One_Of_Us
16.08.2010 00:07:20
Videkaardi biosi flashimine |
oleks siis vaja "pisut" abi flashimisel, oman gigabyte videokaarti millel ei taha driverid korralikult peale minna ning kõik featurid töötada, soovitati proovida biosi flashimist, tootja enda poolt on välja antud biosi uuendused kuid nendega kaasas hoiatused:
1)Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction.
2)Be aware that flashing your video card BIOS in an attempt to change or upgrade the card will certainly void any warranty you may have with the manufacturer, so perform this procedure at your own risk. Certain manufacturers consider any attempt to flash the BIOS as a violation of warranty terms and will withdraw support even if you were not attempting to change the card's capabilities. Also note that if you attempt to considerably increase the performance of your video card by this method, as in overclocking, you are increasing the stress on the hardware, which may cause it to fail sooner.
hoiatused teevadki ettevaatlikuks kuna süsteem pmst töötab, lihtsalt mitte nii nagu max lubab, olekski küsimus kas peaksin tegema biosi uuenduse ning mis saab siis kui midagi valesti läheb.
_________________ mida saab öelda, saab öelda lühidalt. |
| Kommentaarid: 87 loe/lisa |
69 |
pohmakas,
käed värisevad
16.08.2010 07:43:35
Kõigepealt tee vanast BIOS-ist turvalisse kohta backup, et garantiivajadusel vms saaksid tagasi flashida
| Kommentaarid: 164 loe/lisa |
136 |
marxveix
16.08.2010 07:47:34
| Kaardist vana bios siis alati võimalus tagasi flashida (juhul kui miskit nihu läheb). Tagasi flashimisel abiks PCI videokaart.
| Kommentaarid: 310 loe/lisa |
270 |
XeStAiSy
Aeg Maha 2a
16.08.2010 15:39:32
_________________ Punktkeevitus patareidele/akudele. Akutrelli/laptopi/e-bike. PM
viimati muutis XeStAiSy 17.08.2010 06:08:22, muudetud 1 kord |
| Kommentaarid: 12 loe/lisa |
One_Of_Us
16.08.2010 15:48:18
siinsete nõuannete järgi ma siiski siis flashin selle biosi ära, keegi muidugi võiks rääkida veel omadest kogemustest ning kuidas täpselt tal see protseduur käis, internetis muidugi ka õpetused olemas, aga parem ikka kuulda neilt, kes selle ise edukalt sooritanud või vastupidi, neilt, kel midagi valesti läinud ning kuidas probleem lahendatud sai.
olen kindel et sellest oleks päris palju abi teistelegi biosi flashijatele.
69 |
Ramones
16.08.2010 23:48:50
Protseduur järgmine:
1. Teha USB mälupulk bootivaks
2. Sinna peale laduda atiflash.exe ja flashitav biosi fail
3. Arvuti pulga pealt bootida
4. atiflash -f -p 0 bios.rom (kahe kaardiga tuleb vaadata kumba kaarti ikka flashida tahetakse)
5. restart, kaart flashitud
Kui USB pulga bootivaks vormindamine välja arvata, siis muule tegevusele kulub ~2min
Elus esimest korda tehes võttis kogu protseduur koos õpetuse lugemisega ~20min ja seda peale 4 joodud
PS. Selline protseduur kehtib ATI kaartide kohta. Ei näe kuskilt, mis kaardiga teemaalgatajal tegemist on. Kui nV, siis protsess ilmselt pisut teistsugune.
| Kommentaarid: 76 loe/lisa |
75 |
One_Of_Us
17.08.2010 01:46:34
nüüdseks ka endal flash tehtud ja märgatav paranemine süsteemis toimunud. protseduuri läbisin google õpetuste läbi
protseduur erines eelmisest vaid selle poolest et otsisin mälupulga asemel üles vana flopi seadme ning atiflashi asemel kasutasin nvflashi.
