uus teema   vasta Uudised »  Ülevaated, kasutajate hinnangud »  Ülevaade: Noctua NT-H1 märgi kõik teemad loetuks
K3ndu
K3ndu
sõnum 14.02.2011 18:21:18 Ülevaade: Noctua NT-H1 vasta tsitaadiga
Noctua NT-H1 on siis Noctua termopasta mis on nüüdseks juba mitu aastat väljas olnud kuid endiselt pakub peaaegu, et parimat termopastat mis saada.
Esmalt ma tänan ma Noctua't kes varustas mind selle ülevaate eksemplariga.
Noctua NT-H1
Koduleht
Spetsifikatsioonid:
  • Volume ----- 1.4ml (for at least 15 applications)
  • Specific Gravity ----- 2,49 g/cm³
  • Colour ----- grey
  • Recommended storage time (before use) ----- up to 2 years
  • Recommended usage time (on the CPU) ----- up to 3 years
  • Peak operating temperature ----- -50°C to +110°C
  • Recommended operating temperature ----- -40°C to +90°C
Veel andmeid:
  • Excellent performance
    NT-H1 consists of a hybrid compound of different micro-particles, which has been specifically optimized for use in PC environments. Thanks to its extremely low thermal resistance as well as excellent pliability and spreadability, NT-H1 achieves outstanding results.
  • Maximum ease of use & efficient dosage
    As NT-H1 spreads very well under pressure, there's no need to smear it over the heat-spreader. This reduces both the consumption of paste and the time spent on the installation process: Put one drop of NT-H1 onto the centre of your CPU, install the cooler and that's it!
  • Top-performance right from the start
    NT-H1 reaches its full performance extremely fast and doesn't require a longer "burn-in" time.
  • Excellent long-term stability
    NT-H1 doesn't contain any solvents or other substances with low flash point and provides excellent long-term stability. Due to the compound's exceptional curing, bleeding, dry-out und thermal cycling characteristics, NT-H1 can be used for several years without any problems.
  • Not electrically conductive, non-corroding
    NT-H1 possesses a very low dielectric constant and a high dielectric strength. Therefore, there's no danger of short-circuits even in case of direct contact with components or conducting paths. Fully compatible with all materials commonly employed in PC environments, NT-H1 is suited for use with aluminium and copper coolers.
  • Suitable for compressor cooling
    NT-H1 is perfectly suited for use with compressor coolers. Even at the very lowest temperatures, the paste delivers full performance and remains easy to clean off.
Pakendi sisu:
  • Noctua NT-H1
  • Karbi peal olev õpetus
Pakend:
Esmalt pakki nähes mis jääb kohe silma on kindlasti pakendi suurus, kui tavaliselt on termopastad väikestes pakendites siis Noctua termopasta pakend on äärmiselt suur. Miks ta nii suur on sellepärast, et tagaküljel on olemas kõik vajalik info mida sa teada tahad ja mida tavaliselt teiste termopastadega kaasas pole. Värvilahendusest leiame me ka Noctua tüüpilise värvilahenduse ehk pruun ja sinine mis on nii Noctua pakenditel kui ka nende kodulehel põhi värvilahenduseks.
Taga külg on kindlasti huvitavam kui eesikülg kuna siit leiame me absoluutselt kõik info mida kõike vaja teada on, kui poodi lähed ja ostad termopastat siis päris paljudel termopastadel pole üldse mingit infot kaasas, seega on Noctual siin suur eelis teiste ees kuna kui ostad poest siis näed kohe mis head ja halba tal on. Üleval pool on siis naise pilt, ei teagi mida see sümboliseerib või lihtsalt kaunistuseks. Tagant leiame veel 7. erinevas keeles väikese kirjelduse mis sellel termopastal head on.
Need pildid on siis põhimõtteliselt illustreerivad pildid sellest mis info on Veel andmed all. Ülevalt poolt sellelt pildilt näeme me veel, et on hoiatussilt, et kindlasti mitte neelata ja kui neelad sisi kindlasti pöörduda arsti juurde. Hoida lastest ja loomadest eemal ja samas ei tohiks kokku puutuda naha või silmaga, kuid nahaga tahest tahtmata puutub termopasta kokku.
