uus teema   vasta Hinnavaatlus »  Sülearvutid »  Kas peab garantiise viima? märgi kõik teemad loetuks
SeedX
SeedX
sõnum 19.01.2009 16:57:36 Kas peab garantiise viima? vasta tsitaadiga
Paar päeva tagasi tekkisid ekraanile imelikud triibud ja viskas seejärel sinise ekraani ette. Tegin viiruse kontrolli, ja lasin draiverid maha ja installisin uuesti peale. Peale restarti ei läinud enam windowsi, oli must pilt ja tegi seejärel restardi. Tegin formati ja lasin uue win peale, puhastasin arvuti seest ära. Uued draiverid ka ei anna asja.Biosi update ka tehtud. Kui Draiverid maas siis saan windowsi sisse, praegu läppar ühendatud monitoriga. Läppar ise pilti ei näita. Värve paistab olevat 8 bit. Läppar siis Amilo Xa1526
Kodukal selline teade.
Mandatory BIOS update!!!
Some Fujitsu Siemens Computers notebooks are experiencing long-term faults in their graphics displays. This is due to faulty graphics cards and chipsets. The problem can be remedied by replacing the graphics card or motherboard. During the warranty this repair is performed by us free-of-charge:
The following AMILO Notebook systems may be affected:
AMILO Notebook Xi 1526
AMILO Notebook Pi 1556
AMILO Notebook Xa 1526
AMILO Notebook Pa 1538
AMILO Notebook Xa 2528
AMILO Notebook Xa 2529
The following errors may occur:
Development of stripes on the display / garbage on the display
Display does not work at all
System does not boot
For precautionary action you may update your Bios.
The following updates are available, the others will follow, and we will update this page accordingly:
AMILO Pi 1556 - BIOS Version: 1.26
AMILO Xi 1526 - BIOS Version: 1.26
AMILO Pa 1538 - BIOS Version: 1.1P
AMILO Xa 1526 - BIOS Version: 1.1R
AMILO Xa 2528 / Xa 2529 - BIOS Version: 1.0R
If your system doesn`t show one or more of these symptoms we strongly recommend to update your system with the latest BIOS version available for download on our support pages.
Tehase garantii peaks olema mul 2 aastat. Aga kuna olen läpparit mitu korda laiali lammutanud, siis mida teha tuleks ja palju see parandus maksma läheks.
siLc
sõnum 19.01.2009 17:11:47 vasta tsitaadiga
Teha tuleks seda, et vaadata kas saad asja esialgsesse seisundisse taastada. Kui seda teha pole võimalik, siis uue emaplaadi ja töö maksumuse hinda uuri näiteks ServiceNet`st ja Fujitsu Services`st.
SeedX
SeedX
sõnum 21.01.2009 18:21:37 vasta tsitaadiga
Kas tehase seadeid on võimalik taastada kui arvuti ei boodi windowsi, vaid jookseb kokku. Uut windowsi ei saa ka peale panna, jookseb kokku.
Parandus läheks mul maksma 6500.- + KM.
meelis63
sõnum 22.01.2009 00:21:51 vasta tsitaadiga
...kas wini pealelaskmisel probleeme ei esinenud? Asi lõhnab muidu ikka videokaardi vea järgi...siis olukord ikka nutune...
SeedX
SeedX
sõnum 22.01.2009 13:23:15 vasta tsitaadiga
Wini pealelaskmisel pidin läppari ühendama suure monitoriga, sest läppar näitas ainult poolikut pilti või üldse mitte midagi.
sõnum 22.01.2009 13:26:19 vasta tsitaadiga
Vii garantiisse. Sul tundub seal mingi tõsisem jama olevat.
siLc
sõnum 22.01.2009 13:31:32 vasta tsitaadiga
Betamax kirjutas:
SeedX kirjutas:
sõnum 22.01.2009 13:36:59 vasta tsitaadiga
SeedX
SeedX
sõnum 22.01.2009 16:33:55 vasta tsitaadiga
Mul peaks olema 2aastat tehasegarantiid, aga see vist ei loe kui ma olen arvuti mitu korda lahti teinud.
eddvin
eddvin
sõnum 22.02.2009 23:41:11 vasta tsitaadiga
ma viisin remonti...öeldi et põhimõtteliselt võib läpaka minema visata, sest videokaarti ei ole icon_biggrin.gif see lihtsalt läks katki
birgit123
birgit123
sõnum 22.02.2009 23:51:50 vasta tsitaadiga
Garantii kehtib ka siis kui sa oled seda mitu korda ise kokku/lahti võtnud. Eeldusel, et sa ise kuidagi asja vigastanud ei ole. Too kui garantii alles ja füüsiliselt kõik korras , siis saada näiteks meile see masin. Äkki saab aidata www.kungla.ee
toivos
toivos
sõnum 23.02.2009 10:26:57 vasta tsitaadiga
eddvin kirjutas:
Ega tal eraldi videokaarti polegi. Kõik on emaplaadi peale joodetud.
