ärihai
08.01.2009 23:15:20
jama full screeniga |
nimelt, kui tahad etv-st või tv3-st saateid vaadata siis on väikse aknana pilt olemas aga kui panna full siis on ainult must ekraan.
_________________ Ütle siis mõtle  |
Kommentaarid: 138 loe/lisa |
132 |
raul1978
08.01.2009 23:17:07
mis tv-kaart sul on ?
Kommentaarid: 41 loe/lisa |
36 |
ärihai
08.01.2009 23:36:15
ETV saadete arhiivi.
arvutil on peal vista.
132 |
doh
08.01.2009 23:42:13
tsitaat: |
When it comes to capturing the whole screen including the video, understanding why does the video part goes black is important. First of all it is due to the hardware acceleration enabled. Most of our modern systems have hardware acceleration of the video enabled which is good for performance enhancement but it doesnt allow you to do a print screen of the video part. To print screen including the video part, you have to disable the hardware acceleration of the video. |
XP jaoks saab seda maha võtta nii:
tsitaat: |
You can do it by Right clicking desktop > Properties > Settings > Advanced > Troubleshoot > Make the Hardware Acceleration to none. Now whenever you print screen, the video will be included in the print screen. Note: Please be sure to get back to full hardware acceleration because it improves your graphics performance. |
Vista kohta ei oska öelda.
EDIT: Väidetavalt ei saa seda Vistal maha võtta, siiski leidsin sellise howto Vista jaoks:
tsitaat: |
To disable graphics hardware acceleration:
1. Choose Start > Control Panel.
2. In the Appearance and Personalization section, click Adjust Screen Resolution.
3. Click Advanced Settings.
4. On the Troubleshooting tab, click Change Settings.
5. Move the Hardware Acceleration slider to None.
6. Click Apply and then click OK to accept the new setting and close the dialog box.
7. Click OK to close the Display Properties dialog box.
8. Restart Windows. |
Kommentaarid: 51 loe/lisa |
49 |
ärihai
09.01.2009 23:03:39
ok proovin järgi.
E: 4. On the Troubleshooting tab, click Change Settings.
Change Settings on hele ja sellele ei saa klikida
132 |
lisa lemmikuks |
