Cheetah
01.05.2007 14:28:47
Abi paluks. |
Niisiis, probleem selline. Vahest lihtsalt jookseb explorer.exe kokku. Mul on kaks partitsiooni, kui esimesele minna siis ei ole midagi aga teisele minnes kohe jookseb kokku ja peab explorer-i uuesti käivitama. Olen lasknud mitmete spyware programmidega jms üle, aga ükski asi ei leia midagi. Äkki keegi oleks hea ja vaataks Hijackthis-i log-i läbi, äkki seal midagi valesti
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: Megaupload Toolbar - {4E7BD74F-2B8D-469E-CCB0-B130EEDBE97C} - C:\PROGRA~1\MEGAUP~1\MEGAUP~1.DLL
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll
O2 - BHO: TGTSoft Explorer Toolbar Changer - {C333CF63-767F-4831-94AC-E683D962C63C} - C:\Program Files\TGTSoft\StyleXP\TGT_BHO.dll
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
O3 - Toolbar: Megaupload Toolbar - {4E7BD74F-2B8D-469E-CCB0-B130EEDBE97C} - C:\PROGRA~1\MEGAUP~1\MEGAUP~1.DLL
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\System32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\System32\NvMcTray.dll,NvTaskbarInit
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\ctfmon.exe
O4 - HKCU\..\Run: [DAEMON Tools] "C:\Program Files\DAEMON Tools\daemon.exe" -lang 1033
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'Default user')
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll
O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\System32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\System32\browseui.dll
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\System32\nvsvc32.exe
O23 - Service: StarWind iSCSI Service (StarWindService) - Rocket Division Software - C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
O23 - Service: StyleXPService - Unknown owner - C:\Program Files\TGTSoft\StyleXP\StyleXPService.exe
Igasugused ideed on oodatud, tahaks sellest jamast lahti saada.
Kommentaarid: 91 loe/lisa |
84 |
Lord Ami
Kommentaarid: 57 loe/lisa |
52 |
Cheetah
01.05.2007 17:14:24
Proovitud, ei leia midagi. Adaware ei leia midagi, spybot s&d ei leia midagi, fsecure ei leidnud ka midagi. Kas mingi programmiga saab üksikuid faile ka maha lasta? Mul ühe faili peal jookseb kokku
84 |
XYZ
01.05.2007 17:16:24
Kentsakas soovitus - seal logis vahib juba seesama ju vastu...
Nii tarbetut rämpsu täis arvutiga mina keelduks töötamast, ma ei imesta mitte üks raas, et too ebastabiilne on.
Kommentaarid: 81 loe/lisa |
12 :: |
56 |
Cheetah
01.05.2007 17:29:12
Lasin alles siis peale selle proge kui juba asi piixus oli.
84 |
Lord Ami
01.05.2007 18:03:13
Siis võid proovida mingi programmiga registrit parandada.
52 |
01.05.2007 18:24:46
Megaupload toolbar oli vanasti nuhkvara. Praeguste versioonidega pole kursis, aga ma ise seda küll ei usaldaks.
StyleXP koos oma kõigi vidinatega päris kindlasti süsteemi stabiilsust ei suurenda
Kommentaarid: 33 loe/lisa |
Cheetah
01.05.2007 19:27:49
Lasin mõlemad maha, kuid ikka sama
Lord Ami kirjutas: |
Siis võid proovida mingi programmiga registrit parandada. |
Mida näiteks?
E: Sain siis lõpuks failist lahti. Kui fail kustutatud lasin CCleaneriga üle ja leidis 268 probleemi Lasen teiste spyware asjadega ka üle. Sai arvuti korda lõppudelõpuks.
Tänan abistajaid
84 |
lisa lemmikuks |
