K3ndu
14.02.2011 18:21:18
Ülevaade: Noctua NT-H1 |
Noctua NT-H1 on siis Noctua termopasta mis on nüüdseks juba mitu aastat väljas olnud kuid endiselt pakub peaaegu, et parimat termopastat mis saada.
Esmalt ma tänan ma Noctua't kes varustas mind selle ülevaate eksemplariga.
Noctua NT-H1
Koduleht
Spetsifikatsioonid:
- Volume ----- 1.4ml (for at least 15 applications)
- Specific Gravity ----- 2,49 g/cm³
- Colour ----- grey
- Recommended storage time (before use) ----- up to 2 years
- Recommended usage time (on the CPU) ----- up to 3 years
- Peak operating temperature ----- -50°C to +110°C
- Recommended operating temperature ----- -40°C to +90°C
Veel andmeid:
- Excellent performance
NT-H1 consists of a hybrid compound of different micro-particles, which has been specifically optimized for use in PC environments. Thanks to its extremely low thermal resistance as well as excellent pliability and spreadability, NT-H1 achieves outstanding results.
- Maximum ease of use & efficient dosage
As NT-H1 spreads very well under pressure, there's no need to smear it over the heat-spreader. This reduces both the consumption of paste and the time spent on the installation process: Put one drop of NT-H1 onto the centre of your CPU, install the cooler and that's it!
- Top-performance right from the start
NT-H1 reaches its full performance extremely fast and doesn't require a longer "burn-in" time.
- Excellent long-term stability
NT-H1 doesn't contain any solvents or other substances with low flash point and provides excellent long-term stability. Due to the compound's exceptional curing, bleeding, dry-out und thermal cycling characteristics, NT-H1 can be used for several years without any problems.
- Not electrically conductive, non-corroding
NT-H1 possesses a very low dielectric constant and a high dielectric strength. Therefore, there's no danger of short-circuits even in case of direct contact with components or conducting paths. Fully compatible with all materials commonly employed in PC environments, NT-H1 is suited for use with aluminium and copper coolers.
- Suitable for compressor cooling
NT-H1 is perfectly suited for use with compressor coolers. Even at the very lowest temperatures, the paste delivers full performance and remains easy to clean off.
Pakendi sisu:
- Noctua NT-H1
- Karbi peal olev õpetus
Pakend:
Esmalt pakki nähes mis jääb kohe silma on kindlasti pakendi suurus, kui tavaliselt on termopastad väikestes pakendites siis Noctua termopasta pakend on äärmiselt suur. Miks ta nii suur on sellepärast, et tagaküljel on olemas kõik vajalik info mida sa teada tahad ja mida tavaliselt teiste termopastadega kaasas pole. Värvilahendusest leiame me ka Noctua tüüpilise värvilahenduse ehk pruun ja sinine mis on nii Noctua pakenditel kui ka nende kodulehel põhi värvilahenduseks.
Taga külg on kindlasti huvitavam kui eesikülg kuna siit leiame me absoluutselt kõik info mida kõike vaja teada on, kui poodi lähed ja ostad termopastat siis päris paljudel termopastadel pole üldse mingit infot kaasas, seega on Noctual siin suur eelis teiste ees kuna kui ostad poest siis näed kohe mis head ja halba tal on. Üleval pool on siis naise pilt, ei teagi mida see sümboliseerib või lihtsalt kaunistuseks. Tagant leiame veel 7. erinevas keeles väikese kirjelduse mis sellel termopastal head on.
Need pildid on siis põhimõtteliselt illustreerivad pildid sellest mis info on Veel andmed all. Ülevalt poolt sellelt pildilt näeme me veel, et on hoiatussilt, et kindlasti mitte neelata ja kui neelad sisi kindlasti pöörduda arsti juurde. Hoida lastest ja loomadest eemal ja samas ei tohiks kokku puutuda naha või silmaga, kuid nahaga tahest tahtmata puutub termopasta kokku.
Siin on siis tagakülge ülemine vasak pool kus on kirjas õpetus ja ka piltidega ära illustreeritud kuidas termopastat peale kanda, kuid minu arvates oleneb see kõik inimesest kuidas ta soovib termopastat peale kanda. All on ka kirjas, et ei pandaks liiga palju termopastat protsessorile kuna see võib hoopis temperatuure tõsta mitte langetada.
Tegemist siis spetsifikatsioonidega, alustades ülalt on kirjas, et termopastat on 1,4ml ja mida peaks jaguma kuni 15 korraks, grammides ei leia ma kuskilt mitu grammi seda pastat on, aga Googeldades leian ma, et grammides on pastat 3,5g. Välja on toodud ka erikaal, et üks kuupsentimeeter seda termopastat kaalub 2,49g. Värvuseks on hall ja soovitav säilitamisaeg on 2 aastat ja protsessori vahel 3 aastat. Soovitav temperatuuride vahe kasutada seda termopastat on -40 kuni 90 kraadi ja maksimum mis lubatud on -50 kuni 110 kraadi mis arvatavasti ei ole enam hea termopastale.
Noctua NT-H1:
Nüüd siis lähemalt termopastast endast, värviskeem on nagu ikka tüüpiline Noctua värviskeem. Peale saab teda lihtsalt kanda kuna korgimehhanism mis hoiab termopastat tuubi sees kinni on huvitav ja mida ma pole varem näinud, ehk siis nagu pildilt näha on otsas sooned sees ja korgi saab otsast lihtsalt ära keerata mille all, on siis väike avaus kust tuleb termopasta ise välja. Keeruline ei ole teda välja pigistada ja väikse lükkamise peale tulebki pasta välja. Mis mulle selle pasta juures teistest veel natuke teistsugust silma jäi oli see, et pasta on suhteliselt kuiv, kui teised pastad on ikkagi suhteliselt märjad siis see pasta on ikka päris kuiv. Samuti ka mis ta teistest erinevaks teeb on see, et Noctua lubab, kui termopasta peale kanda siis koheselt saavutab ta oma täieliku soojusjuhtivuse, näiteks Arctic Silver 5-l on sissetöötamisaeg, et esmalt pead paar päeva ootama kui termopasta enda täielikku soojusjuhtivuse saavutab. Mis mulle veel selle termopasta juures meeldib on, et ta ei juhi elektrit ja seega kui ta kuskile emaplaadi peale kukub või mis iganes siis ta ei kärsata sul emaplaat läbi või muud sellist õnnetust, kuid samas paistab olevat see omadus enamustel termopastadel. Samuti on teisel pildil ka näha, et tuub ise on päris suur, võrreldes Nexuse tuubiga, on ta päris palju suurem, grammide poolest on Noctua tuubis 3,5g ja Nexus-e tuubis ainult 1g pastat. Kuid mida ma mitte kuskilt Noctua termopasta ei leidnud oli see, et millest termopasta koosneb, nagu Nexuse tuubilt näha ja kirjas on, et pasta koosneb 30% hõbedat siis Noctua kohta ei leidnud ma midagi.
