uus teema   vasta Tarkvara »  Turvalisus »  Abi paluks. märgi kõik teemad loetuks
Cheetah
Cheetah
sõnum 01.05.2007 13:28:47 Abi paluks. vasta tsitaadiga
Niisiis, probleem selline. Vahest lihtsalt jookseb explorer.exe kokku. Mul on kaks partitsiooni, kui esimesele minna siis ei ole midagi aga teisele minnes kohe jookseb kokku ja peab explorer-i uuesti käivitama. Olen lasknud mitmete spyware programmidega jms üle, aga ükski asi ei leia midagi. Äkki keegi oleks hea ja vaataks Hijackthis-i log-i läbi, äkki seal midagi valesti icon_confused.gif
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: Megaupload Toolbar - {4E7BD74F-2B8D-469E-CCB0-B130EEDBE97C} - C:\PROGRA~1\MEGAUP~1\MEGAUP~1.DLL
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll
O2 - BHO: TGTSoft Explorer Toolbar Changer - {C333CF63-767F-4831-94AC-E683D962C63C} - C:\Program Files\TGTSoft\StyleXP\TGT_BHO.dll
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
O3 - Toolbar: Megaupload Toolbar - {4E7BD74F-2B8D-469E-CCB0-B130EEDBE97C} - C:\PROGRA~1\MEGAUP~1\MEGAUP~1.DLL
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\System32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\System32\NvMcTray.dll,NvTaskbarInit
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\ctfmon.exe
O4 - HKCU\..\Run: [DAEMON Tools] "C:\Program Files\DAEMON Tools\daemon.exe" -lang 1033
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'Default user')
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll
O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\System32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\System32\browseui.dll
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\System32\nvsvc32.exe
O23 - Service: StarWind iSCSI Service (StarWindService) - Rocket Division Software - C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
O23 - Service: StyleXPService - Unknown owner - C:\Program Files\TGTSoft\StyleXP\StyleXPService.exe
Igasugused ideed on oodatud, tahaks sellest jamast lahti saada.
Kommentaarid: 91 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 84
Lord Ami
Lord Ami
sõnum 01.05.2007 15:31:08 vasta tsitaadiga
Logi täiesti puhas.
Spyware eemaldajatest proovi veel näiteks seda:
http://www.superantispyware.com/downloadfile.html?productid=SUPERANTISPYWAREFREE
Cheetah
Cheetah
sõnum 01.05.2007 16:14:24 vasta tsitaadiga
Proovitud, ei leia midagi. Adaware ei leia midagi, spybot s&d ei leia midagi, fsecure ei leidnud ka midagi. Kas mingi programmiga saab üksikuid faile ka maha lasta? Mul ühe faili peal jookseb kokku
XYZ
XYZ
sõnum 01.05.2007 16:16:24 vasta tsitaadiga
Lord Ami kirjutas:
Logi täiesti puhas.
Kentsakas soovitus - seal logis vahib juba seesama ju vastu...
Nii tarbetut rämpsu täis arvutiga mina keelduks töötamast, ma ei imesta mitte üks raas, et too ebastabiilne on.
Cheetah
Cheetah
sõnum 01.05.2007 16:29:12 vasta tsitaadiga
Lasin alles siis peale selle proge kui juba asi piixus oli.
Lord Ami
Lord Ami
sõnum 01.05.2007 17:03:13 vasta tsitaadiga
Siis võid proovida mingi programmiga registrit parandada.
sõnum 01.05.2007 17:24:46 vasta tsitaadiga
Megaupload toolbar oli vanasti nuhkvara. Praeguste versioonidega pole kursis, aga ma ise seda küll ei usaldaks.
StyleXP koos oma kõigi vidinatega päris kindlasti süsteemi stabiilsust ei suurenda icon_rolleyes.gif
Cheetah
Cheetah
sõnum 01.05.2007 18:27:49 vasta tsitaadiga
Lord Ami kirjutas:
Mida näiteks?
E: Sain siis lõpuks failist lahti. Kui fail kustutatud lasin CCleaneriga üle ja leidis 268 probleemi icon_razz.gif Lasen teiste spyware asjadega ka üle. Sai arvuti korda lõppudelõpuks.
