uus teema   vasta Tarkvara »  Tarkvara »  Väga pikk explorerininttime 206643 märgi kõik teemad loetuks
Liivaannus
sõnum 19.06.2011 12:57:21 Väga pikk explorerininttime 206643 vasta tsitaadiga
Masin buudib kole kaua, hakkasin asja uurima jõudsin selleni, et üks suurimaid venitajaid on explorer init time
    BootTsVersion 2
    BootStartTime 2011-06-19T08:06:41.671600300Z
    BootEndTime 2011-06-19T08:11:53.966038000Z
    SystemBootInstance 360
    UserBootInstance 328
    BootTime 309736
    MainPathBootTime 235208
    BootKernelInitTime 17
    BootDriverInitTime 1911
    BootDevicesInitTime 3553
    BootPrefetchInitTime 32569
    BootPrefetchBytes 232148992
    BootAutoChkTime 0
    BootSmssInitTime 9915
    BootCriticalServicesInitTime 4594
    BootUserProfileProcessingTime 2331
    BootMachineProfileProcessingTime 4532
    BootExplorerInitTime 206643
    BootNumStartupApps 17
    BootPostBootTime 74528
    BootIsRebootAfterInstall false
    BootRootCauseStepImprovementBits 512
    BootRootCauseGradualImprovementBits 0
    BootRootCauseStepDegradationBits 0
    BootRootCauseGradualDegradationBits 0
    BootIsDegradation false
    BootIsStepDegradation false
    BootIsGradualDegradation false
    BootImprovementDelta 0
    BootDegradationDelta 0
    BootIsRootCauseIdentified true
    OSLoaderDuration 3019
    BootPNPInitStartTimeMS 17
    BootPNPInitDuration 4568
    OtherKernelInitDuration 2139
    SystemPNPInitStartTimeMS 6531
    SystemPNPInitDuration 897
    SessionInitStartTimeMS 7604
    Session0InitDuration 1916
    Session1InitDuration 1406
    SessionInitOtherDuration 6591
    WinLogonStartTimeMS 17519
    OtherLogonInitActivityDuration 4181
    UserLogonWaitDuration 2558
Siia siis süsteemi riistvara informatsioon
    OS Name Microsoft Windows 7 Professional
    Version 6.1.7601 Service Pack 1 Build 7601
    Other OS Description Not Available
    OS Manufacturer Microsoft Corporation
    System Name ****
    System Manufacturer System manufacturer
    System Model P5QL PRO
    System Type x64-based PC
    Processor Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz, 3003 Mhz, 2 Core(s), 2 Logical Processor(s)
    BIOS Version/Date American Megatrends Inc. 0414, 25.07.2008
    SMBIOS Version 2.5
    Windows Directory C:\Windows
    System Directory C:\Windows\system32
    Boot Device \Device\HarddiskVolume1
    Locale Eesti
    Hardware Abstraction Layer Version = "6.1.7601.17514"
    User Name *******
    Time Zone FLE Daylight Time
    Installed Physical Memory (RAM) 4,00 GB
    Total Physical Memory 4,00 GB
    Available Physical Memory 1,73 GB
    Total Virtual Memory 8,00 GB
    Available Virtual Memory 5,44 GB
    Page File Space 4,00 GB
    Page File C:\pagefile.sys
Äkki oskate öelda, mis seda pikka booti põhjustada võiks. Visuaalselt on see pikk must ekraan peale logoni, kiirendada saab explorerit killides ja uuesti käivitades task managerist, kuid see pole päris OK lahendus mu jaoks. Enne kui see probleem tekkis veetis masin pikalt aega võrku otsides, sai pildi küll kiiresti ette, kuid näitas pikalt võrgu otsimist oma sinise ringiga seal ühenduse ikooni peal. Ruuter on thomsoni tg784. Kasutan ka fikseeritud kohtvõrgu IP d, kuna pole suutnud leida teist moodust, kuidas ruuter suudaks mu masinat tuvastada, MAC iga sidumine ei õnnestunud. Rohkem hetkel seonduvat informatsiooni pähe ei karga, kui on täpsustusi vaja küsige.
sõnum 23.06.2011 12:26:08 vasta tsitaadiga
Ühtlasi tasuks üle vaadata oma startup progede list ja installida uusimad win7 uuendused WU kaudu.
