uus teema   vasta Raud »  Kõvad kettad »  Reallocated sector count märgi kõik teemad loetuks
karlcrutch
karlcrutch
sõnum 05.05.2011 19:47:52 Reallocated sector count vasta tsitaadiga
Probleem antud attribuudiga. Äkki keegi oskab selgitada mida see endast kujutab? Kui jooksutada testi kõvakettal, siis kõik on ok välja arvatud see, mis annab warningu ja järgneva info
Normalized: 69
worst:69
Threshold:10
Value: 292 sectors
Kommentaarid: 9 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 8
Andrus Luht
itimees.ee
Andrus Luht
sõnum 05.05.2011 19:53:52 vasta tsitaadiga
See tähendab, et aegade jooksul on ketas oma tarkusega avastanud ja ringi mäppinud 69 halva kvaliteediga sektorit ketta pinnal.
Kommentaarid: 377 loe/lisa Kasutajad arvavad:  :: 5 :: 1 :: 318
walwur
sõnum 05.05.2011 19:58:10 vasta tsitaadiga
Bad sektorid.Kuidagi palju neid.Eks asjatundjad võiks selle jutu eesti keeles ära seletada.
Count of reallocated sectors. When the hard drive finds a read/write/verification error, it marks that sector as "reallocated" and transfers data to a special reserved area (spare area). This process is also known as remapping, and reallocated sectors are called "remaps". The raw value normally represents a count of the bad sectors that have been found and remapped. Thus, the higher the attribute value, the more sectors the drive has had to reallocate. This allows a drive with bad sectors to continue operation, however, a drive which has had any reallocations at all is significantly more likely fail in the near future.[12] While primarily used as a metric of the life-expectancy of the drive, this number also affects performance. As the count of reallocated sectors increases, the read/write speed tends to become worse because the drive head is forced to seek to the reserved area whenever a remap is accessed. A workaround which will preserve drive speed at the expense of capacity is to create a disk partition over the region which contains remaps and instruct the operating system to not use that partition.
Kommentaarid: 104 loe/lisa Kasutajad arvavad:  :: 2 :: 1 :: 92
karlcrutch
karlcrutch
sõnum 05.05.2011 22:24:41 vasta tsitaadiga
Ehk siis on aeg uus ketas muretseda.
toivos
toivos
sõnum 06.05.2011 09:51:07 vasta tsitaadiga
Andrus Luht kirjutas:
292
Taastan datat katkistelt ketastelt ja katkistelt Flash(USB) mäludelt. Nüüd ka katkistelt SSD ketastelt.
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 66
Andrus Luht
itimees.ee
Andrus Luht
sõnum 06.05.2011 10:03:38 vasta tsitaadiga
toivos, ma pole selles nii kindel. SMARTi interpreteerivad erinevad tarkvarad erineval. Näide:
HD Tune:
Linux'i smartctl:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   120   099   006    Pre-fail  Always       -       242225194
  3 Spin_Up_Time            0x0003   095   095   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       104
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       12
  7 Seek_Error_Rate         0x000f   075   061   030    Pre-fail  Always       -       35803325
  9 Power_On_Hours          0x0032   088   088   000    Old_age   Always       -       10692
10  Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12  Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       52
183 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
184 Unknown_Attribute       0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   065   057   045    Old_age   Always       -       35 (Lifetime Min/Max 31/38)
194 Temperature_Celsius     0x0022   035   043   000    Old_age   Always       -       35 (0 21 0 0)
195 Hardware_ECC_Recovered  0x001a   045   027   000    Old_age   Always       -       242225194
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       113198158064129
241 Unknown_Attribute       0x0000   100   253   000    Old_age   Offline      -       3970832001
242 Unknown_Attribute       0x0000   100   253   000    Old_age   Offline      -       2673346542
Kontrollerist tuleb ta ju üldse sellisel kujul:
S.M.A.R.T. (Controller ID 2 - Port 3):
10 00 01 0F 00 64 64 00 00 00 00 00 00 00 03 07
00 47 47 12 25 00 00 00 00 00 04 32 00 64 64 66
00 00 00 00 00 00 05 33 00 35 35 EE 07 00 00 00
00 00 07 0F 00 FD FD 00 00 00 00 00 00 00 08 25
00 64 64 00 00 00 00 00 00 00 09 32 00 5F 5F FC
64 00 00 00 00 00 0A 33 00 64 64 00 00 00 00 00
00 00 0B 12 00 64 64 01 00 00 00 00 00 00 0C 32
00 64 64 65 00 00 00 00 00 00 0D 0E 00 64 64 00
00 00 00 00 00 00 B8 37 00 64 64 00 00 00 00 00
00 00 BB 32 00 64 64 03 00 00 00 00 00 00 BC 32
00 64 64 00 00 00 00 00 00 00 BE 22 00 47 40 1D
00 0F 24 00 00 00 C2 22 00 47 40 1D 00 0B 25 00
00 00 C3 1A 00 64 64 D7 26 1B 00 00 00 00 C4 32
00 64 64 00 00 00 00 00 00 00 C5 12 00 64 64 00
00 00 00 00 00 00 C6 30 00 64 64 00 00 00 00 00
00 00 C7 3E 00 C8 C8 00 00 00 00 00 00 00 C8 0A
00 C8 BE 00 00 00 00 00 00 00 C9 0A 00 64 64 00
00 00 00 00 00 00 CA 32 00 64 64 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 E7 2D 00 7B
03 00 01 00 02 C5 15 C5 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 CB
walwur
sõnum 06.05.2011 11:33:31 vasta tsitaadiga
Mida tähendab C7 Ultra DMA CRC error count?Omal annab sellel 200/253/0/47/warning
toivos
toivos
sõnum 06.05.2011 11:49:23 vasta tsitaadiga
walwur kirjutas:
Ülekande vead kaablis
sõnum 06.05.2011 16:31:53 vasta tsitaadiga
HD Tune:
Linux'i smartctl:
Need näited paistavad olema erinevatelt ketastelt ja see HD Tune pilt on üldse väga kahtlase välimusega - kas on HD Tune või ketta firmware puhta lolliks läinud, et nullise raw väärtusega on normaliseeritud väärtus 1 icon_confused.gif . Kui see pilt sinult ei tuleks, ütleksin, et looks shopped
Samas on C4 ja C5 väärtused seal pildil toivos (ja wikipedia) varianti toetavad, ainult reallocated sector count raw väärtus on millegipärast nulliks muutunud - muid parameetreid vaadates see kindlasti null olla ei saa. See juhtum tundub siiski mingi firmware kiiks olema (puhver ületäitunud?)
Pean siiski toivos-ga ühinema selles osas, et normaliseeritud väärtus on see, mis kõigi parameetrite puhul hakkab pihta 200 või 100 pealt ning halvenedes hakkab vähenema ja allapoole thresholdi langedes hakkab SMART häiret andma. Nähtud seda tervel hulgal erinevatel ketastel ja ühel ja samal kettal on seni ikkagi nii HD Tune kui Everest kui smartctl ja veel mõni SMART parameetreid näitav tarkvarajupp neid numbreid ühtemoodi näidanud.
Ma ei tea, kust sinu info pärit on, aga ei ole siin foorumis ega mul endal veel sinu interpretatsiooni kinnitavaid näiteid esinenud.
Kui nüüd süvened natuke neisse tabelitesse ja vaatad ka tulpade pealkirju - raw on ikkagi "toores" loendur ja normaliseerimine tähendab mingit tüüpi "kaalumist", antud juhul täiesti erinevate parameetrite viimist ühtsele skaalale (0-253), vastupidine tõlgendus oleks absurd ja selle lükkavad ümber sinu oma toodud näited (ja kümned näited siit foorumist)
ot:
vabandust, kui mul veidi trükivigu täna rohkem tekstis sees on - jätsin tund aega tagasi parema käe keskmise sõrme otsapidi puusületäie ja seina vahele ja sõrm on nüüd üsna tuim
Ma ise ka alles võrdlemisi hiljuti (veidi rohkem kui aasta tagasi) võtsin ette ja tegin endale selle asja selgeks, enne seda olin samuti veidi segaduses. Wiki on tihtipeale hea lugemismaterjal.
HacaX
HacaX
sõnum 09.05.2011 22:34:37 vasta tsitaadiga
OT: lisaks on ka see teema et kettalt tulenev info võib olla esitatud teisiti kui ta speci kohaselt olema peaks (smartctl'il oli lausa võti et firmware'ide sedasorti lutikatega arvestada, kui mälu ei peta siis Samsung oli peamine tootja kelle kettad kippusid andmeid vales järjekorras väljastama)
IMO & GPLed
villu70
villu70
sõnum 15.01.2014 21:08:11 vasta tsitaadiga
Targemad, andke nõu kas üks ketas hakkab otsi andma?
Kommentaarid: 142 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 122
Märt.
Märt.
sõnum 16.01.2014 17:10:30 vasta tsitaadiga
Jah.
villu70
villu70
sõnum 16.01.2014 17:14:51 vasta tsitaadiga
Märt., tänud thumbs_up.gif , seda ma kartsin