Siin on siis tagakülge ülemine vasak pool kus on kirjas õpetus ja ka piltidega ära illustreeritud kuidas termopastat peale kanda, kuid minu arvates oleneb see kõik inimesest kuidas ta soovib termopastat peale kanda. All on ka kirjas, et ei pandaks liiga palju termopastat protsessorile kuna see võib hoopis temperatuure tõsta mitte langetada.
Tegemist siis spetsifikatsioonidega, alustades ülalt on kirjas, et termopastat on 1,4ml ja mida peaks jaguma kuni 15 korraks, grammides ei leia ma kuskilt mitu grammi seda pastat on, aga Googeldades leian ma, et grammides on pastat 3,5g. Välja on toodud ka erikaal, et üks kuupsentimeeter seda termopastat kaalub 2,49g. Värvuseks on hall ja soovitav säilitamisaeg on 2 aastat ja protsessori vahel 3 aastat. Soovitav temperatuuride vahe kasutada seda termopastat on -40 kuni 90 kraadi ja maksimum mis lubatud on -50 kuni 110 kraadi mis arvatavasti ei ole enam hea termopastale.
Noctua NT-H1:
Nüüd siis lähemalt termopastast endast, värviskeem on nagu ikka tüüpiline Noctua värviskeem. Peale saab teda lihtsalt kanda kuna korgimehhanism mis hoiab termopastat tuubi sees kinni on huvitav ja mida ma pole varem näinud, ehk siis nagu pildilt näha on otsas sooned sees ja korgi saab otsast lihtsalt ära keerata mille all, on siis väike avaus kust tuleb termopasta ise välja. Keeruline ei ole teda välja pigistada ja väikse lükkamise peale tulebki pasta välja. Mis mulle selle pasta juures teistest veel natuke teistsugust silma jäi oli see, et pasta on suhteliselt kuiv, kui teised pastad on ikkagi suhteliselt märjad siis see pasta on ikka päris kuiv. Samuti ka mis ta teistest erinevaks teeb on see, et Noctua lubab, kui termopasta peale kanda siis koheselt saavutab ta oma täieliku soojusjuhtivuse, näiteks Arctic Silver 5-l on sissetöötamisaeg, et esmalt pead paar päeva ootama kui termopasta enda täielikku soojusjuhtivuse saavutab. Mis mulle veel selle termopasta juures meeldib on, et ta ei juhi elektrit ja seega kui ta kuskile emaplaadi peale kukub või mis iganes siis ta ei kärsata sul emaplaat läbi või muud sellist õnnetust, kuid samas paistab olevat see omadus enamustel termopastadel. Samuti on teisel pildil ka näha, et tuub ise on päris suur, võrreldes Nexuse tuubiga, on ta päris palju suurem, grammide poolest on Noctua tuubis 3,5g ja Nexus-e tuubis ainult 1g pastat. Kuid mida ma mitte kuskilt Noctua termopasta ei leidnud oli see, et millest termopasta koosneb, nagu Nexuse tuubilt näha ja kirjas on, et pasta koosneb 30% hõbedat siis Noctua kohta ei leidnud ma midagi.
