SeedX
19.01.2009 17:57:36
Kas peab garantiise viima? |
Paar päeva tagasi tekkisid ekraanile imelikud triibud ja viskas seejärel sinise ekraani ette. Tegin viiruse kontrolli, ja lasin draiverid maha ja installisin uuesti peale. Peale restarti ei läinud enam windowsi, oli must pilt ja tegi seejärel restardi. Tegin formati ja lasin uue win peale, puhastasin arvuti seest ära. Uued draiverid ka ei anna asja.Biosi update ka tehtud. Kui Draiverid maas siis saan windowsi sisse, praegu läppar ühendatud monitoriga. Läppar ise pilti ei näita. Värve paistab olevat 8 bit. Läppar siis Amilo Xa1526
Kodukal selline teade.
Mandatory BIOS update!!!
Some Fujitsu Siemens Computers notebooks are experiencing long-term faults in their graphics displays. This is due to faulty graphics cards and chipsets. The problem can be remedied by replacing the graphics card or motherboard. During the warranty this repair is performed by us free-of-charge:
The following AMILO Notebook systems may be affected:
AMILO Notebook Xi 1526
AMILO Notebook Pi 1556
AMILO Notebook Xa 1526
AMILO Notebook Pa 1538
AMILO Notebook Xa 2528
AMILO Notebook Xa 2529
The following errors may occur:
Development of stripes on the display / garbage on the display
Display does not work at all
System does not boot
For precautionary action you may update your Bios.
The following updates are available, the others will follow, and we will update this page accordingly:
AMILO Pi 1556 - BIOS Version: 1.26
AMILO Xi 1526 - BIOS Version: 1.26
AMILO Pa 1538 - BIOS Version: 1.1P
AMILO Xa 1526 - BIOS Version: 1.1R
AMILO Xa 2528 / Xa 2529 - BIOS Version: 1.0R
If your system doesn`t show one or more of these symptoms we strongly recommend to update your system with the latest BIOS version available for download on our support pages.
Tehase garantii peaks olema mul 2 aastat. Aga kuna olen läpparit mitu korda laiali lammutanud, siis mida teha tuleks ja palju see parandus maksma läheks.
siLc
19.01.2009 18:11:47
| Teha tuleks seda, et vaadata kas saad asja esialgsesse seisundisse taastada. Kui seda teha pole võimalik, siis uue emaplaadi ja töö maksumuse hinda uuri näiteks ServiceNet`st ja Fujitsu Services`st.
SeedX
21.01.2009 19:21:37
Kas tehase seadeid on võimalik taastada kui arvuti ei boodi windowsi, vaid jookseb kokku. Uut windowsi ei saa ka peale panna, jookseb kokku.
Parandus läheks mul maksma 6500.- + KM.
meelis63
22.01.2009 01:21:51
| ...kas wini pealelaskmisel probleeme ei esinenud? Asi lõhnab muidu ikka videokaardi vea järgi...siis olukord ikka nutune...
SeedX
22.01.2009 14:23:15
| Wini pealelaskmisel pidin läppari ühendama suure monitoriga, sest läppar näitas ainult poolikut pilti või üldse mitte midagi.
siLc
22.01.2009 14:31:32
| Betamax kirjutas: |
| Vii garantiisse. Sul tundub seal mingi tõsisem jama olevat. |
Ilmselt juba käidud
| SeedX kirjutas: |
| Parandus läheks mul maksma 6500.- + KM. |
SeedX
22.01.2009 17:33:55
| Mul peaks olema 2aastat tehasegarantiid, aga see vist ei loe kui ma olen arvuti mitu korda lahti teinud.
eddvin
23.02.2009 00:41:11
mul on täpselt sama jama, täpselt sama arvutiga
ma viisin remonti...öeldi et põhimõtteliselt võib läpaka minema visata, sest videokaarti ei ole see lihtsalt läks katki
birgit123
23.02.2009 00:51:50
| Garantii kehtib ka siis kui sa oled seda mitu korda ise kokku/lahti võtnud. Eeldusel, et sa ise kuidagi asja vigastanud ei ole. Too kui garantii alles ja füüsiliselt kõik korras , siis saada näiteks meile see masin. Äkki saab aidata www.kungla.ee
toivos
23.02.2009 11:26:57
| eddvin kirjutas: |
ma viisin remonti...öeldi et põhimõtteliselt võib läpaka minema visata, sest videokaarti ei ole see lihtsalt läks katki |
Ega tal eraldi videokaarti polegi. Kõik on emaplaadi peale joodetud.
