arvuti510
08.02.2009 19:33:03
kuidas eemaldada ikoon ekraanilt(desktopilt) |
| Kuidas eemaldada ikooni ekraanilt? Ikooniks on "My bluetooth places". Kustutada seda ei saa, parema hiireklahviga vajutades ei tule "delete" valikut ka.
M00t
08.02.2009 19:51:22
| desktopil paremklikk>properties ja siis kuidagi sealt. (Mul on Vista, ma ei mäleta kuidas XP'l need asjad käisid eeldades et sul on XP)
| Kommentaarid: 77 loe/lisa |
73 |
siLc
08.02.2009 19:51:46
| Kui arvutis on Bluetooth moodul, siis miks mitte selle tarkvara alt uurida?
186 |
limp
08.02.2009 20:03:38
| lu1de kirjutas: |
| desktopil paremklikk>properties ja siis kuidagi sealt. (Mul on Vista, ma ei mäleta kuidas XP'l need asjad käisid eeldades et sul on XP) |
customize desktop all peaks olema...
_________________ Ärgake lapsed, maailm on hädaohus
Windows keskkond on nagu li*s - kõik teda ke*ivad aga keegi teda ei armasta! |
| Kommentaarid: 56 loe/lisa |
52 |
Oliverk
08.02.2009 20:21:30
| See tekib Bluetooth software installil. Alal kella juures bluetooth ikoonil parem klõps ja kuskilt sealt seadetest show my bluetooth places linnuke maha. Panen peast hetkel täpselt ei mäleta aga vist nii oli.
| Kommentaarid: 27 loe/lisa |
26 |
miq1988
08.02.2009 20:26:39
Kunagi oli sama jama, kasutasin siis guuglit ja sain sellise vastuse ning toimib:
I recently installed my bluetooth usb dongle on my computer running Vista and
I found an unwanted feature which was also present when I was using XP.
The bluetooth icon that was installed on the desktop, after I installed my bluetooth driver software,
was refusing to remove itself. Right clicking on it would only produce three options;
Open, Explore and Create Shortcut. Last time (XP) I got around this problem by running a desktop clean up,
that put all the icons I chose into a folder, which I then deleted. After a quick look
I couldnt find it on my computer so looked the problem on Google and after a few mins
came across a great little solution vistax64.com from user POMAH.
All you have to do is fire up the registry editor and navigate to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows \CurrentVersion\explorer\Desktop\NameSpace
To do this just type regedit and hit enter in Vistas search bar. Navigate to the above
location and select each of the folders beneath (each of these represent all of your icons on your desktop)
while looking at the left of the pannel for something that will look like the below image.
When youve found the folder delete it, go to your desktop and
press F5 to refresh the screen and it should be gone.
As always though when editing the regerstriy make a backup of the entry your editing/deleting
incase anything goes wary. To make a backup just right click the folder and hit Export.
| Kommentaarid: 10 loe/lisa |
10 |
arvuti510
08.02.2009 22:23:17
| sain lahti ikoonist, kasutasin "unused desktop" ikoonide kustutamise värki.
Absona
| Kommentaarid: 11 loe/lisa |
2 trini
12.02.2009 08:20:04
| Mul see sama ikoon ja ei saanud kuskilt välja lülitada muudmoodi kui TweakUI'ga eemaldades. Tekitas selle Blue Soleil soft.
| Kommentaarid: 16 loe/lisa |
15 |