Kuumustest:
Termopastat testiti sellises arvutis:
Emaplaat: Asrock P45TS
Protsessor: Intel Core 2 Duo E7400 2.8 GHz
Jahutus: Arctic Cooling Freezer 7 Pro
RAM: A-Data 4Gb DDR2 800 mhz
Videokaart: Palit ATI Radeon HD 4670 512MB
HDD1: Seagate Barracuda 160GB ST3160811AS
HDD2: Seagate Barracuda 250GB ST3250820AS
Toiteplokk: Ez Cool 400W
Windows: Windows 7 Ultimate 32-bit
Kast: GMC J1
  • Ventilaatori pöörded on BIOS-es põhjas
  • Arvuti külje peal on 120mm ventilaator ja taga on 120mm ventilaator
  • Temperatuure mõõdan HWmonitoriga
  • LOAD test tehakse Prime 95'ga
  • IDLE temperatuur saavutatakse sellega, et arvuti seisab umbes tund aega puutumata töölaual
  • Toatemperatuur on 22 kraadi juures
Pildilt näha siis Noctua termopasta teeb Nexuse pastale ära paari kraadiga, nii IDLE's kui ka LOAD'is teeb Noctua ära kuid CORE IDLE's ja CPU LOAD's jäävad termperatuurid Nexuse pastaga samaks. Arvestades sellega, et Nexuse oma maksab peaaegu, et 3 korda vähem, siis kas on mõtet tõmmelda nende paari kraadi pärast kuid kindlasti mida kõrgemad temperatuurid seda suuremad on ka vahed. Samas on ka Nexuse tuub 1g ja Noctua tuub 3,5g nii, et kui koguse ja hinnasuhe kokku panan siis polegi Noctua kõige hullem ja jagub ka pikemaks ajaks.
Lõppsõna:
thumbs_up.gif Pole sissetöötamisaega
thumbs_up.gif Jahutab natuke paremini
thumbs_up.gif Kerge puhastada
thumbs_up.gif Kerge paigaldada
thumbs_up.gif Pikk kasutusaeg
thumbs_up.gif Hind
thumbs_down.gif Sissetöötamisaega ei saa kinnitada
thumbs_down.gif Pole müügil erinevates kogustes
Hinnaks on 6.40€ hetkel Modikompis, ja samuti Hinnavaatluses
viimati muutis K3ndu 25.02.2011 09:00:23, muudetud 7 korda
Kommentaarid: 135 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 125
Jann1
Jann1
sõnum 14.02.2011 19:17:53 vasta tsitaadiga
Ja mis siis hind oleks sellisele? Ise olen saanud nexuse pasta vist mingi 40 krooni eest.
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 5 :: 1 :: 128
Syncmahv
Syncmahv
sõnum 14.02.2011 19:25:54 vasta tsitaadiga
Endal ka see kasutusel GPU ja CPU'l. Võib nagu rahul olla. Kui vaja siis hea jahutust maha võtta.
martin366
martin366
sõnum 14.02.2011 19:28:00 vasta tsitaadiga
Kommentaarid: 185 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 172
Jann1
Jann1
sõnum 14.02.2011 19:33:45 vasta tsitaadiga
Syncmahv, Mis hinnaga ise ostsid selle? Kuna omal on kohe nexus otsas siis oleks vaja midagi kuna mõningatel asjadel vajab pasta vahetamist.
K3ndu
K3ndu
sõnum 14.02.2011 19:41:59 vasta tsitaadiga
Lisasin hinna ja poe ülevaate lõppu.
Froggy
Froggy
sõnum 14.02.2011 22:01:05 vasta tsitaadiga
Syncmahv kirjutas:
Mis mõttes hea jahutust maha võtta?
Endal pole veel õnnestunud seda pastat kasutades jahutust sedasi maha saada, et prose soketist välja ei tuleks icon_smile.gif (AM2+)
Mario.
sõnum 14.02.2011 22:07:00 vasta tsitaadiga
Tuub, mitte tuup.
Palun võrdlusmomenti LiquidPro'ga
Ei ole arvutustehnikaga täna lihtsalt kodus ja oleks tore, kui keegi pädev suudaks leida analoogse komplekti peal tsiteeritud testid ja siis võrrelda antud argumenti.
Wiltz
sõnum 14.02.2011 22:44:21 vasta tsitaadiga
kenasti loetav ülevaade küll, aga mõningad kohad vajaksid küll natuke rohkem "kahe jalaga maa peal" tõlgendamist.
