mightythor
17.04.2008 05:17:26
lokaalvõrgus oleva arvuti pingimine üle interneti |
mul on kodus 3COM'i WL-525 ruuter, mille järel on siis kaks arvutit. Kui ma tahaksin nüüd näiteks ühte koduarvutit pingida, siis kuidas ma seda teha saakin? ICMP protokollil pole porti ning ma ei saa teda suunata. Teine võimalus mida mu ruuter pakub on mingi Special Applications, kuid see pole kah nagu päris see(pealegi peaksin ma seal samamoodi pordid seadistama).
Some software applications require special or multiple connections to the Internet and these would normally be blocked by the Firewall. For example Internet Telephony or Video conferencing require multiple connections.
So that these special applications can work properly and are not blocked, the firewall needs to be told about them. In each instance there will be a trigger port and incoming port(s), where traffic on the trigger port tells the Firewall to open the incoming ports.
Note: Each defined Special Application only supports a single PC user and up to 10 Special Applications can be defined.
Adding a Special Application
1. Press the New button.
2. Choose an application by making a selection from the pull-down menu.
3. Press the Add button.
Custom applications can be added to the Special Applications list.
1. Select Other from the pull-down menu list.
2. Enter a suitable name for the application.
3. Enter the Trigger Port.
4. Enter the Incoming Ports.
Note: A range of ports can be added by using '-' the hyphen character, with additional ports being added using a comma. For example: 1200-1300, 4001, 5000
5. Press the Add button.
Note: Pressing the Close button discards any entries made.
Modify an existing Special Application
1. Select the Application name link within the table.
2. Make the required modifications.
3. Press the Modify button.
Deleting a Special Application
1. Press the Delete button on the row corresponding to the application to be removed.
Note: Once an entry has been deleted it cannot be undone.
Enabling a Special Application
The Special Application will not become active unless the Enable tick box has been checked. A Special Application in the un-ticked state will be blocked by the Firewall.
Kolmas võimalus oleks vist keelata NAT ja siis kuidagi proovida. Või on see üldse teostatav, et üle interneti pingida lokaalvõrgus olevat masinat?
| Kommentaarid: 62 loe/lisa |
53 |
Smith
17.04.2008 09:34:50
Ja mida see ping sulle annab üldse? Tahad teada, et kas aparaat on sisse lülitatud?
_________________ Only the Central Computer knows the truth |
145 |
| Kommentaarid: 1159 loe/lisa |
725 |
wicked
17.04.2008 09:43:55
Osad linksysi ja trendneti purgid lasid läbi veebiliidese pingi kasutada. Ehk siis lubad ligipääsu veebiliidesele välisvõrgust (turvalisus?) ja logid sinna sisse ja pingid mida tahad. 3COM sarnast asja ei võimalda?
_________________ I prepared Explosive Runes this morning |
| Kommentaarid: 68 loe/lisa |
63 |
UrmasL
17.04.2008 10:33:35
Re: lokaalvõrgus oleva arvuti pingimine üle interneti |
| mightythor kirjutas: |
| mul on kodus 3COM'i WL-525 ruuter, mille järel on siis kaks arvutit. Kui ma tahaksin nüüd näiteks ühte koduarvutit pingida, siis kuidas ma seda teha saakin? ICMP protokollil pole porti ning ma ei saa teda suunata. |
Olenevalt sellest mis opsüsteemiga masinad on, suunad ruuterist kas RDP või SSH pordi ühele masinatest. Edaspidi logid siis masinasse ja sealt edasi teed LAN's mis tahad. Mis su eesmärk üldse on?
| Kommentaarid: 58 loe/lisa |
54 |
