uus teema   vasta Tarkvara »  Tarkvara »  Probleem Windows update'iga märgi kõik teemad loetuks
Geomees
sõnum 02.03.2008 00:18:09 Probleem Windows update'iga vasta tsitaadiga
Nimelt ei Windows ei installi uuendusi ära. (originaal Windows) Pilt järgmine:http://img409.imageshack.us/img409/5007/klklkjs9.pngWindows Genuine Advantage Validation Tool (KB892130) mul puudub. See jutt käis selle kohta, kui ma http://www.update.microsoft.com updaitisin.
Kui ma aga update'in taskbarilt, siis juhtub selline asi: http://img249.imageshack.us/img249/6790/fdfhdfja1.png
Kõik failid on järgmised, mis pildile ei mahtunud:
Security Update for Windows XP (KB928843)
Security Update for Windows XP (KB890859)
Security Update for Windows XP (KB944653)
Security Update for Windows XP (KB914389)
Security Update for Windows XP (KB920683)
Security Update for Windows XP (KB908519)
Security Update for Windows Media Player 11 for Windows XP (KB936782)
Update for Windows XP (KB894391)
Security Update for Windows XP (KB943055)
Security Update for Windows XP (KB935839)
Security Update for Windows XP (KB896428)
Security Update for Windows XP (KB913580)
Security Update for Windows XP (KB905749)
Security Update for Windows XP (KB908531)
Update for Windows XP (KB930916)
Critical Update for Windows XP (KB886185)
Security Update for Windows XP (KB943485)
Security Update for Windows XP (KB935840)
Security Update for Windows XP (KB920213)
Cumulative Security Update for Internet Explorer 6 for Windows XP (KB944533)
Security Update for Windows XP (KB938127)
Security Update for Windows XP (KB900725)
Update for Windows Media Player 11 for Windows XP (KB939683)
Update for Windows Media Format 11 SDK for Windows XP (KB929399)
Security Update for Windows XP (KB888302)
Security Update for Windows XP (KB941568)
Security Update for Windows XP (KB926255)
Security Update for Windows XP (KB918118)
Security Update for Outlook Express for Windows XP (KB941202)
Update for Windows XP (KB922582)
Security Update for Windows XP (KB901214)
Security Update for Windows XP (KB932168)
Security Update for Windows XP (KB905414)
Security Update for Windows XP (KB917344)
Security Update for Windows XP (KB914388)
Security Update for Windows XP (KB919007)
Security Update for Windows XP with Windows Media Format Runtime 9.5 and 11 (KB941569)
Security Update for Windows XP (KB930178)
Update for Windows XP (KB942763)
Update for Windows XP (KB920872)
Security Update for Windows XP (KB926436)
Security Update for Windows XP (KB890046)
Security Update for Windows XP (KB902400)
Security Update for Windows XP (KB918439)
Security Update for Windows XP (KB891781)
Cumulative Security Update for Outlook Express for Windows XP (KB929123)
Security Update for Windows XP (KB925902)
Security Update for Windows Media Player Plug-in (KB911564)
Update for Windows XP (KB910437)
Security Update for Windows Media Player 6.4 (KB925398)
Security Update for Windows XP (KB896358)
Security Update for Windows XP (KB938829)
Security Update for Windows XP (KB946026)
Update for Windows XP (KB936357)
Update for Windows XP (KB927891)
Security Update for Windows XP (KB941644)
Security Update for Windows XP (KB924496)
Security Update for Windows XP (KB873339)
Security Update for Windows XP (KB931261)
Security Update for Windows XP (KB924270)
Security Update for Windows XP (KB896423)
Security Update for Windows XP (KB924667)
Update for Windows XP (KB938828)
Security Update for Windows XP (KB911562)
Security Update for Windows XP (KB936021)
Security Update for Windows XP (KB911280)
Security Update for Windows XP (KB923980)
Security Update for Windows XP (KB893756)
Security Update for Windows XP (KB920685)
Security Update for Windows XP (KB933729)
Windows Malicious Software Removal Tool - February 2008 (KB890830)
Windows Internet Explorer 7 for Windows XP
Security Update for Windows XP (KB899591)
Security Update for Windows XP (KB901017)
Update for Windows XP (KB942840)
Security Update for Windows XP (KB911927)
Security Update for Windows XP (KB931784)
Security Update for Windows XP (KB928255)
Security Update for Windows XP (KB923414)
Security Update for Windows XP (KB885836)
Security Update for Windows XP (KB885835)
Security Update for Windows XP (KB922819)
Security Update for Windows XP (KB943460)
Security Update for Windows XP (KB927802)
Security Update for Windows XP (KB927779)
Security Update for Windows XP (KB899587)
Arvan, et update'id ei installi sellepärast, et mul puudub Windows Genuine Advantage Validation Tool. Ma ei saa aru, miks ei installi Windows Genuine Advantage Validation Tool ära, kuigi mul on originaal Windows. Siinkohal loodangi teie abile foorumlased
airm
sõnum 02.03.2008 11:58:30 vasta tsitaadiga
windows kataloogis on näha log laiendiga fail nimega midagi update või sordi kuupäeav järgi, leiad ülesse.
