Bam Margera
11.01.2003 17:00:16
Kui kõrgele võib videokaarti klokata??? |
| kas võib klokata maximumini?
| Kommentaarid: 56 loe/lisa |
51 |
kk
11.01.2003 17:01:45
| Sa lased selle kaardi niimodi varsti läbi. Inimestel ka muud teha ei ole...
7 :: |
94 |
Vidget
11.01.2003 17:15:32
IRW:
Klokkama hakatakse jah maximumist ja siis minnakse lahjematele tasemetele. 8)
Kasuta Otsingut!!!
128 |
bigmarx
11.01.2003 17:25:54
link :: vanem teema
see peaks kõik ütlema
_________________ "Kes naerab viimasena? Ma olen siis teie järel!" |
| Kommentaarid: 485 loe/lisa |
385 |
Nu
11.01.2003 18:21:29
mis asi on maximum?
minu kogemused näitavad (mitmete eri kaartidega) et kui kaart enam ei kannata, jookseb masin lihtsalt kokku. P***e pole veel ühtegi keeranud.
_________________ DO you want it.. And if you had it would you flaunt it...
ss |
157 |
Siil udus
11.01.2003 18:23:20
| proovi ära hakka vaikselt tõstma ja muud midagi
| Kommentaarid: 28 loe/lisa |
25 |
Elitegamer
11.01.2003 21:52:58
If your current videocard isn't fast enough there is always a way to make it a little bit faster by running the 3D chip core on a faster tact-frequency. This way you can pump up your average Framerate a little bit. Is overclocking really a must ? Nah, not really ... you card works fine. At its default speed. And with today's fast videocard technology you really won't know much difference in Frames Per Second significant .. Still it is fun to push you card to the limit. And by all means, some of you might actually do see a difference in FPS. On this page we will supply you with some information about Overclocking your 3D card. Overclocking is a something that should be done on a wise and proper manner. We take no responsibility in everything noted within this page. If you decide to overclock your card then that is your choice and the consequences are for your own risk.
All chipsets are made within a safety margin regarding its default clockspeed. Voodoo one cards had a default core of 55 Mhz, Voodoo2 had a default tact-frequency core of 90MHz. When you cool down your card a bit with a little fan or heatsink (fan is preferred) then it is in general relatively safe to overclock within a 10% margin of your default clockspeed. The key to a good and relatively safe overclocking process is to make sure that your card is cooled so it can not overheat itself.
Things have changed for the better. Graphics processor units have a much higher core-frequency and memory can be clocked much higher. Examples of the most used NVIDIA videocards:
GeForce2 MX 166/175MHz Core 166/175MHz memory
GeForce2 GTS 200MHz core/333MHz memory
GeForce2 Pro 200 MHz core/400 MHz memory
GeForce2 Ultra 250 MHz core/460 MHz memory
All these videocards core and memory can be increased by about 10%
If you are going to overclock the take the following steps :
Cool your card, preferably with a Cooling fan. If not available use a heatsink on the fan. (most videocards have these already)
Make sure that you stay within a 10% limit of your default clockspeed
Overclock you card in small steps. From ex. 200Mhz to 210Mhz. Test your card by playing a game for a while. If nothing happens, then go up another 5Mhz. and so on until you reach the 10% limit.
If you notice bad polygons or other strange glitches while using your 3D card then you have seriously reached the limit. Go down at least 5Mhz to be safe and try again.
If your card locks out (black screen) then follow step down 5 to 10 MHz from your last setting.
If you smell something weird ... hey turn your computer of like the speed of light and prey that your 3D chips aren't fried.
Point 6 seems a bit steep. I have never experienced this before (and I overclocked and tested a lot), but it doesn't mean it can't happen.
There are several programs around that can alter some settings on your 3D videocard.
Coolbits :
We'll keep this short and simple , coolbits is a registry patch that allows for an extra tab in your driver that allows you to overclock your NVIDIA videocard.
If you download this patch and click on it after downloading it will modify your Registry to enable the hardware Option Tab.
As you can see, it allows you to overclock both the core and the RAM. Be careful when overclocking and try not to go to overboard as it can damage your card.
Personally I think the little extra performance gained by overclocking isn't justified by the amount of extra pressure you put on your card.
If you have a Leadtek Card however , you don't need to download coolbits as Leadtek have been generous enough to include an overclocking utility of it's own. The "Speed Runner"
Above : Leadteks Speed Runner , use this instead of Coolbits if you have a Leadtek card.
Other manufacturers have similar utilities. You can also use a third party utility like our GeForce Tweak Utility or RivaTuner to swiftly overclock and tweak your NVIDIA videocard.
