Liivaannus
19.06.2011 11:57:21
Väga pikk explorerininttime 206643 |
Masin buudib kole kaua, hakkasin asja uurima jõudsin selleni, et üks suurimaid venitajaid on explorer init time
BootTsVersion 2
BootStartTime 2011-06-19T08:06:41.671600300Z
BootEndTime 2011-06-19T08:11:53.966038000Z
SystemBootInstance 360
UserBootInstance 328
BootTime 309736
MainPathBootTime 235208
BootKernelInitTime 17
BootDriverInitTime 1911
BootDevicesInitTime 3553
BootPrefetchInitTime 32569
BootPrefetchBytes 232148992
BootAutoChkTime 0
BootSmssInitTime 9915
BootCriticalServicesInitTime 4594
BootUserProfileProcessingTime 2331
BootMachineProfileProcessingTime 4532
BootExplorerInitTime 206643
BootNumStartupApps 17
BootPostBootTime 74528
BootIsRebootAfterInstall false
BootRootCauseStepImprovementBits 512
BootRootCauseGradualImprovementBits 0
BootRootCauseStepDegradationBits 0
BootRootCauseGradualDegradationBits 0
BootIsDegradation false
BootIsStepDegradation false
BootIsGradualDegradation false
BootImprovementDelta 0
BootDegradationDelta 0
BootIsRootCauseIdentified true
OSLoaderDuration 3019
BootPNPInitStartTimeMS 17
BootPNPInitDuration 4568
OtherKernelInitDuration 2139
SystemPNPInitStartTimeMS 6531
SystemPNPInitDuration 897
SessionInitStartTimeMS 7604
Session0InitDuration 1916
Session1InitDuration 1406
SessionInitOtherDuration 6591
WinLogonStartTimeMS 17519
OtherLogonInitActivityDuration 4181
UserLogonWaitDuration 2558
Siia siis süsteemi riistvara informatsioon
OS Name Microsoft Windows 7 Professional
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name ****
System Manufacturer System manufacturer
System Model P5QL PRO
System Type x64-based PC
Processor Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz, 3003 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 0414, 25.07.2008
SMBIOS Version 2.5
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale Eesti
Hardware Abstraction Layer Version = "6.1.7601.17514"
User Name *******
Time Zone FLE Daylight Time
Installed Physical Memory (RAM) 4,00 GB
Total Physical Memory 4,00 GB
Available Physical Memory 1,73 GB
Total Virtual Memory 8,00 GB
Available Virtual Memory 5,44 GB
Page File Space 4,00 GB
Page File C:\pagefile.sys
Äkki oskate öelda, mis seda pikka booti põhjustada võiks. Visuaalselt on see pikk must ekraan peale logoni, kiirendada saab explorerit killides ja uuesti käivitades task managerist, kuid see pole päris OK lahendus mu jaoks. Enne kui see probleem tekkis veetis masin pikalt aega võrku otsides, sai pildi küll kiiresti ette, kuid näitas pikalt võrgu otsimist oma sinise ringiga seal ühenduse ikooni peal. Ruuter on thomsoni tg784. Kasutan ka fikseeritud kohtvõrgu IP d, kuna pole suutnud leida teist moodust, kuidas ruuter suudaks mu masinat tuvastada, MAC iga sidumine ei õnnestunud. Rohkem hetkel seonduvat informatsiooni pähe ei karga, kui on täpsustusi vaja küsige.
| Kommentaarid: 92 loe/lisa |
Liivaannus
27.06.2011 22:19:28
Peale Ms configu näppimist ja ccleaneriga üle käimist sain asja suts kiiremaks, kuid mitte normaalseks. Teise accounti puhul toimib asi analoogselt. Muutusd tekkis ainult nii palju, et enam pole must pilt vaid käivitab ilusti 3 nda osapoole tarkvara, kuid MS i oma asjad kuidagi lagivad. Võrguühenduse ikooni peal on see kahtlane sinine ring nagu mõtleks ja action center jõuab kisada, et viirusetõrje ei tule üles. Peale paari minutilist jama kaob see sinine ring ja tuleb ka viirusetõrje ilusti üles.
Ühesõnaga veits läks paremaks, kuid mitte piisavalt. Proovin veel Safemodei.
Edit:
Enne kui ta selle sinise rõnga minema saab on Taskmgr i järgi pikk idle, cpu 0-1%. Mingil hetkel aga kaob taskmgr nagu backgroundi vms, näha on ilusti aga kõlab see "kõll" helin kui miskit muuta tahad ja ei lase muuta, nagu oleks mingi veateade esiplaanile tulnud, kuid füüsiliselt sellist asja näha ei ole. Ja pealtnäha lambist hakkab masin äkki lammutama ja kõik normaliseerub. Kokku võtab trall peale logoni aega vast paar minutit. Vahemärkusena võin lisada, et peale logoni läheb digsby IM klient mürts üles ja ühendab ilma probleemideta.
Liivaannus
30.06.2011 19:27:51
| Nuh Reinstalli soovitavad paljud, aga see on loogika vastane lihtsalt, krt asju peab saama korda teha. Peale puhastamist läks olukord veits paremaks, et on enamvähem talutav, seega jätkan otsinguid lahenduse osas vaikselt, kui kopa ette viskab lasen uue peale.