vaata viimaseid rida ja kasutada tuleb ka googlit.
Kommentaarid: 56 loe/lisa Kasutajad arvavad:  :: 2 :: 1 :: 50
AJ
AJ
sõnum 02.03.2008 14:17:12 vasta tsitaadiga
Security Update peaks igal juhu installima sõltumata sellest kas su kastis on WGA Validation Tool.
Geomees
sõnum 02.03.2008 14:47:34 vasta tsitaadiga
AJ kirjutas:
Jah, aga ma tahaksin, et teised updated ka installiks.
airm kirjutas:
Kahjuks ei saanud aru, mida on vaja teha,
TFD
sõnum 02.03.2008 23:31:52 vasta tsitaadiga
Sama probleem, keegi võiks mingisugust abi pakkuda...
airm
sõnum 02.03.2008 23:46:20 vasta tsitaadiga
windows kataloogis on fail, nimega "WindowsUpdate.log"
Seda sisu tuleks vaadata, kuna seal sisutihedamad errormessaged.
Ja kui sealt aru ei saada, siis arusaamatud mõisted goolisse torgata.
sõnum 03.03.2008 11:13:05 vasta tsitaadiga
Kas oled proovinud kõigepealt seda, et installid Validation Tooli eraldi, teed restardi ja seejärel installid ülejäänud uuendused?
M: Intel i5 4590 protsessorid
M: HP Elitedesk 800 G3 SFF
Kommentaarid: 751 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 564
Geomees
sõnum 03.03.2008 19:22:48 vasta tsitaadiga
ndk kirjutas:
Jah, proovisin. Alguses tundus kõik libedalt minevalt: update'id downloadisid (downloading ja siis läks natuke aega kuni tuli udate taha done ja võeti järgmine update ette). Jätsin siis ööseks tegema ja tulin hommikul vaatama ja vastu vaatas selline pilt:http://img114.imageshack.us/img114/9495/cmbbvzv9.png
Elar
sõnum 03.03.2008 20:23:28 vasta tsitaadiga
Tee järgmise sisuga .bat fail:
regsvr32 /s wuapi.dll
regsvr32 /s wuaueng1.dll
regsvr32 /s wuaueng.dll
regsvr32 /s wucltui.dll
regsvr32 /s wups2.dll
regsvr32 /s wups.dll
regsvr32 /s wuweb.dll
Käivita see. Endal on see korduvalt aidanud.
TFD
sõnum 03.03.2008 23:16:57 vasta tsitaadiga
Elar kirjutas:
Geomees
sõnum 04.03.2008 00:27:59 vasta tsitaadiga
Vabandust minu võhiklikuse pärast, kuid kuhu ja kuidas, tuleb see bat file teha?
sõnum 04.03.2008 00:36:03 vasta tsitaadiga
Tee tühi .txt fail Desktopile, kirjuta sinna sisse eelpool toodud read, salvesta, muuda laiend .bat ja tee ikoonil topeltklikk.
Geomees
sõnum 05.03.2008 22:18:37 vasta tsitaadiga
ndk kirjutas:
