karlcrutch
05.05.2011 20:47:52
Reallocated sector count |
Probleem antud attribuudiga. Äkki keegi oskab selgitada mida see endast kujutab? Kui jooksutada testi kõvakettal, siis kõik on ok välja arvatud see, mis annab warningu ja järgneva info
Normalized: 69
worst:69
Threshold:10
Value: 292 sectors
| Kommentaarid: 9 loe/lisa |
Andrus Luht
itimees.ee
318 |
walwur
05.05.2011 20:58:10
Bad sektorid.Kuidagi palju neid.Eks asjatundjad võiks selle jutu eesti keeles ära seletada.
Count of reallocated sectors. When the hard drive finds a read/write/verification error, it marks that sector as "reallocated" and transfers data to a special reserved area (spare area). This process is also known as remapping, and reallocated sectors are called "remaps". The raw value normally represents a count of the bad sectors that have been found and remapped. Thus, the higher the attribute value, the more sectors the drive has had to reallocate. This allows a drive with bad sectors to continue operation, however, a drive which has had any reallocations at all is significantly more likely fail in the near future.[12] While primarily used as a metric of the life-expectancy of the drive, this number also affects performance. As the count of reallocated sectors increases, the read/write speed tends to become worse because the drive head is forced to seek to the reserved area whenever a remap is accessed. A workaround which will preserve drive speed at the expense of capacity is to create a disk partition over the region which contains remaps and instruct the operating system to not use that partition.
92 |
karlcrutch
05.05.2011 23:24:41
| Ehk siis on aeg uus ketas muretseda.
toivos
06.05.2011 10:51:07
| Andrus Luht kirjutas: |
| See tähendab, et aegade jooksul on ketas oma tarkusega avastanud ja ringi mäppinud 69 halva kvaliteediga sektorit ketta pinnal. |
292
_________________ Taastan datat katkistelt ketastelt ja katkistelt Flash(USB) mäludelt. Nüüd ka katkistelt SSD ketastelt. |
| Kommentaarid: 70 loe/lisa |
66 |
Andrus Luht
itimees.ee
06.05.2011 11:03:38
toivos, ma pole selles nii kindel. SMARTi interpreteerivad erinevad tarkvarad erineval. Näide:
HD Tune:
Linux'i smartctl:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 120 099 006 Pre-fail Always - 242225194
3 Spin_Up_Time 0x0003 095 095 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 104
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 12
7 Seek_Error_Rate 0x000f 075 061 030 Pre-fail Always - 35803325
9 Power_On_Hours 0x0032 088 088 000 Old_age Always - 10692
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 52
183 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
184 Unknown_Attribute 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 065 057 045 Old_age Always - 35 (Lifetime Min/Max 31/38)
194 Temperature_Celsius 0x0022 035 043 000 Old_age Always - 35 (0 21 0 0)
195 Hardware_ECC_Recovered 0x001a 045 027 000 Old_age Always - 242225194
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 113198158064129
241 Unknown_Attribute 0x0000 100 253 000 Old_age Offline - 3970832001
242 Unknown_Attribute 0x0000 100 253 000 Old_age Offline - 2673346542 |
Kontrollerist tuleb ta ju üldse sellisel kujul:
S.M.A.R.T. (Controller ID 2 - Port 3):
10 00 01 0F 00 64 64 00 00 00 00 00 00 00 03 07
00 47 47 12 25 00 00 00 00 00 04 32 00 64 64 66
00 00 00 00 00 00 05 33 00 35 35 EE 07 00 00 00
00 00 07 0F 00 FD FD 00 00 00 00 00 00 00 08 25
00 64 64 00 00 00 00 00 00 00 09 32 00 5F 5F FC
64 00 00 00 00 00 0A 33 00 64 64 00 00 00 00 00
00 00 0B 12 00 64 64 01 00 00 00 00 00 00 0C 32
00 64 64 65 00 00 00 00 00 00 0D 0E 00 64 64 00