Taastan datat katkistelt ketastelt ja katkistelt Flash(USB) mäludelt. Nüüd ka katkistelt SSD ketastelt.
sõnum 23.02.2009 10:40:47 vasta tsitaadiga
Muide - selline nähtus, et läppari ekraanil pole pilti, kuid välise monitoriga on pilt, võib olla vabalt täiesti remonditav emaplaadi viga.
Alles paar päeva tagasi lappisin ühe HV-lase Fujitsu-Siemensi läppari emaplaati, millel enda ekraaniga pilt puudus, kuid välise ekraaniga oli pilt olemas.
eddvin
eddvin
sõnum 23.02.2009 22:50:31 vasta tsitaadiga
to toivos:
jah, minu viga, ega ei ole tõesti eraldi videokaarti. Vabandust aga ma ei tunne läpakaehitust eriti icon_smile.gif
Muidu on pilt mul olemas, aga kui läpakat sisse lülitada, siis on ekraanil triibud ja kui installida display driver, ei lähegi läpakas tööle icon_sad.gif
MONGO
MONGO
sõnum 25.02.2009 14:02:28 vasta tsitaadiga
Mul on sama mudeliga sarnane probleem, uurisin natuke asja ja vastab täpselt netist leitud jamade kirjeldustele: ekraan hakkas jamama alguses harva, kord 10 käivituse peale näiteks, siis jama tihenes ja enam ei tööta üldse, suht kindel olen et emaplaadi viga, sest kui pilt ette tuli võisid väänata mispidi tahes ja ikka töötas.
Seda et masin ilusti üles buudib tean kindlalt sellest, et vindoosa startup meloodia käib paarkümmend seci peale käivitust. Netist laidsin ka, et paljudel hakkas jura peale ca aastavanuse masinaga, mul ta nii vana ongi.
Tõe huvides mainin ära et loll väikevend ajas arvutile peale rohke alkoholiga siirupise koksi, umbkaudu kuu või rohkem peale seda ta hakkas jamama ka, seepärast garantiiga parem tegemist ei tee, lisaks olen ka ise lahti võtnud teda ja mõne asja ära vahetanud.
Täna lähen uurima palju emme maksab, vahetaksin ise ära ta. Vahepeal tekkis ka hull plaan ehitada ta desktopiks ümber icon_smile.gif arvutit on vaja ja 10 k ei ole tõesti võtta mitte kuskilt, selline asi oleks võimalik juhul, kui kuskilt sobiv kasutatud emaplaat leida.
Nomore
Nomore
sõnum 27.02.2009 17:29:21 vasta tsitaadiga
Keegi rääkis hiljuti, et tasub emaplaat puhtaks pesta kõigist suhkru- ja vedelikujääkidest, kui pärast vedeliku peale kallamist probleemid tekivad.
Eile nägin, kuidas mees teerulli alla jäi. Nüüd mul enam ühte jalga pole.
cbr
cbr
sõnum 01.12.2010 19:18:07 vasta tsitaadiga
tahanteada kirjutas:
Kuidas sa seda siis remontisid? Mul ühel Pa 1538-l on siin ekraan otsad andnud. Välise monitoriga üle DVI samas töötab. Tundub, et samasugune graafikakaardi jama.
sõnum 01.12.2010 19:30:30 vasta tsitaadiga
cbr: Seinast seina võimalused - nii nagu lähed seljavaluga kirurgi juurde - enne uuritakse - siis lüüakse nuga selga. icon_smile.gif
Nii ka läppari juures - kui lollusi põhjustab tolm, siis puhastad, kui on mõni jubin kutu, siis pead selle üles otsima ja nii edasi - ühtset retsepti ja ravimist olemas pole. icon_wink.gif
cbr
cbr
sõnum 01.12.2010 19:33:29 vasta tsitaadiga
Nojah, antud juhul tundub, et on graafikakaart kutu. Mida sina sel korral tegid? Oli see üldse üks neist mudelitest?