Kui ükski eelnevatest ei toimi, siis võid proovida teha uue kasutajakonto ja vaadata kas sellega on sama asi.
Liivaannus
sõnum 27.06.2011 23:19:28 vasta tsitaadiga
Peale Ms configu näppimist ja ccleaneriga üle käimist sain asja suts kiiremaks, kuid mitte normaalseks. Teise accounti puhul toimib asi analoogselt. Muutusd tekkis ainult nii palju, et enam pole must pilt vaid käivitab ilusti 3 nda osapoole tarkvara, kuid MS i oma asjad kuidagi lagivad. Võrguühenduse ikooni peal on see kahtlane sinine ring nagu mõtleks ja action center jõuab kisada, et viirusetõrje ei tule üles. Peale paari minutilist jama kaob see sinine ring ja tuleb ka viirusetõrje ilusti üles.
Ühesõnaga veits läks paremaks, kuid mitte piisavalt. Proovin veel Safemodei.
Edit:
Enne kui ta selle sinise rõnga minema saab on Taskmgr i järgi pikk idle, cpu 0-1%. Mingil hetkel aga kaob taskmgr nagu backgroundi vms, näha on ilusti aga kõlab see "kõll" helin kui miskit muuta tahad ja ei lase muuta, nagu oleks mingi veateade esiplaanile tulnud, kuid füüsiliselt sellist asja näha ei ole. Ja pealtnäha lambist hakkab masin äkki lammutama ja kõik normaliseerub. Kokku võtab trall peale logoni aega vast paar minutit. Vahemärkusena võin lisada, et peale logoni läheb digsby IM klient mürts üles ja ühendab ilma probleemideta.
sõnum 30.06.2011 17:11:21 vasta tsitaadiga
Liivaannus
sõnum 30.06.2011 20:27:51 vasta tsitaadiga
Nuh Reinstalli soovitavad paljud, aga see on loogika vastane lihtsalt, krt asju peab saama korda teha. Peale puhastamist läks olukord veits paremaks, et on enamvähem talutav, seega jätkan otsinguid lahenduse osas vaikselt, kui kopa ette viskab lasen uue peale.
sõnum 01.07.2011 09:04:59 vasta tsitaadiga
Liivaannus kirjutas:
Üldjuhul olen ma viimane inimene kes reinstalli soovitab aga omast kogemusest - vahel tõesti on see ainus valik.Näiteks eelmise installiga oli mul probleem, kus VLC mõtles 5-10 sekundit pärast selle sulgemist enne kui akna kinni viskas.Äärmiselt häiriv oli ja ma kulutasin tunde, et seda viga virtuaalmasinas sama tarkvaraga taasluua aga lõpuks andsin alla.Kui aeg kätte jõudis ja uue installi tegin, siis nüüd uuel see viga puudub.
Ühtlasi võib veel proovida käsurealt jooksutada:
sfc /scannow
See kontrollib üle ja parandab võimalikud vead mis see leiab.Igaks juhuks ütlen ka, et see võtab tagasi muudatused mis OS failidesse on tehtud.Üldiselt ei tohiks see probleem olla kui minggeid custom teemasid ja kraami ei jooksutada mis OS faile muudavad.
sfc /?
Microsoft (R) Windows (R) Resource Checker Version 6.0
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
Scans the integrity of all protected system files and replaces incorrect versions with
correct Microsoft versions.
SFC [/SCANNOW] [/VERIFYONLY] [/SCANFILE=<file>] [/VERIFYFILE=<file>]
[/OFFWINDIR=<offline windows directory> /OFFBOOTDIR=<offline boot directory>]
/SCANNOW Scans integrity of all protected system files and repairs files with
problems when possible.