_________________ Taastan datat katkistelt ketastelt ja katkistelt Flash(USB) mäludelt. Nüüd ka katkistelt SSD ketastelt. |
23.02.2009 11:40:47
Muide - selline nähtus, et läppari ekraanil pole pilti, kuid välise monitoriga on pilt, võib olla vabalt täiesti remonditav emaplaadi viga.
Alles paar päeva tagasi lappisin ühe HV-lase Fujitsu-Siemensi läppari emaplaati, millel enda ekraaniga pilt puudus, kuid välise ekraaniga oli pilt olemas.
Ja see konkreetne emaplaat oli täiesti remonditav
eddvin
23.02.2009 23:50:31
to toivos:
jah, minu viga, ega ei ole tõesti eraldi videokaarti. Vabandust aga ma ei tunne läpakaehitust eriti
Muidu on pilt mul olemas, aga kui läpakat sisse lülitada, siis on ekraanil triibud ja kui installida display driver, ei lähegi läpakas tööle
MONGO
25.02.2009 15:02:28
Mul on sama mudeliga sarnane probleem, uurisin natuke asja ja vastab täpselt netist leitud jamade kirjeldustele: ekraan hakkas jamama alguses harva, kord 10 käivituse peale näiteks, siis jama tihenes ja enam ei tööta üldse, suht kindel olen et emaplaadi viga, sest kui pilt ette tuli võisid väänata mispidi tahes ja ikka töötas.
Seda et masin ilusti üles buudib tean kindlalt sellest, et vindoosa startup meloodia käib paarkümmend seci peale käivitust. Netist laidsin ka, et paljudel hakkas jura peale ca aastavanuse masinaga, mul ta nii vana ongi.
Tõe huvides mainin ära et loll väikevend ajas arvutile peale rohke alkoholiga siirupise koksi, umbkaudu kuu või rohkem peale seda ta hakkas jamama ka, seepärast garantiiga parem tegemist ei tee, lisaks olen ka ise lahti võtnud teda ja mõne asja ära vahetanud.
Täna lähen uurima palju emme maksab, vahetaksin ise ära ta. Vahepeal tekkis ka hull plaan ehitada ta desktopiks ümber arvutit on vaja ja 10 k ei ole tõesti võtta mitte kuskilt, selline asi oleks võimalik juhul, kui kuskilt sobiv kasutatud emaplaat leida.
Nomore
27.02.2009 18:29:21
Keegi rääkis hiljuti, et tasub emaplaat puhtaks pesta kõigist suhkru- ja vedelikujääkidest, kui pärast vedeliku peale kallamist probleemid tekivad.
_________________ Eile nägin, kuidas mees teerulli alla jäi. Nüüd mul enam ühte jalga pole. |
cbr
01.12.2010 20:18:07
| tahanteada kirjutas: |
Ja see konkreetne emaplaat oli täiesti remonditav  |
Kuidas sa seda siis remontisid? Mul ühel Pa 1538-l on siin ekraan otsad andnud. Välise monitoriga üle DVI samas töötab. Tundub, et samasugune graafikakaardi jama.
01.12.2010 20:30:30
cbr: Seinast seina võimalused - nii nagu lähed seljavaluga kirurgi juurde - enne uuritakse - siis lüüakse nuga selga.
Nii ka läppari juures - kui lollusi põhjustab tolm, siis puhastad, kui on mõni jubin kutu, siis pead selle üles otsima ja nii edasi - ühtset retsepti ja ravimist olemas pole.
cbr
01.12.2010 20:33:29
Nojah, antud juhul tundub, et on graafikakaart kutu. Mida sina sel korral tegid? Oli see üldse üks neist mudelitest?