N: "Pildilt näha siis Noctua termopasta teeb Nexuse pastale ära paari kraadiga, nii IDLE's kui ka LOAD'is teeb Noctua ära kuid CORE IDLE's ja CPU LOAD's jäävad termperatuurid Nexuse pastaga samaks"
tegelikkuses on pildilt näha, et pastad annavad sisuliselt täpselt sama tulemuse. asjatundlik review kirjutaja teaks juba automaatselt seda tulemust just nii tõlgendada, kuna igasugused 1 kraadised vahed tuleb nii ehk naa lugeda mõõteveaks. antud juhul on täiesti selge, et pastad annavad identse tulemuse.
ja sellele väitele "endiselt pakub peaaegu, et parimat termopastat mis saada" tahaks tõepoolest konkreetset tõestust võrdluse näol coollaboratory liquidpro'ga. isiklikult olen 200% kindel, et ükski möga baasil pasta ei suuda endiselt sellele vedelale metallile lähedale tulla.
K3ndu
K3ndu
sõnum 15.02.2011 07:13:43 vasta tsitaadiga
Wiltz kirjutas:
Ma ei hakka nüüd lademetes termopastat koju kokku ostma, et neid siin proovida kõiki. Mõõteviga mõõteveaks, aga kokkuvõtteks ju kumbki peab peale jääma ja sellisel juhul jääbki Noctua peale.
Mario.
sõnum 15.02.2011 07:17:08 vasta tsitaadiga
Et kui teisi testsubjekte võtta pole, võidab olemasolev?
No kuule. Ettevõtmine ülevaateid teha on väga tervitatav, kuid palun ole rohkem pühendunud.
Wiltz'il on hetkel tuline õigus ja alusetud argumendid panevad sinu kirjutatu objektiivsuses ning läbimõeldavuses kahtlema.
K3ndu
K3ndu
sõnum 15.02.2011 07:20:13 vasta tsitaadiga
MarioA. kirjutas:
Kontakteerusin Cool Laboratoryga, vaatame mis saab. Samas veel niipalju, et ega nende termopastadega ei ole oodatagi mingeid suuri temperatuuri erinevusi.
omgwtf
omgwtf
sõnum 15.02.2011 07:28:21 vasta tsitaadiga
Termopastal ja termopastal on vahe ikka täitsa sees nii,et erinevusi ikka jagub temperatuurides icon_wink.gif
Piipz
Piipz
sõnum 15.02.2011 07:48:16 vasta tsitaadiga
Mis te vingute, see ongi ülevaade, mitte suur termopastatest.
Kui ma teen mingist läpakast või videokaardist ülevaate, siis on ju hea, kui mõni teine on ka kõrval, kuid üldiselt vaatan toodet ennast, mitte kõiki maailma tooteid.
Kui tahate SUURT testi, siis vaadake seda:
http://benchmarkreviews.com/index.php?option=com_content&task=view&id=138&Itemid=1
Ning nagu ma arvasin (algul ehmatasin et tohoh, mingi uus turuliider), on AS5 ikkagi parem, kui see siinolev. Teisi eelolevas lingis pastasid ma lihtsalt ei teadnud.
Kommentaarid: 37 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 34
K3ndu
K3ndu
sõnum 15.02.2011 11:42:12 vasta tsitaadiga
Piip kirjutas:
EDIT: Positiivsemaid uudiseid ka, soovisite Liquid Pro-d ja lähimate nädalate jooksul peaks tulema mõlemad Cool Laboratory termopasta ülevaated
EDIT2: MX-4 ülevaade ka tulemas millalgi.
alec
alec
sõnum 15.02.2011 14:09:00 vasta tsitaadiga
Liquid metal ei ole termopasta. Teda ei saa pärast üldse ära, prosele ja jahutusele inetud plekid jäävad peale
AGa MX-4 (ja MX-2ga võrdlust) tahaks küll näha
You win again, gravity!
C-4 can make a dull day fun
there are very few problems that can't be remedied with the proper application of explosives
K3ndu
K3ndu
sõnum 15.02.2011 14:40:44 vasta tsitaadiga
alec kirjutas:
Mx2-e ülevaadet ma pakkuda ei saa, aga MX4 tuleb küll.
omgwtf
omgwtf
sõnum 15.02.2011 20:07:36 vasta tsitaadiga
alec kirjutas:
Puhastamine jah keeruline+ lisaks teatud tallaga cooleriga vist ei tohi üldse kasutada asja.