00 00 00 00 00 00 B8 37 00 64 64 00 00 00 00 00
00 00 BB 32 00 64 64 03 00 00 00 00 00 00 BC 32
00 64 64 00 00 00 00 00 00 00 BE 22 00 47 40 1D
00 0F 24 00 00 00 C2 22 00 47 40 1D 00 0B 25 00
00 00 C3 1A 00 64 64 D7 26 1B 00 00 00 00 C4 32
00 64 64 00 00 00 00 00 00 00 C5 12 00 64 64 00
00 00 00 00 00 00 C6 30 00 64 64 00 00 00 00 00
00 00 C7 3E 00 C8 C8 00 00 00 00 00 00 00 C8 0A
00 C8 BE 00 00 00 00 00 00 00 C9 0A 00 64 64 00
00 00 00 00 00 00 CA 32 00 64 64 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 E7 2D 00 7B
03 00 01 00 02 C5 15 C5 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 CB |
_________________ Äriklassi serverilahenduste müük, paigaldus ja haldus. SaaS / PaaS / IaaS lahendused
Tier-3 privaatpilvede, virtuaal- ja virtuaal-privaat-serverite lahendused. 24/7 haldus, monitooring |
318 |
walwur
06.05.2011 12:33:31
| Mida tähendab C7 Ultra DMA CRC error count?Omal annab sellel 200/253/0/47/warning
92 |
toivos
06.05.2011 12:49:23
| walwur kirjutas: |
| Mida tähendab C7 Ultra DMA CRC error count?Omal annab sellel 200/253/0/47/warning |
Ülekande vead kaablis
66 |
06.05.2011 17:31:53
Need näited paistavad olema erinevatelt ketastelt ja see HD Tune pilt on üldse väga kahtlase välimusega - kas on HD Tune või ketta firmware puhta lolliks läinud, et nullise raw väärtusega on normaliseeritud väärtus 1 . Kui see pilt sinult ei tuleks, ütleksin, et looks shopped
Samas on C4 ja C5 väärtused seal pildil toivos (ja wikipedia) varianti toetavad, ainult reallocated sector count raw väärtus on millegipärast nulliks muutunud - muid parameetreid vaadates see kindlasti null olla ei saa. See juhtum tundub siiski mingi firmware kiiks olema (puhver ületäitunud?)
Pean siiski toivos-ga ühinema selles osas, et normaliseeritud väärtus on see, mis kõigi parameetrite puhul hakkab pihta 200 või 100 pealt ning halvenedes hakkab vähenema ja allapoole thresholdi langedes hakkab SMART häiret andma. Nähtud seda tervel hulgal erinevatel ketastel ja ühel ja samal kettal on seni ikkagi nii HD Tune kui Everest kui smartctl ja veel mõni SMART parameetreid näitav tarkvarajupp neid numbreid ühtemoodi näidanud.
Ma ei tea, kust sinu info pärit on, aga ei ole siin foorumis ega mul endal veel sinu interpretatsiooni kinnitavaid näiteid esinenud.
Kui nüüd süvened natuke neisse tabelitesse ja vaatad ka tulpade pealkirju - raw on ikkagi "toores" loendur ja normaliseerimine tähendab mingit tüüpi "kaalumist", antud juhul täiesti erinevate parameetrite viimist ühtsele skaalale (0-253), vastupidine tõlgendus oleks absurd ja selle lükkavad ümber sinu oma toodud näited (ja kümned näited siit foorumist)
| ot: |
| vabandust, kui mul veidi trükivigu täna rohkem tekstis sees on - jätsin tund aega tagasi parema käe keskmise sõrme otsapidi puusületäie ja seina vahele ja sõrm on nüüd üsna tuim |
Ma ise ka alles võrdlemisi hiljuti (veidi rohkem kui aasta tagasi) võtsin ette ja tegin endale selle asja selgeks, enne seda olin samuti veidi segaduses. Wiki on tihtipeale hea lugemismaterjal.
HacaX
09.05.2011 23:34:37
OT: lisaks on ka see teema et kettalt tulenev info võib olla esitatud teisiti kui ta speci kohaselt olema peaks (smartctl'il oli lausa võti et firmware'ide sedasorti lutikatega arvestada, kui mälu ei peta siis Samsung oli peamine tootja kelle kettad kippusid andmeid vales järjekorras väljastama)
| Kommentaarid: 24 loe/lisa |
22 |
villu70
15.01.2014 22:08:11
Targemad, andke nõu kas üks ketas hakkab otsi andma?
122 |
Märt.
16.01.2014 18:10:30
Jah.
| Kommentaarid: 29 loe/lisa |
23 |
villu70
16.01.2014 18:14:51
Märt., tänud , seda ma kartsin
122 |