01.07.2011 08:04:59
| Liivaannus kirjutas: |
| see on loogika vastane lihtsalt, krt asju peab saama korda teha. |
Üldjuhul olen ma viimane inimene kes reinstalli soovitab aga omast kogemusest - vahel tõesti on see ainus valik.Näiteks eelmise installiga oli mul probleem, kus VLC mõtles 5-10 sekundit pärast selle sulgemist enne kui akna kinni viskas.Äärmiselt häiriv oli ja ma kulutasin tunde, et seda viga virtuaalmasinas sama tarkvaraga taasluua aga lõpuks andsin alla.Kui aeg kätte jõudis ja uue installi tegin, siis nüüd uuel see viga puudub.
Ühtlasi võib veel proovida käsurealt jooksutada:
See kontrollib üle ja parandab võimalikud vead mis see leiab.Igaks juhuks ütlen ka, et see võtab tagasi muudatused mis OS failidesse on tehtud.Üldiselt ei tohiks see probleem olla kui minggeid custom teemasid ja kraami ei jooksutada mis OS faile muudavad.
sfc /?
Microsoft (R) Windows (R) Resource Checker Version 6.0
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
Scans the integrity of all protected system files and replaces incorrect versions with
correct Microsoft versions.
SFC [/SCANNOW] [/VERIFYONLY] [/SCANFILE=<file>] [/VERIFYFILE=<file>]
[/OFFWINDIR=<offline windows directory> /OFFBOOTDIR=<offline boot directory>]
/SCANNOW Scans integrity of all protected system files and repairs files with
problems when possible.
/VERIFYONLY Scans integrity of all protected system files. No repair operation is
performed.
/SCANFILE Scans integrity of the referenced file, repairs file if problems are
identified. Specify full path <file>
/VERIFYFILE Verifies the integrity of the file with full path <file>. No repair
operation is performed.
/OFFBOOTDIR For offline repair specify the location of the offline boot directory
/OFFWINDIR For offline repair specify the location of the offline windows directory
e.g.
sfc /SCANNOW
sfc /VERIFYFILE=c:\windows\system32\kernel32.dll
sfc /SCANFILE=d:\windows\system32\kernel32.dll /OFFBOOTDIR=d:\ /OFFWINDIR=d:\windows
sfc /VERIFYONLY |
Liivaannus
01.07.2011 19:41:43
Proovin selle skänni ära ja annan tulemustest teada. Kasutan ainult Akrapovici themei välimuse jaoks, muid suuremaid muutusi pole süsteemis küll teinud.
Edit: Ei leidnud midagi viga olevat.
Noname
01.07.2011 20:01:03
| tomorrow kirjutas: |
Kahtlustan, et OS hapuks läinud  |
Loll jutt. OS ei lähe hapuks. Lase masin üle Combofixiga, tdss killeriga, cleaneriga, spybotiga ja nod32-ga.
tee chkdsk /r.
322 |
Märt.
01.07.2011 20:41:39
Noname, imelik jutt Gurult. Miks OS ei või hapuks minna? Mille vastu küll Ccleaner on? Miks tasuline NOD32, kui on olemas tasuta MSE?
| Kommentaarid: 29 loe/lisa |
23 |
01.07.2011 20:54:13
Väikse ääremärkusena - ka poolkutu ketas võib vabalt selliseid pikki käimajooksmisi teha, kuna Windows kulutab kogu oma aja Bad Sektoritest pärit vigaste bittide parandamiseks ja ümbertõstmiseks.
Nii, et tasuks masinasse panna ajutiselt täiesti korras ketas, sellele Win peale lükata ja siis vaadata, kuidas käitub ja kuidas kiirused on. Või siis uurida mõne kettakontrolliprogrammiga, et kuidas ketas käitub.
211 |
Noname
02.07.2011 00:07:46
| udusiil kirjutas: |
Noname, imelik jutt Gurult. Miks OS ei või hapuks minna? Mille vastu küll Ccleaner on? Miks tasuline NOD32, kui on olemas tasuta MSE? |
Imelikku pole siin midagi, 4000-5000 masinat läbi käinud ja pole näinud haput os-i. Üks väike osa sellest võib erinevatel põhjustel peeti minna aga see on kõik taastatav.
Tasuta MSE paigaldub ainult litsentsiga masinale ja ei ole nii hea kui max seadetel nod. Lihtne näide MSE Logist:
Rakenduses Security Essentials ilmnes järgmine tõrge: Tõrkekood 0x80070032. The request is not supported.
Kategooria: Trooja
Kirjeldus: See programm on ohtlik ja viib ellu ründajate käske.
Soovitatav toiming: Eemaldage see tarkvara kohe.
Security Essentials on tuvastanud programmid, mis võivad ohustada teie privaatsust või kahjustada arvutit. Pääsete nende programmide kasutatavatele failidele endiselt juurde neid eemaldamata (pole soovitatav). Nendele failidele juurdepääsemiseks valige toiming Luba ja siis klõpsake nupul Rakenda toimingud. Kui see suvand pole saadaval, logige sisse administraatorina või pöörduge abi saamiseks turbeadministraatori poole.
Üksused:
rootkit:AlureonMbr
TDSS killer tappis selle viiruse 15 sekudiga mida MSE ei suutnud 10X korraga.
322 |
Liivaannus
05.07.2011 15:45:38
| Läks uus win peale. Hetkel on elu ilus minimaalsete lisadega värske install.