Mario.
sõnum 15.02.2011 20:14:06 vasta tsitaadiga
Jah, see vedelmetall seob ennast alumiiniumiga.
Wiltz
sõnum 15.02.2011 21:11:13 vasta tsitaadiga
ja tulemus on see, et alumiinium pudeneb pulbriks...aga esimest korda kui unustasin selle ja kogemata proovisin oli jube lahe efekt, eriti siis kui lisada suuremas koguses vett icon_lol.gif õnneks oli tegu ühe väga odava radikaga thumbs_up.gif
anyway, väga tervitatav nähtus, et tuleb coollaby kraami ülevaade, aga ma tõesti loodan, et viitsid siis teha kohe samaaegselt otsese võrdluse näiteks ühega praeguse testi pastadest ka. st. täpselt samad tingimused testimisel, et võrdlus oleks aus ja objektiivne.
PS. liquidit on väga keeruline korralikult "installeerida". soovitan küsida kohe tootjalt kaasa konkreetseid juhiseid, nõuandeid kuidas seda kõige paremini teha. kehv install võib tähendada hirmus viletsat tulemust selle pastaga.
AJ
AJ
sõnum 15.02.2011 22:04:07 vasta tsitaadiga
alec kirjutas:
Väga suurt vahet neil ei ole
Mõned MX-4'ja ülevaateid
Arctic MX-4 Thermal Paste Review
HardwareHeaven
ARCTIC COOLING MX-4 Thermal Compound Review
Madshrimps
ARCTIC MX-4 Thermal Paste Review
Vortez
Arctic Cooling MX-4 Thermal Paste Review
KitGuru
Arctic Cooling MX-4 Thermal Compound
TweakTown
K3ndu
K3ndu
sõnum 16.02.2011 07:43:41 vasta tsitaadiga
Wiltz kirjutas:
Eks ma üritan teha võimalikult ausad ja täpsed tulemused, võrdlus tuleb kindlasti temperatuuride osas.
Miki-Hiir
sõnum 16.02.2011 08:24:34 vasta tsitaadiga
Seda Arctic Cooling MX-4 30g tuubi Eestis kuskilt saada ka on?
Kommentaarid: 46 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 43
martin366
martin366
sõnum 16.02.2011 08:28:45 vasta tsitaadiga
Miki-Hiir kirjutas:
Ei leia küll. Isegi 4g on ulme hinnaga.
Ise eelistaks MX-2, kuna nagunii nende vahe nii väike (aga hinnavahe suur). http://www.ordi.ee/EPood/Product.aspx?Query=mx-2&ItemID=2100-1550&MC=KOMP&IC=2100 thumbs_up.gif
Mario.
sõnum 16.02.2011 09:59:48 vasta tsitaadiga
K3ndu kirjutas:
Wiltz kirjutas:
Jäta ta viimaseks subjektiks ning ennem hari, kuidas seda kõige paremini maha saab ( icon_lol.gif - üsna nu--, kui aus olla, aga kui on korralik jahutus, siis enne protsessori vahetamist naljalt kiskuda pole vajagi )
Wiltz
sõnum 16.02.2011 18:27:42 vasta tsitaadiga
no minul on aidanud tavaliselt liivapaber thumbs_up.gif kuid jah, see on väga-väga õige tähelepanek, et tasuks viimaseks subjektiks jätta. muidugi samamoodi tuleks ka pöörata tõsiselt tähelepanu sellele, et üldse iga pasta vahetuse ajal ikkagi eelnev kraam väga korralikult mõlemalt pinnalt eemaldada. aga eriti kehtib see ilmselt pasta kohta, mis on peal enne liquidpro testimist. muidu lihtsalt võib tulemus tulla palju kehvem kui see ideaalis olla võiks.
K3ndu
K3ndu
sõnum 23.02.2011 07:59:43 vasta tsitaadiga
Tänud soovituste eest, võtan arvesse ja proovin ja katsetan.
