Geomees
02.03.2008 00:18:09
Probleem Windows update'iga |
Nimelt ei Windows ei installi uuendusi ära. (originaal Windows) Pilt järgmine:http://img409.imageshack.us/img409/5007/klklkjs9.pngWindows Genuine Advantage Validation Tool (KB892130) mul puudub. See jutt käis selle kohta, kui ma http://www.update.microsoft.com updaitisin.
Kui ma aga update'in taskbarilt, siis juhtub selline asi: http://img249.imageshack.us/img249/6790/fdfhdfja1.png
Kõik failid on järgmised, mis pildile ei mahtunud:
Security Update for Windows XP (KB928843)
Security Update for Windows XP (KB890859)
Security Update for Windows XP (KB944653)
Security Update for Windows XP (KB914389)
Security Update for Windows XP (KB920683)
Security Update for Windows XP (KB908519)
Security Update for Windows Media Player 11 for Windows XP (KB936782)
Update for Windows XP (KB894391)
Security Update for Windows XP (KB943055)
Security Update for Windows XP (KB935839)
Security Update for Windows XP (KB896428)
Security Update for Windows XP (KB913580)
Security Update for Windows XP (KB905749)
Security Update for Windows XP (KB908531)
Update for Windows XP (KB930916)
Critical Update for Windows XP (KB886185)
Security Update for Windows XP (KB943485)
Security Update for Windows XP (KB935840)
Security Update for Windows XP (KB920213)
Cumulative Security Update for Internet Explorer 6 for Windows XP (KB944533)
Security Update for Windows XP (KB938127)
Security Update for Windows XP (KB900725)
Update for Windows Media Player 11 for Windows XP (KB939683)
Update for Windows Media Format 11 SDK for Windows XP (KB929399)
Security Update for Windows XP (KB888302)
Security Update for Windows XP (KB941568)
Security Update for Windows XP (KB926255)
Security Update for Windows XP (KB918118)
Security Update for Outlook Express for Windows XP (KB941202)
Update for Windows XP (KB922582)
Security Update for Windows XP (KB901214)
Security Update for Windows XP (KB932168)
Security Update for Windows XP (KB905414)
Security Update for Windows XP (KB917344)
Security Update for Windows XP (KB914388)
Security Update for Windows XP (KB919007)
Security Update for Windows XP with Windows Media Format Runtime 9.5 and 11 (KB941569)
Security Update for Windows XP (KB930178)
Update for Windows XP (KB942763)
Update for Windows XP (KB920872)
Security Update for Windows XP (KB926436)
Security Update for Windows XP (KB890046)
Security Update for Windows XP (KB902400)
Security Update for Windows XP (KB918439)
Security Update for Windows XP (KB891781)
Cumulative Security Update for Outlook Express for Windows XP (KB929123)
Security Update for Windows XP (KB925902)
Security Update for Windows Media Player Plug-in (KB911564)
Update for Windows XP (KB910437)
Security Update for Windows Media Player 6.4 (KB925398)
Security Update for Windows XP (KB896358)
Security Update for Windows XP (KB938829)
Security Update for Windows XP (KB946026)
Update for Windows XP (KB936357)
Update for Windows XP (KB927891)
Security Update for Windows XP (KB941644)
Security Update for Windows XP (KB924496)
Security Update for Windows XP (KB873339)
Security Update for Windows XP (KB931261)
Security Update for Windows XP (KB924270)
Security Update for Windows XP (KB896423)
Security Update for Windows XP (KB924667)
Update for Windows XP (KB938828)
Security Update for Windows XP (KB911562)
Security Update for Windows XP (KB936021)
Security Update for Windows XP (KB911280)
Security Update for Windows XP (KB923980)
Security Update for Windows XP (KB893756)
Security Update for Windows XP (KB920685)
Security Update for Windows XP (KB933729)
Windows Malicious Software Removal Tool - February 2008 (KB890830)
Windows Internet Explorer 7 for Windows XP
Security Update for Windows XP (KB899591)
Security Update for Windows XP (KB901017)
Update for Windows XP (KB942840)
Security Update for Windows XP (KB911927)
Security Update for Windows XP (KB931784)
Security Update for Windows XP (KB928255)
Security Update for Windows XP (KB923414)
Security Update for Windows XP (KB885836)
Security Update for Windows XP (KB885835)
Security Update for Windows XP (KB922819)
Security Update for Windows XP (KB943460)
Security Update for Windows XP (KB927802)
Security Update for Windows XP (KB927779)
Security Update for Windows XP (KB899587)
Arvan, et update'id ei installi sellepärast, et mul puudub Windows Genuine Advantage Validation Tool. Ma ei saa aru, miks ei installi Windows Genuine Advantage Validation Tool ära, kuigi mul on originaal Windows. Siinkohal loodangi teie abile foorumlased
airm
02.03.2008 11:58:30
windows kataloogis on näha log laiendiga fail nimega midagi update või sordi kuupäeav järgi, leiad ülesse.
