millist antiviirust kasutad ja kas oled seda ise seadistanud? (HTTPS protokolli kontrolli ei tohi sisse lülitada, kui ID-kaardiga autentimist kasutada tahad või pead ID-autentivad lehed erandina loetlema kui mittekontrollitavad leheküljed (exceptions))
Kui on uusim ID-kaardi tarkvara, siis proovi mõne muu brauseriga (Firefox, Chrome). Olenevalt katsetuste tulemusest saab ehk natuke paremat aimu, kust viga otsima hakata.
-vodafone-
-vodafone-
sõnum 04.10.2011 20:18:44 vasta tsitaadiga
IE, Firefox, Chrome = kõik sama probleem
https://port.andmevara.ee/webcom/ak tegu selle lehega.
Kõige uuem ID utility peal, toimib. Aga lehte ei ava.
Andrus Luht
itimees.ee
Andrus Luht
sõnum 04.10.2011 20:56:08 vasta tsitaadiga
-vodafone-, tõmba omal id-kaardi utiliit käima ja registreeri oma sertifikaadid uuesti ära.
sõnum 05.10.2011 16:08:41 vasta tsitaadiga
Andrus Luht kirjutas:
Ja lisaks sellele - vastamata jäi minu küsimus antiviiruse kohta. ESET tooted ja Kaspersky ning vist ka Avast on kolm kindlat toodet mida ma tean, millega ID-kaardi kasutamise saab edukalt ära blokeerida. Tõenäoliselt on sarnaseid AV tooteid tänasel päeval juba rohkem, lihtsalt pole mul nende kohta konkreetset infot.