Kuumustest:
Termopastat testiti sellises arvutis:
Emaplaat: Asrock P45TS
Protsessor: Intel Core 2 Duo E7400 2.8 GHz
Jahutus: Arctic Cooling Freezer 7 Pro
RAM: A-Data 4Gb DDR2 800 mhz
Videokaart: Palit ATI Radeon HD 4670 512MB
HDD1: Seagate Barracuda 160GB ST3160811AS
HDD2: Seagate Barracuda 250GB ST3250820AS
Toiteplokk: Ez Cool 400W
Windows: Windows 7 Ultimate 32-bit
Kast: GMC J1
- Ventilaatori pöörded on BIOS-es põhjas
- Arvuti külje peal on 120mm ventilaator ja taga on 120mm ventilaator
- Temperatuure mõõdan HWmonitoriga
- LOAD test tehakse Prime 95'ga
- IDLE temperatuur saavutatakse sellega, et arvuti seisab umbes tund aega puutumata töölaual
- Toatemperatuur on 22 kraadi juures
Pildilt näha siis Noctua termopasta teeb Nexuse pastale ära paari kraadiga, nii IDLE's kui ka LOAD'is teeb Noctua ära kuid CORE IDLE's ja CPU LOAD's jäävad termperatuurid Nexuse pastaga samaks. Arvestades sellega, et Nexuse oma maksab peaaegu, et 3 korda vähem, siis kas on mõtet tõmmelda nende paari kraadi pärast kuid kindlasti mida kõrgemad temperatuurid seda suuremad on ka vahed. Samas on ka Nexuse tuub 1g ja Noctua tuub 3,5g nii, et kui koguse ja hinnasuhe kokku panan siis polegi Noctua kõige hullem ja jagub ka pikemaks ajaks.
Lõppsõna:
Pole sissetöötamisaega
Jahutab natuke paremini
Kerge puhastada
Kerge paigaldada
Pikk kasutusaeg
Sissetöötamisaega ei saa kinnitada
Pole müügil erinevates kogustes
Hinnaks on 6.40€ hetkel Modikompis, ja samuti Hinnavaatluses
viimati muutis K3ndu 25.02.2011 09:00:23, muudetud 7 korda |
| Kommentaarid: 135 loe/lisa |
125 |
Jann1
14.02.2011 19:17:53
| Ja mis siis hind oleks sellisele? Ise olen saanud nexuse pasta vist mingi 40 krooni eest.
128 |
Syncmahv
14.02.2011 19:25:54
| Endal ka see kasutusel GPU ja CPU'l. Võib nagu rahul olla. Kui vaja siis hea jahutust maha võtta.
102 |
martin366
14.02.2011 19:28:00
Võrdlust 5.80€ maksva Arctic Cooling MX-2-ga ?
172 |
Jann1
14.02.2011 19:33:45
| Syncmahv, Mis hinnaga ise ostsid selle? Kuna omal on kohe nexus otsas siis oleks vaja midagi kuna mõningatel asjadel vajab pasta vahetamist.
128 |
K3ndu
14.02.2011 19:41:59
| Lisasin hinna ja poe ülevaate lõppu.
125 |
Froggy
14.02.2011 22:01:05
| Syncmahv kirjutas: |
| Endal ka see kasutusel GPU ja CPU'l. Võib nagu rahul olla. Kui vaja siis hea jahutust maha võtta. |
Mis mõttes hea jahutust maha võtta?
Endal pole veel õnnestunud seda pastat kasutades jahutust sedasi maha saada, et prose soketist välja ei tuleks (AM2+)
Aga muidu hea pasta
| Kommentaarid: 29 loe/lisa |
Mario.
14.02.2011 22:07:00
Tuub, mitte tuup.
Palun võrdlusmomenti LiquidPro'ga
Ei ole arvutustehnikaga täna lihtsalt kodus ja oleks tore, kui keegi pädev suudaks leida analoogse komplekti peal tsiteeritud testid ja siis võrrelda antud argumenti.
6 :: |
217 |
Wiltz
14.02.2011 22:44:21
kenasti loetav ülevaade küll, aga mõningad kohad vajaksid küll natuke rohkem "kahe jalaga maa peal" tõlgendamist.
N: "Pildilt näha siis Noctua termopasta teeb Nexuse pastale ära paari kraadiga, nii IDLE's kui ka LOAD'is teeb Noctua ära kuid CORE IDLE's ja CPU LOAD's jäävad termperatuurid Nexuse pastaga samaks"
tegelikkuses on pildilt näha, et pastad annavad sisuliselt täpselt sama tulemuse. asjatundlik review kirjutaja teaks juba automaatselt seda tulemust just nii tõlgendada, kuna igasugused 1 kraadised vahed tuleb nii ehk naa lugeda mõõteveaks. antud juhul on täiesti selge, et pastad annavad identse tulemuse.
ja sellele väitele "endiselt pakub peaaegu, et parimat termopastat mis saada" tahaks tõepoolest konkreetset tõestust võrdluse näol coollaboratory liquidpro'ga. isiklikult olen 200% kindel, et ükski möga baasil pasta ei suuda endiselt sellele vedelale metallile lähedale tulla.