vaata viimaseid rida ja kasutada tuleb ka googlit.
| Kommentaarid: 56 loe/lisa |
50 |
AJ
02.03.2008 14:17:12
Security Update peaks igal juhu installima sõltumata sellest kas su kastis on WGA Validation Tool.
| Kommentaarid: 37 loe/lisa |
36 |
Geomees
02.03.2008 14:47:34
| AJ kirjutas: |
| Security Update peaks igal juhu installima sõltumata sellest kas su kastis on WGA Validation Tool. |
Jah, aga ma tahaksin, et teised updated ka installiks.
| airm kirjutas: |
vaata viimaseid rida ja kasutada tuleb ka googlit. |
Kahjuks ei saanud aru, mida on vaja teha,
TFD
02.03.2008 23:31:52
| Sama probleem, keegi võiks mingisugust abi pakkuda...
airm
02.03.2008 23:46:20
windows kataloogis on fail, nimega "WindowsUpdate.log"
Seda sisu tuleks vaadata, kuna seal sisutihedamad errormessaged.
Ja kui sealt aru ei saada, siis arusaamatud mõisted goolisse torgata.
50 |
| Kommentaarid: 755 loe/lisa |
567 |
Geomees
03.03.2008 19:22:48
| ndk kirjutas: |
| Kas oled proovinud kõigepealt seda, et installid Validation Tooli eraldi, teed restardi ja seejärel installid ülejäänud uuendused? |
Jah, proovisin. Alguses tundus kõik libedalt minevalt: update'id downloadisid (downloading ja siis läks natuke aega kuni tuli udate taha done ja võeti järgmine update ette). Jätsin siis ööseks tegema ja tulin hommikul vaatama ja vastu vaatas selline pilt:http://img114.imageshack.us/img114/9495/cmbbvzv9.png
Aru ma ei saa mis viga on
Elar
03.03.2008 20:23:28
Tee järgmise sisuga .bat fail:
regsvr32 /s wuapi.dll
regsvr32 /s wuaueng1.dll
regsvr32 /s wuaueng.dll
regsvr32 /s wucltui.dll
regsvr32 /s wups2.dll
regsvr32 /s wups.dll
regsvr32 /s wuweb.dll
Käivita see. Endal on see korduvalt aidanud.
TFD
03.03.2008 23:16:57
| Elar kirjutas: |
Käivita see. Endal on see korduvalt aidanud. |
Aitäh Elar, see aitas igatahes mind
Geomees
04.03.2008 00:27:59
| Vabandust minu võhiklikuse pärast, kuid kuhu ja kuidas, tuleb see bat file teha?
567 |
Geomees
05.03.2008 22:18:37
| ndk kirjutas: |
| Tee tühi .txt fail Desktopile, kirjuta sinna sisse eelpool toodud read, salvesta, muuda laiend .bat ja tee ikoonil topeltklikk. |
Aitäh, sai korda
