praegune kellaaeg 16.09.2026 11:08:40
ranel
17.09.2007 23:57:22
dx9 taastamine |
http://www.3dcenter.de/downloads/files/cb46p71/directx-dx9uninstaller.zip
lasin siis selle prgrammi kunagi peale, et 3dmarkis skkorida. paraku tahaks nüüd aga paari dx9 nõudvat mängu mängida, aga peal on mul nüüd ainult dx8.1
niisiis ehk keegi oskab öelda, kuidas saaks dx9 peale(lihtsalt niisama install ei aita)
165 |
tom1245
18.09.2007 10:09:40
| suurel osal mängudel tavaliselt plaadil ka dx9 installer, kus dx9 installimist nõutakse ju mängu installeerimise käigus?
| Kommentaarid: 84 loe/lisa |
ranel
23.09.2007 21:57:41
| tom1245 kirjutas: |
| suurel osal mängudel tavaliselt plaadil ka dx9 installer, kus dx9 installimist nõutakse ju mängu installeerimise käigus? |
| ranel kirjutas: |
| (lihtsalt niisama install ei aita) |
keegi siis ei tea, kuidas saada dx9 tagasi?
165 |
-RaiTz-
25.09.2007 16:38:36
Proovi seda
First download the directx9.0c redist and the directx9.0b redist. when you have donwloaded you click on the files and you choose to extract it to a folder make a directx9.0c and directx9.0b folders on your desktop. once extracted your ready for next part.
You need to download directx eradicator which can be found by typing it on google or looking on the softpedia website. when you download save it to your desktop for easier access. when donwload is finished unzip the files and there will be a directx rollbacak and DXERAD file . double click on the DXERAD file and it will tell are you sure you want to uninstall directx say yes and then it will tell you the computer will restart. once restared the comp might take long for the desktop items to show up this is normal be patient( some errors might come up to). once you can see all the desktop items go into your directx9.0c folder you made. in here should be your extracted files for directx9.0c. copy all the .cab file ( the cabinet files into your directx9.0b folder you made and replace them with the ones already in the dirext x9.0b folder. now click on the dxinstall button IN THE DIRECT X 9.0B FOLDER. and it should install properly after that it will restart your computer. once its done go on start, run ,dxdiag and walaa directx9.0c
| Kommentaarid: 36 loe/lisa |
30 |