9 :: |
226 |
K3ndu
15.02.2011 07:13:43
| Wiltz kirjutas: |
ja sellele väitele "endiselt pakub peaaegu, et parimat termopastat mis saada" tahaks tõepoolest konkreetset tõestust võrdluse näol coollaboratory liquidpro'ga. isiklikult olen 200% kindel, et ükski möga baasil pasta ei suuda endiselt sellele vedelale metallile lähedale tulla. |
Ma ei hakka nüüd lademetes termopastat koju kokku ostma, et neid siin proovida kõiki. Mõõteviga mõõteveaks, aga kokkuvõtteks ju kumbki peab peale jääma ja sellisel juhul jääbki Noctua peale.
125 |
Mario.
15.02.2011 07:17:08
Et kui teisi testsubjekte võtta pole, võidab olemasolev?
No kuule. Ettevõtmine ülevaateid teha on väga tervitatav, kuid palun ole rohkem pühendunud.
Wiltz'il on hetkel tuline õigus ja alusetud argumendid panevad sinu kirjutatu objektiivsuses ning läbimõeldavuses kahtlema.
6 :: |
217 |
K3ndu
15.02.2011 07:20:13
| MarioA. kirjutas: |
Wiltz'il on hetkel tuline õigus ja alusetud argumendid panevad sinu kirjutatu objektiivsuses ning läbimõeldavuses kahtlema. |
Kontakteerusin Cool Laboratoryga, vaatame mis saab. Samas veel niipalju, et ega nende termopastadega ei ole oodatagi mingeid suuri temperatuuri erinevusi.
125 |
omgwtf
15.02.2011 07:28:21
Termopastal ja termopastal on vahe ikka täitsa sees nii,et erinevusi ikka jagub temperatuurides
137 |
Piipz
15.02.2011 07:48:16
Mis te vingute, see ongi ülevaade, mitte suur termopastatest.
Kui ma teen mingist läpakast või videokaardist ülevaate, siis on ju hea, kui mõni teine on ka kõrval, kuid üldiselt vaatan toodet ennast, mitte kõiki maailma tooteid.
Kui tahate SUURT testi, siis vaadake seda:
http://benchmarkreviews.com/index.php?option=com_content&task=view&id=138&Itemid=1
Ning nagu ma arvasin (algul ehmatasin et tohoh, mingi uus turuliider), on AS5 ikkagi parem, kui see siinolev. Teisi eelolevas lingis pastasid ma lihtsalt ei teadnud.
| Kommentaarid: 37 loe/lisa |
34 |
K3ndu
15.02.2011 11:42:12
| Piip kirjutas: |
Ning nagu ma arvasin (algul ehmatasin et tohoh, mingi uus turuliider), on AS5 ikkagi parem, kui see siinolev. Teisi eelolevas lingis pastasid ma lihtsalt ei teadnud. |
EDIT: Positiivsemaid uudiseid ka, soovisite Liquid Pro-d ja lähimate nädalate jooksul peaks tulema mõlemad Cool Laboratory termopasta ülevaated
EDIT2: MX-4 ülevaade ka tulemas millalgi.