Other videocards like Matrox, Radeon and 3dfx should look into our downlaod section where some nice utils are on-line.
allikas: www.guru3d.com
maximumini saab kellata ainult siis kui selleks on hea cooler! sellega mis alguses kaasa pannakse ei ole see võimalik(vist)
kui ma omale gf4 ti4400 ostsin,lugesin onu tomi teste ja vaatasin et memory oli 700 klokitud ja ma oma lolli peaga lükkasin kah slideri 700 peale ja masin jooksis kolinal kokku(mängu sees)
Wiltz
11.01.2003 22:26:30
no eriline tarkpea, leidsid mingi hea texti mida copy pasteerida
teen lühidalt, seda, mis on kaardi maximum, SINA ei tea!
SINA klokid senimaani, kuni tulevad "asjad", mis hakkavad SIND häirima. See, et hakka vaixelt tõstma, on jura! Tõsta minu poolest 2X, mitte midagi ei juhtu, peale selle, et mazin jooxeb korra kokku. Loogiline piir on vast mingi 10-30% algkiirusest juurde lükata. Kuna eeldan, et sa pole selle asjaga just palju tegelenud, sis alusta 10, 15%'st.
Jah, võid maximumini klokata! Enne leia see maximum;)
9 :: |
226 |
Elitegamer
12.01.2003 00:01:14
| Wiltz kirjutas: |
Jah, võid maximumini klokata! Enne leia see maximum;) |
mul üle 10% pani pange
VR53
12.01.2003 00:15:40
| Elitegamer kirjutas: |
mul üle 10% pani pange |
mul 46% t88tas puhtalt, 50+% ei saanud 3Dga hakkama
_________________ Uued Lenovo sülearvutid: www.lenovoarvutid.ee - kasuta koodi "HINNAVAATLUS", et saada 50€ alla P14s Gen 6 R7 hinnast!
| Kommentaarid: 842 loe/lisa |
636 |
Elitegamer
12.01.2003 00:18:57
| CMaster kirjutas: |
mul 46% t88tas puhtalt, 50+% ei saanud 3Dga hakkama |
mis kuuleriga?
soodent
12.01.2003 00:19:51
| Enamus kaarte üle 15% ei jookse.Mul neid erinevaid geforcesid küll olnud ja stabiilsus kaob üle 20% jooksutades.Ti 200 paistab olema erandlikum ,kui foorumit uskuda.Samas on siin luuluvendi rihmaks.Eks agp volti kägistatakse max ja osa driverite optione disabletakse.Pole näinud ,et mälude jahutamine palju aitaks.
| Kommentaarid: 822 loe/lisa |
19 :: |
6 :: |
564 |
VR53
12.01.2003 00:25:14
mis kuuleriga? |
mingi 40x40x10 kakajunn, mille ma oma P100 ruuterilt maha kookisin...
636 |
Tuhkur
12.01.2003 02:02:14
...kerge offtopic jälle aga...see sõltub muidugi kaardist...aga palju neid punne max juurde tuleb? mingi paarsada?
3dmark'is...
| Kommentaarid: 10 loe/lisa |
XR
| Kommentaarid: 49 loe/lisa |
42 |
Plin500
HV piljardihai
12.01.2003 13:53:34
| Tuhkur kirjutas: |
3dmark'is... |
no ikka mingi paar tuhat...nt. gf4 Ti-4200
| Kommentaarid: 79 loe/lisa |
77 |
Wiltz
12.01.2003 15:26:29
paar tuhat? no see oleneb of course kaardist, klokist. kellel tuleb paarkymmend, kellel paartuhat!
paartuhat võib öelda sellisex umbkaudsex maximumix vast. Keskmisex tulemusex praeguste kaartidega, keskmise kellaja puhul panex ikka vast mingi 500 pointi, isegi vb nati alla selle(kui keskmisex tulemusex võtta kuskil 8,9,10k)
no võib ka vist öelda, et minu käest neid kaarte ikka on läbi käinud, ja ausalt öeldes on olnud üks kaart, mis ei kannatanud 10% klokki, see oli kyro2(arvan, et seal olid omad põhjused;)
Kõik ülejäänud kaardid on tegelikult(videomälu silmas pidades) kannatanud vähemalt 20% kanti klokki, radeon muidugi pinge tõstmise abil, mis on loomulik(alapinge ei saagi tähendada suurt klokki!)
9 :: |
226 |
acer
12.01.2003 18:44:18
loogika ütleb, et: niikaua, kuna masin pildi taskusse paneb
| Kommentaarid: 35 loe/lisa |
33 |
margo1
19.01.2003 17:36:32
| Mis moodi neid videokaarte clockida saab ja milleks sea hea on?
traks
304 |