/VERIFYONLY Scans integrity of all protected system files. No repair operation is
performed.
/SCANFILE Scans integrity of the referenced file, repairs file if problems are
identified. Specify full path <file>
/VERIFYFILE Verifies the integrity of the file with full path <file>. No repair
operation is performed.
/OFFBOOTDIR For offline repair specify the location of the offline boot directory
/OFFWINDIR For offline repair specify the location of the offline windows directory
e.g.
sfc /SCANNOW
sfc /VERIFYFILE=c:\windows\system32\kernel32.dll
sfc /SCANFILE=d:\windows\system32\kernel32.dll /OFFBOOTDIR=d:\ /OFFWINDIR=d:\windows
sfc /VERIFYONLY
Liivaannus
sõnum 01.07.2011 20:41:43 vasta tsitaadiga
Proovin selle skänni ära ja annan tulemustest teada. Kasutan ainult Akrapovici themei välimuse jaoks, muid suuremaid muutusi pole süsteemis küll teinud.
Edit: Ei leidnud midagi viga olevat.
Noname
Noname
sõnum 01.07.2011 21:01:03 vasta tsitaadiga
tomorrow kirjutas:
Loll jutt. OS ei lähe hapuks. Lase masin üle Combofixiga, tdss killeriga, cleaneriga, spybotiga ja nod32-ga.
tee chkdsk /r.
Kommentaarid: 373 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 322
Märt.
Märt.
sõnum 01.07.2011 21:41:39 vasta tsitaadiga
Noname, imelik jutt Gurult. Miks OS ei või hapuks minna? Mille vastu küll Ccleaner on? icon_lol.gif Miks tasuline NOD32, kui on olemas tasuta MSE?
sõnum 01.07.2011 21:54:13 vasta tsitaadiga
Väikse ääremärkusena - ka poolkutu ketas võib vabalt selliseid pikki käimajooksmisi teha, kuna Windows kulutab kogu oma aja Bad Sektoritest pärit vigaste bittide parandamiseks ja ümbertõstmiseks.
Nii, et tasuks masinasse panna ajutiselt täiesti korras ketas, sellele Win peale lükata ja siis vaadata, kuidas käitub ja kuidas kiirused on. Või siis uurida mõne kettakontrolliprogrammiga, et kuidas ketas käitub.
Noname
Noname
sõnum 02.07.2011 01:07:46 vasta tsitaadiga
udusiil kirjutas:
Imelikku pole siin midagi, 4000-5000 masinat läbi käinud ja pole näinud haput os-i. Üks väike osa sellest võib erinevatel põhjustel peeti minna aga see on kõik taastatav.
Tasuta MSE paigaldub ainult litsentsiga masinale ja ei ole nii hea kui max seadetel nod. Lihtne näide MSE Logist:
Rakenduses Security Essentials ilmnes järgmine tõrge: Tõrkekood 0x80070032. The request is not supported.
Kategooria: Trooja
Kirjeldus: See programm on ohtlik ja viib ellu ründajate käske.
Soovitatav toiming: Eemaldage see tarkvara kohe.
Security Essentials on tuvastanud programmid, mis võivad ohustada teie privaatsust või kahjustada arvutit. Pääsete nende programmide kasutatavatele failidele endiselt juurde neid eemaldamata (pole soovitatav). Nendele failidele juurdepääsemiseks valige toiming Luba ja siis klõpsake nupul Rakenda toimingud. Kui see suvand pole saadaval, logige sisse administraatorina või pöörduge abi saamiseks turbeadministraatori poole.
Üksused:
rootkit:AlureonMbr
TDSS killer tappis selle viiruse 15 sekudiga mida MSE ei suutnud 10X korraga.
Liivaannus
sõnum 05.07.2011 16:45:38 vasta tsitaadiga
Läks uus win peale. Hetkel on elu ilus minimaalsete lisadega värske install.
