praegune kellaaeg 29.11.2026 20:48:18
roheline25
16.01.2008 13:35:21
mida arvata Philips 37PFL5322 LCD telerist |
on kellelgi sellise teleriga kokkupuuteid olnud?
mida arvata sellest?
PHILIPS 37PFL5322
Product Description Philips 37PFL5322 - 37" LCD TV
Product Type LCD TV
Diagonal Size 37" - widescreen
Dimensions (WxDxH) 93.5 cm x 26.5 cm x 68.8 cm - with stand
Weight 28 kg
Colour Silver, high-gloss black
Country Kits United Kingdom, Ireland
Digital Television Certification HD ready
Resolution 1366 x 768
Display Format 720p
Input Video Formats 480p, 720p, 1080i, 480i, 576i, 576p
Video Interface Component, composite, HDMI, S-Video, SCART
Technology TFT active matrix
Progressive Scan Yes
Image Aspect Ratio 16:9
TV Tuner 1x analogue
Analogue TV Tuner NTSC, PAL, SECAM
Multi-channel Preview Double screen
Features Video noise reduction, Active control, Dynamic Contrast, 3:2 pulldown compensation, anti-reflection coating, 2:2 pulldown compensation, Colour Transient Improvement (CTI), Luminance Transient Improvement (LTI), Contrast Plus, Smart Picture Control, Smart Sound Control, Pixel Plus HD
Sound Output Mode Stereo
Speaker System 2 speakers
Sound Effects Dynamic Bass Enhancement (DBE), Incredible Surround
Stereo Reception System NICAM
Remote Control Remote control - infrared
Power AC 230V ( 50/60 Hz )
Detailed specifications - PHILIPS 37PFL5322
General
Product Type 37" LCD TV
Dimensions With stand
Width 93.5 cm
Depth 26.5 cm
Height 68.8 cm
Weight 28 kg
Enclosure Colour Silver, high-gloss black
Display
Display Format 720p
Dynamic Contrast Ratio 5000:1
Brightness 500 cd/m2
Progressive Scan Progressive scanning (line doubling)
Widescreen Modes Zoom 14:9, Zoom 16:9, Subtitle Zoom, Super Zoom, WideScreen, Conventional 4:3, Auto Wide
Viewing Angle 178 degrees
Viewing Angle (Vertical) 178 degrees
Pixel Response Time 6 ms
Comb Filter 3D digital
Colour Temperature Control Yes
TV Tuner
Reception System SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-I, PAL-D, SECAM-L, PAL-K
Video Features
HD Ready Yes
Analogue Video Input Signals NTSC, PAL, SECAM
Supported Computer Resolutions 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA)
Parental Channel Lock Yes
Remote Control
Type Remote control - infrared
Supported Devices TV
Audio System
Surround Mode Built-in
Equaliser Yes (7-band)
Speakers Included 2 speakers
Output Power / Total 20 Watt
Features Auto volume adjustment
Speaker(s) 2 x right/left channel speaker - built-in - 10 Watt
Connections
Connector Type 2 x HDMI ( 19 pin HDMI Type A ) - rear ¦ 1 x SCART (AV in/out / RGB) ( 21 PIN SCART ) - rear ¦ 1 x SCART (AV in/out / S-Video) ( 21 PIN SCART ) - rear ¦ 1 x audio line-in ( RCA phono x 2 ) - rear ¦ 1 x component video input ( RCA phono x 3 ) - rear ¦ 1 x headphones ( mini-phone stereo 3.5 mm ) - side ¦ 1 x S-Video input ( 4 PIN mini-DIN ) - side ¦ 1 x composite video/audio input ( RCA phono x 3 ) - side
madmel
16.01.2008 16:44:06
Juhul kui sa tahad järelmaksuga näiteks osta(või raha ei ole küsimus) siis soovitaks midagi 7 seeriast.Pildi protsessorid on paremad.
Hetkel ei oska midagi targemat öelda.
| Kommentaarid: 29 loe/lisa |