125 |
alec
15.02.2011 14:09:00
Liquid metal ei ole termopasta. Teda ei saa pärast üldse ära, prosele ja jahutusele inetud plekid jäävad peale
AGa MX-4 (ja MX-2ga võrdlust) tahaks küll näha
_________________ You win again, gravity!
C-4 can make a dull day fun
there are very few problems that can't be remedied with the proper application of explosives |
| Kommentaarid: 23 loe/lisa |
22 |
K3ndu
15.02.2011 14:40:44
| alec kirjutas: |
AGa MX-4 (ja MX-2ga võrdlust) tahaks küll näha |
Mx2-e ülevaadet ma pakkuda ei saa, aga MX4 tuleb küll.
125 |
omgwtf
15.02.2011 20:07:36
| alec kirjutas: |
Puhastamine jah keeruline+ lisaks teatud tallaga cooleriga vist ei tohi üldse kasutada asja.
137 |
Mario.
15.02.2011 20:14:06
| Jah, see vedelmetall seob ennast alumiiniumiga.
6 :: |
217 |
Wiltz
15.02.2011 21:11:13
ja tulemus on see, et alumiinium pudeneb pulbriks...aga esimest korda kui unustasin selle ja kogemata proovisin oli jube lahe efekt, eriti siis kui lisada suuremas koguses vett õnneks oli tegu ühe väga odava radikaga
anyway, väga tervitatav nähtus, et tuleb coollaby kraami ülevaade, aga ma tõesti loodan, et viitsid siis teha kohe samaaegselt otsese võrdluse näiteks ühega praeguse testi pastadest ka. st. täpselt samad tingimused testimisel, et võrdlus oleks aus ja objektiivne.
PS. liquidit on väga keeruline korralikult "installeerida". soovitan küsida kohe tootjalt kaasa konkreetseid juhiseid, nõuandeid kuidas seda kõige paremini teha. kehv install võib tähendada hirmus viletsat tulemust selle pastaga.
9 :: |
226 |
AJ
15.02.2011 22:04:07
| alec kirjutas: |
Väga suurt vahet neil ei ole
Mõned MX-4'ja ülevaateid
Arctic MX-4 Thermal Paste Review
HardwareHeaven
ARCTIC COOLING MX-4 Thermal Compound Review
Madshrimps
ARCTIC MX-4 Thermal Paste Review
Vortez
Arctic Cooling MX-4 Thermal Paste Review
KitGuru
Arctic Cooling MX-4 Thermal Compound
TweakTown
36 |
K3ndu
16.02.2011 07:43:41
| Wiltz kirjutas: |
PS. liquidit on väga keeruline korralikult "installeerida". soovitan küsida kohe tootjalt kaasa konkreetseid juhiseid, nõuandeid kuidas seda kõige paremini teha. kehv install võib tähendada hirmus viletsat tulemust selle pastaga. |
Eks ma üritan teha võimalikult ausad ja täpsed tulemused, võrdlus tuleb kindlasti temperatuuride osas.
125 |
Miki-Hiir
16.02.2011 08:24:34
| Seda Arctic Cooling MX-4 30g tuubi Eestis kuskilt saada ka on?
| Kommentaarid: 46 loe/lisa |
43 |
martin366
172 |
Mario.
16.02.2011 09:59:48
| K3ndu kirjutas: |
| Wiltz kirjutas: |
Eks ma üritan teha võimalikult ausad ja täpsed tulemused, võrdlus tuleb kindlasti temperatuuride osas. |
Jäta ta viimaseks subjektiks ning ennem hari, kuidas seda kõige paremini maha saab ( - üsna nu--, kui aus olla, aga kui on korralik jahutus, siis enne protsessori vahetamist naljalt kiskuda pole vajagi )
6 :: |
217 |
Wiltz
16.02.2011 18:27:42
no minul on aidanud tavaliselt liivapaber kuid jah, see on väga-väga õige tähelepanek, et tasuks viimaseks subjektiks jätta. muidugi samamoodi tuleks ka pöörata tõsiselt tähelepanu sellele, et üldse iga pasta vahetuse ajal ikkagi eelnev kraam väga korralikult mõlemalt pinnalt eemaldada. aga eriti kehtib see ilmselt pasta kohta, mis on peal enne liquidpro testimist. muidu lihtsalt võib tulemus tulla palju kehvem kui see ideaalis olla võiks.
9 :: |
226 |
K3ndu
23.02.2011 07:59:43
Tänud soovituste eest, võtan arvesse ja proovin ja katsetan.
EDIT:Coollaboratory termopastad on siin ja ülevaated on paari päeva pärast ülal, Ultra ja Pro mõlemad.
125 |
aunus
Aeg maha 1p
24.02.2011 08:54:18
| Mõttetu raha raiskamine. Ise olen siiani hakkama saanud ilma pastata ja jahutab ka normaalselt ilma pastata. Võibolla 3-4kraadi kõrgem on aga mis suur asi see ikka on. Võibolla tavaarvutitele on see hea jah aga läptopidel ongi juba niigi jahedad prosed ja ei kuumene eriti. Sellepärast pole ka läpakatel seda pastat väga vaja.
Jann1
24.02.2011 10:08:01
| aunus kirjutas: |
| Mõttetu raha raiskamine. Ise olen siiani hakkama saanud ilma pastata ja jahutab ka normaalselt ilma pastata. Võibolla 3-4kraadi kõrgem on aga mis suur asi see ikka on. Võibolla tavaarvutitele on see hea jah aga läptopidel ongi juba niigi jahedad prosed ja ei kuumene eriti. Sellepärast pole ka läpakatel seda pastat väga vaja. |
Küsin kohe otse. Debiilik oled või?
128 |
aunus
Aeg maha 1p
24.02.2011 11:02:25
| Ise oled kui selliseid asju küsid. Sest mis sa arvad, et debiilik ise teab, et ta debiil on?
Jann1
24.02.2011 11:05:41
Ma tõesti loodan, et su läpakal põleb prose ära. Ning ära aja teemas sellist juttu, et pole pastat üldse vaja.
Mine tee omale lollijutu teema j vatra seal oma lolli loba!
128 |
aunus
Aeg maha 1p
24.02.2011 11:40:38
Haters gonna hate.
Kahju, et sulle negatiivset panna ei saa.
Flacko
Joonistusmaniakk!
24.02.2011 11:44:49
Ega ilma äritehinguta ei tohikski imo panna kommentaare. just lugesin et need on äride jaoks, mitte mingite lahmimiste või "ohh mul on sitt tuju, paneme talle ühe nega ära" kommid.
_________________ Flacko, the nutty weasel who loves blue cheese, Blyth's Reed Warblers, Thrush Nightingales and Devin Townsend!
viimati muutis Flacko 24.02.2011 11:45:35, muudetud 1 kord |
| Kommentaarid: 199 loe/lisa |
166 |
K3ndu
24.02.2011 11:45:02
| Lol aunusel juba AM 30 ka, igastahes tõesti väga puusse postitused, et pole vaja jne. Pro ja Ultra ülevaade tuleb koos ja homme on ülevaade ülal.
125 |
martin366
24.02.2011 12:53:12
K3ndu, tubli, et viitsid tegeleda
172 |
paxo
johhu12
16.10.2011 12:06:01
| Aitähh hea ülevaate eest, aga sooviks kah võrdlust Artic MX-4-ga ja Artic Silver 5-ga.
| Kommentaarid: 21 loe/lisa |
20 |
K3ndu
16.10.2011 13:02:43
| johhu12 kirjutas: |
| Aitähh hea ülevaate eest, aga sooviks kah võrdlust Artic MX-4-ga ja Artic Silver 5-ga. |
Mul on seda termopastat kodus juba niipalju, et ma ei hakka MX-4 ja AS5'te veel juurde ostma testimiseks. Kuid nagu ka tulemused näitavad on nad enamus samasse auku va vedelmetall termopastad.
Parem kannata, sest lähiajal tuleb AC 13 Freezer ülevaade ja mis annab suurema temperatuurivahe kui mingi termopasta.
125 |
