robiii
09.11.2008 16:50:29
settings.php |
Tere .
Väga loll probleem mul . Nimelt , tõmbasin skripti , täpselt naq encode explorer , aint rohkem lisasi , kuid põhimõte on sama .
INSTALL.txt on kirjas , muuda settings.php faili . Avasin , kuid ma ei saanud eriti aru kuidas täpselt muutma pean .
Sisu on selline :
<?php
define("SHOW_ICONS",true);
/* Defines if the script shows all hidden folders in linux
Hidden folders in linux are prefix with the '.' character with the exclusion of "." & ".."
Examples include /home/.mplayer
SHOW_LINUX_HIDDEN_FILES Options: true or false
define("SHOW_LINUX_HIDDEN_FILES",false);
/* The default path sets the path the script access when not parameterized (first load)
DEFAULT_PATH examples:
Linux: "/home/"
Windows: "C:\\Windows\\"
define("DEFAULT_PATH",".");
/* Root containment will ensure that the script does not traverse out of the root folder
ROOT_CONTAINMENT Options: true or false
ROOT_PATH examples:
Linux: "/home/"
define("ROOT_CONTAINMENT",true); // specifies if the script is allowed to traverse out of a folder
define("ROOT_PATH","/home/webadmin/witsdom.com.sg/html/phpelf/"); // specifies the path that the script is contained within
/* Logging will allow all operations to be logged
LOGGING Options: true or false
LOG_FILE examples:
Linux: "/home/"
Windows: "C:\\Windows\\myrequests.log"
define("LOGGING",false);
define("LOG_DIR","/home/webadmin/witsdom.com.sg/html/phpelf/logs/");
Oskate aidata ? Endal seee kõik PLANET.ee -s
Aeg maha 1p
09.11.2008 16:53:11
No seal on ju kommentaarid juures... täpselt nii peadki seal defineerima kõike. valid, kas "true" või "false" ning kus vaja, pead andma ka mingi pathi...
| Kommentaarid: 94 loe/lisa |
81 |
robiii
09.11.2008 17:07:41
| carlking kirjutas: |
| No seal on ju kommentaarid juures... täpselt nii peadki seal defineerima kõike. valid, kas "true" või "false" ning kus vaja, pead andma ka mingi pathi... |
sellest sain aru .
aga oskad näitena anda ? kui mul /htdocs/www/ ja seal need failid .
Sest nii kuidas ma panin , mina nii seda tööle ei saanud .
Aeg maha 1p
09.11.2008 17:26:11
ma ei ole planet.ee'ga kokku puutunud, aga netpointis tuli mul see full path kasutajatoe kaudu küsida, kuna ta oli tegelikkuses pikem kui ftp kliendiga või filemanageriga ise tuletades.
81 |
oicu
09.11.2008 17:30:14
| mismoodi ei saanud tööle. kas andis mingi errori ?
| Kommentaarid: 9 loe/lisa |
9 |
robiii
09.11.2008 17:34:13
| oicu kirjutas: |
| mismoodi ei saanud tööle. kas andis mingi errori ? |
Jah , aadressi real andis errori . http://xxx.planet.ee/www/index.php?op=error , kusjuures , ta refeshis seda lehte ja leht oli iseenesest tühi . lihtsalt refeshis ise automaatselt .
iceincube
09.11.2008 17:46:04
tee sinna kausta mingi php fail ja kirjuta sisse
<?php
echo getcwd();
ning navigeeri browseriga selle faili peale.
Siis saad teada selle vajaliku path-i.
Vähemalt peaks saama.
getcwd
| Kommentaarid: 39 loe/lisa |
37 |
robiii
09.11.2008 17:58:04
| iceincube kirjutas: |
<?php
echo getcwd();
getcwd |
tänud , sain