ehk siis
1. teha flopi bootivaks(rmb flopil, valikust format ning create msdos startup disk)
2. netist tõmmata nvflash program ning uue biosi fail(bios ümbernimetada 1.rom), ning lisada need diskile
3. arvutile teha restart disk sees
4. (kui soovid teha backup vanast biosist siis trüki nvflash -b backup01.rom) trüki nvflash -5 -6 1.rom
ka mul võttis protseduur ise 2min kuid õpetuste lugemine ning hoiatustele mõtlemine pisut kauem nagu juba mainisin tegemist oli nV kaardiga ning protsess just väga palju erinenudki, kuigi võib biosi muutmine vähendada kaardi eluiga tuli biosi uuendamisega kaardile juurde uusi huvitavaid võimalusi nagu näiteks temp. jälgimine ja suurtemate pingetega mängimine.
69 |
WäntWõll
make.believe
17.08.2010 02:29:26
Väha nutikas on mainid aviimases postis mis firma kaarti flässisid
Geniaalne IMO
Nvidia flässamine oleks võtnud Windowsi all umbes minuti hirmu
300 |
rycyve
| Kommentaarid: 98 loe/lisa |
81 |
One_Of_Us
20.08.2010 22:15:38
ei leidnud kahjuks seda teemat üles algul ja siin saadud vastustest oli tõesti palju abi nii et pmst teemast kasu kui palju, kahjuks ei saa muuta kustuta seda teemat enam.
69 |
indu
16.12.2011 16:09:29
Ei hakka uut teemat tegema.
Sai windowsi all videokaarti bios metsa keeratud. Windowsi enam ei boodi.
Tegin backupi kuid miks dosis enam ei lase flashida ?
Selline tekst ees.
_________________ http://www.lossirestoran.eu/ |
| Kommentaarid: 63 loe/lisa |
58 |
trip
17.12.2011 10:19:23
proovi
atiflash -p -sst 0 ati.rom
303 |
indu
24.12.2011 16:16:04
| indu kirjutas: |
| trip kirjutas: |
proovi
atiflash -p -sst 0 ati.rom |
Edasi nagu ei toimund midagi
58 |
raku16
24.12.2011 18:32:21
sul on seal kirjutatud lõpus ati.com või ma eksin ?
peaks ikka olema ati.rom
| Kommentaarid: 18 loe/lisa |
18 |
indu
25.12.2011 00:02:45
| raku16 kirjutas: |
peaks ikka olema ati.rom |
Jup my bad - lähen siis uuele katsele.
58 |
trip
28.12.2011 10:36:03
| indu, mis kaart see sul on, mis mudel täpsemalt?
303 |
indu
05.02.2012 13:08:02
Nii sain teise arvuti ja kirjutasin käsurea nüüd õigesti aga sama kiri ees. Ei tahaks uskuda et nüüd ära flashis.
HD Sapphire 6850 on kaartiks.
58 |
heikis
05.02.2012 13:18:47
atiflash -i näitab tuvastatud ati adapterid. võibolla 0 on vale?
loe lisaks siit:
http://www.techpowerup.com/forums/showthread.php?t=57750
lisaks su näites on sst ilma sidekriipsuta. pole mõtet niisama lahmida neid käske sinna kui sa ei tea, kuidas syntax toimib või mida mingi käsk üldse tegema peaks. tee asi endale enne selgeks. pole ime, et midagi pekki oled keeranud.
| Kommentaarid: 338 loe/lisa |
290 |
indu
05.02.2012 13:50:05
| heikis kirjutas: |
loe lisaks siit:
lisaks su näites on sst ilma sidekriipsuta. pole mõtet niisama lahmida neid käske sinna kui sa ei tea, kuidas syntax toimib või mida mingi käsk üldse tegema peaks. tee asi endale enne selgeks. pole ime, et midagi pekki oled keeranud. |
atiflash -i näitab et no adapter found.
Pekki läks kaart winflashimise ajal.
e: kõige uuema atiflashiga toimis.
58 |
