Bad Sector
10.01.2003 10:23:04
Hulk kasulikku vabavara!!! |
Vabavaralised programmid
Siia teemasse postitada linke vabavaralistele programmidele ... lisada võiks ka seletuse millega tegu on ja milleks antud programm hea on. Kõik muu siia kirjutatu kuulub kustutamisele.
Renka: Muutsin teemat
| Kommentaarid: 29 loe/lisa |
25 |
t-force
| Kommentaarid: 27 loe/lisa |
22 |
paranoid
13.08.2004 10:39:57
Siit peaks vist kõike leidma:
http://www.freewarefiles.com/
_________________ Powered by: AMD, Gigabyte,ATI, Chieftech, A-DATA, Intel, NEC |
| Kommentaarid: 22 loe/lisa |
20 |
2III7
| Kommentaarid: 162 loe/lisa |
146 |
droz
| Kommentaarid: 4 loe/lisa |
nene
13.08.2004 18:48:11
sourceforge rohkem arendajatele...
paljuski parem on www.freshmeat.net, a windowsi kasutajad peavad hulga linuxi programme vast välja filtreerima. Ja noh seal pole ka igasugu Alpha-staadiumis projekte.
| Kommentaarid: 24 loe/lisa |
23 |
313 |
MarkoV
| Kommentaarid: 31 loe/lisa |
31 |
paranoid
15.08.2004 14:00:03
DVD Decrypter - One of the best DVDDecrypter tool, it enables you to decrypt and copy DVDs to your HD. It can also make DVD images and burn DVD and CD images.
/*Freeware*/
http://www.dvddecrypter.com/
EDIT by Tanel: As you might know, Sonique.com has shut down the website for a while.
This would make a nice addition and reminder to it: https://www.videoproc.com/resource/what-happened-to-dvddecrypter.htm
20 |
AMD
| Kommentaarid: 335 loe/lisa |
145 :: |
12 |
Eraser
30 |
paranoid
17.08.2004 00:08:17
Kõik ühes servus...PHP4, MySQL jne jne...
Ning kõik see tasuta:
http://www.yellowtip.com/products/yellowtipws.php
See on YellowTip Web Server v2.0.0
The YellowTip Web Server was developed to make available a highly professional and easily installable package of Apache, PHP4, MySQL4, phpMyAdmin and Zend Optimizer for the Windows platform (Win98, WinMe, Win2K, WinXP).
With a convenient all-in-one installer, all components are installed in a single directory and can be used immediately after the installation process has completed. An uninstaller allows you to remove the YellowTip WebServer from your computer.
During the installation process you can chose which components you wish to install.
The YellowTip Web Server allows you to run complex php based web applications from your own Windows computer. Even php applications that have been encoded by Zend Encoder are able to run on the YellowTip webserver as Zend Optimizer is part of the installation.
Due to high demand, the developers have included some of the most popular Open Source packages with WebServer 2.0. PostNuke, phpBB and Gallery are just some of the packages that are (optionally) installed and configured.
20 |
HacaX
18.08.2004 01:08:27
Kuna OSi ei täpsustatud ja aeg-ajalt tuleb inimsudel ette ka DOSiga mässamist, siis viskaks kolm sobivat(?) linki:
http://home.att.net/~short.stop/freesoft/softlib1.htm - legendaarne Richard L. Greeni kogu mis sisaldab üle 700 proge kirjelduse ja lingi.
http://cyberside.dyn.ee/files/ - FreeDOSi failiarhiivi Eesti peegeldus
http://ubcd.sourceforge.net - Ultimate Boot CD - buutiv plaat täis kõikvõimalikku tasuta kraami mida arvuti parandamisel võiks vaja minna: antiviirused, partitsioneerijad, testimissoft, etc etc etc.
22 |
Raulj
| Kommentaarid: 14 loe/lisa |
14 |
marqs
22.08.2004 16:52:24
paljud hakkavad nädala pärast mat analüüside, lin algebrade jms imelises maailmas oma kohta otsima
eriti vahvas seisus on need, kel omal ajal valik kutsekooli kasuks langes ja/või eelmisest diplomist rohkem kui aasta mööda läinud.
ehk on keset osatuletisi, maatrikse ja polünoome abi MuPAD'ist, selle CAS'i vanemad light versioonid on tasuta linuxile ning winile.
paar lihtsamat näidet dokustaatidest:
>> equations := {x + y = 1, x - y = 1}:
>> solve(equations)
{[x = 1, y = 0]}
>> f := (1 + (sin(x)^2 + cos(x)^2)^2)/sin(x):
>> f=simplify(f)
2 2 2
(cos(x) + sin(x) ) + 1 2
sin(x) sin(x)
>> f := y^2 + 4*x + 6*x^2 + 4*x^3 + x^4
2 3 2 4
4 x + 6 x + 4 x + y + x
>> diff(f, x)
2 3
12 x + 12 x + 4 x + 4
>> diff(f, y)
2 y
>> int(f, x = 0..1)
y + 26/5
kõige muu hulgas on asi abiks ka pindade ja joonte ette manamiseks.
_________________ 0xDEAD
0xBEEF |
| Kommentaarid: 28 loe/lisa |
AMD
23.08.2004 14:48:10
SystemRescueCd
QtParted & PartGui => PartitionMagic'u kloonid
lisaks veel palju palju huvitavaid asju...
_________________ From now on, the forum is owned by AMD.That means that you are NO LONGER allowed to talk about, or even mention *ntel. |
145 :: |
12 |
Notsu
suur13
185 |
AMD
31.08.2004 11:55:37
selle eest ei pea vist eraldi maksma
Windows XP ® eestikeelse kasutajaliidese pakett
Eestikeelse kasutajaliidese pakett Windows XP Professionali või Windows XP Home Editioni jaoks muudab suurema osa Windows XP kasutajaliidesest eestikeelseks.
145 :: |
12 |
CommandsRef
14 |
borru
03.09.2004 13:24:28
PHP tegelitskitele:
mps php designer
Minu raudne lemmik windowsi all, kuna ta ei ruuna mu raali, võtab kettaruumi 1MB jagu, ja on tasuta.
http://www.mpsoftware.dk/software_php.htm
Võimaldab vajadusel ka SQL ja html vaadet kasutada... ehk siis värvib ka need koodid ilustid ära.
screenshot
| Kommentaarid: 13 loe/lisa |
AMD
19.09.2004 21:32:37
What is xine?
xine is a free multimedia player. It plays back CDs, DVDs, and VCDs. It also decodes multimedia files like AVI, MOV, WMV, and MP3 from local disk drives, and displays multimedia streamed over the Internet. It interprets many of the most common multimedia formats available - and some of the most uncommon formats, too.
145 :: |
12 |
paranoid
30.09.2004 22:30:33
BitComet |
Minu meelest parim client BitTorrentile:
BitComet
http://www.bitcomet.com/
20 |
keytron
| Kommentaarid: 58 loe/lisa |
54 |
Ho Ho
26.10.2004 15:00:20
| FSF/UNESCO Free Software Directory. Mõni(enamus?) proge sealt töötab ka wini keskkonnas ning peale selle et nad on tasuta on ka kood saadaval kui kellelgi peaks tahtmist olema.
86 |