EDIT:Coollaboratory termopastad on siin ja ülevaated on paari päeva pärast ülal, Ultra ja Pro mõlemad.
aunus
Aeg maha 1p
sõnum 24.02.2011 08:54:18 vasta tsitaadiga
Mõttetu raha raiskamine. Ise olen siiani hakkama saanud ilma pastata ja jahutab ka normaalselt ilma pastata. Võibolla 3-4kraadi kõrgem on aga mis suur asi see ikka on. Võibolla tavaarvutitele on see hea jah aga läptopidel ongi juba niigi jahedad prosed ja ei kuumene eriti. Sellepärast pole ka läpakatel seda pastat väga vaja.
Jann1
Jann1
sõnum 24.02.2011 10:08:01 vasta tsitaadiga
aunus kirjutas:
Küsin kohe otse. Debiilik oled või?
aunus
Aeg maha 1p
sõnum 24.02.2011 11:02:25 vasta tsitaadiga
Ise oled kui selliseid asju küsid. Sest mis sa arvad, et debiilik ise teab, et ta debiil on?
Jann1
Jann1
sõnum 24.02.2011 11:05:41 vasta tsitaadiga
Ma tõesti loodan, et su läpakal põleb prose ära. Ning ära aja teemas sellist juttu, et pole pastat üldse vaja.
Mine tee omale lollijutu teema j vatra seal oma lolli loba!
aunus
Aeg maha 1p
sõnum 24.02.2011 11:40:38 vasta tsitaadiga
Kahju, et sulle negatiivset panna ei saa.
Flacko
Joonistusmaniakk!
Flacko
sõnum 24.02.2011 11:44:49 vasta tsitaadiga
Ega ilma äritehinguta ei tohikski imo panna kommentaare. just lugesin et need on äride jaoks, mitte mingite lahmimiste või "ohh mul on sitt tuju, paneme talle ühe nega ära" kommid.
Flacko, the nutty weasel who loves blue cheese, Blyth's Reed Warblers, Thrush Nightingales and Devin Townsend!
viimati muutis Flacko 24.02.2011 11:45:35, muudetud 1 kord
Kommentaarid: 199 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 166
K3ndu
K3ndu
sõnum 24.02.2011 11:45:02 vasta tsitaadiga
Lol aunusel juba AM 30 ka, igastahes tõesti väga puusse postitused, et pole vaja jne. Pro ja Ultra ülevaade tuleb koos ja homme on ülevaade ülal.
martin366
martin366
sõnum 24.02.2011 12:53:12 vasta tsitaadiga
paxo
paxo
sõnum 12.10.2011 10:50:30 vasta tsitaadiga
Mõtlesin ka kunagi erinevaid termopastasi testima hakata aga kadus huvi ära.
Aga jõudsin testida seda sama termopastat ja sellist 1€ http://www.ebay.com/itm/30g-Thermal-Grease-Paste-Compound-PC-CPU-Heatsink-Tube-/370366570705?pt=LH_DefaultDomain_0&hash=item563b9160d1 ja see odav hiina pasteet oli oma 3-5 kraadi jahedam kui Noctua icon_lol.gif . Testisin neid mõlemat E8400 peal ja Kandsin õhukese kihina nad protsessorile. Sellise 30g sured ennem maha kui otsa saab. icon_lol.gif . Samas võibolla oleneb ka protsessoritest aga E8400 puhul oli see odav hiina jama parem. Vaatan kui mingi aeg viitsin lauaka tööle ajada siis saab täpsemad numbrid idle ja full loadi kohta.
johhu12
johhu12
sõnum 16.10.2011 12:06:01 vasta tsitaadiga
Aitähh hea ülevaate eest, aga sooviks kah võrdlust Artic MX-4-ga ja Artic Silver 5-ga.
K3ndu
K3ndu
sõnum 16.10.2011 13:02:43 vasta tsitaadiga
johhu12 kirjutas:
Mul on seda termopastat kodus juba niipalju, et ma ei hakka MX-4 ja AS5'te veel juurde ostma testimiseks. Kuid nagu ka tulemused näitavad on nad enamus samasse auku va vedelmetall termopastad.
Parem kannata, sest lähiajal tuleb AC 13 Freezer ülevaade ja mis annab suurema temperatuurivahe kui mingi termopasta.
