Bad Sector
10.01.2003 10:23:04
Hulk kasulikku vabavara!!! |
Vabavaralised programmid
Siia teemasse postitada linke vabavaralistele programmidele ... lisada võiks ka seletuse millega tegu on ja milleks antud programm hea on. Kõik muu siia kirjutatu kuulub kustutamisele.
Renka: Muutsin teemat
| Kommentaarid: 29 loe/lisa |
25 |
t-force
| Kommentaarid: 27 loe/lisa |
22 |
paranoid
13.08.2004 10:39:57
Siit peaks vist kõike leidma:
http://www.freewarefiles.com/
_________________ Powered by: AMD, Gigabyte,ATI, Chieftech, A-DATA, Intel, NEC |
| Kommentaarid: 22 loe/lisa |
20 |
2III7
| Kommentaarid: 170 loe/lisa |
152 |
droz
| Kommentaarid: 4 loe/lisa |
nene
13.08.2004 18:48:11
sourceforge rohkem arendajatele...
paljuski parem on www.freshmeat.net, a windowsi kasutajad peavad hulga linuxi programme vast välja filtreerima. Ja noh seal pole ka igasugu Alpha-staadiumis projekte.
| Kommentaarid: 24 loe/lisa |
23 |
313 |
MarkoV
| Kommentaarid: 31 loe/lisa |
31 |
paranoid
15.08.2004 14:00:03
DVD Decrypter - One of the best DVDDecrypter tool, it enables you to decrypt and copy DVDs to your HD. It can also make DVD images and burn DVD and CD images.
/*Freeware*/
http://www.dvddecrypter.com/
EDIT by Tanel: As you might know, Sonique.com has shut down the website for a while.
This would make a nice addition and reminder to it: https://www.videoproc.com/resource/what-happened-to-dvddecrypter.htm
20 |
AMD
| Kommentaarid: 335 loe/lisa |
145 :: |
12 |
Eraser
30 |
paranoid
17.08.2004 00:08:17
Kõik ühes servus...PHP4, MySQL jne jne...
Ning kõik see tasuta:
http://www.yellowtip.com/products/yellowtipws.php
See on YellowTip Web Server v2.0.0
The YellowTip Web Server was developed to make available a highly professional and easily installable package of Apache, PHP4, MySQL4, phpMyAdmin and Zend Optimizer for the Windows platform (Win98, WinMe, Win2K, WinXP).
With a convenient all-in-one installer, all components are installed in a single directory and can be used immediately after the installation process has completed. An uninstaller allows you to remove the YellowTip WebServer from your computer.
During the installation process you can chose which components you wish to install.
The YellowTip Web Server allows you to run complex php based web applications from your own Windows computer. Even php applications that have been encoded by Zend Encoder are able to run on the YellowTip webserver as Zend Optimizer is part of the installation.
Due to high demand, the developers have included some of the most popular Open Source packages with WebServer 2.0. PostNuke, phpBB and Gallery are just some of the packages that are (optionally) installed and configured.
20 |
HacaX
18.08.2004 01:08:27
Kuna OSi ei täpsustatud ja aeg-ajalt tuleb inimsudel ette ka DOSiga mässamist, siis viskaks kolm sobivat(?) linki:
http://home.att.net/~short.stop/freesoft/softlib1.htm - legendaarne Richard L. Greeni kogu mis sisaldab üle 700 proge kirjelduse ja lingi.
http://cyberside.dyn.ee/files/ - FreeDOSi failiarhiivi Eesti peegeldus
http://ubcd.sourceforge.net - Ultimate Boot CD - buutiv plaat täis kõikvõimalikku tasuta kraami mida arvuti parandamisel võiks vaja minna: antiviirused, partitsioneerijad, testimissoft, etc etc etc.
22 |
Raulj
| Kommentaarid: 14 loe/lisa |
14 |
marqs
22.08.2004 16:52:24
paljud hakkavad nädala pärast mat analüüside, lin algebrade jms imelises maailmas oma kohta otsima
eriti vahvas seisus on need, kel omal ajal valik kutsekooli kasuks langes ja/või eelmisest diplomist rohkem kui aasta mööda läinud.
ehk on keset osatuletisi, maatrikse ja polünoome abi MuPAD'ist, selle CAS'i vanemad light versioonid on tasuta linuxile ning winile.
paar lihtsamat näidet dokustaatidest:
>> equations := {x + y = 1, x - y = 1}:
>> solve(equations)
{[x = 1, y = 0]}
>> f := (1 + (sin(x)^2 + cos(x)^2)^2)/sin(x):
>> f=simplify(f)
2 2 2
(cos(x) + sin(x) ) + 1 2
sin(x) sin(x)
>> f := y^2 + 4*x + 6*x^2 + 4*x^3 + x^4
2 3 2 4
4 x + 6 x + 4 x + y + x
>> diff(f, x)
2 3
12 x + 12 x + 4 x + 4
>> diff(f, y)
2 y
>> int(f, x = 0..1)
y + 26/5
kõige muu hulgas on asi abiks ka pindade ja joonte ette manamiseks.
_________________ 0xDEAD
0xBEEF |
| Kommentaarid: 28 loe/lisa |
AMD
23.08.2004 14:48:10
SystemRescueCd
QtParted & PartGui => PartitionMagic'u kloonid
lisaks veel palju palju huvitavaid asju...
_________________ From now on, the forum is owned by AMD.That means that you are NO LONGER allowed to talk about, or even mention *ntel. |
145 :: |
12 |
Notsu
suur13
| Kommentaarid: 204 loe/lisa |
189 |
AMD
31.08.2004 11:55:37
selle eest ei pea vist eraldi maksma
Windows XP ® eestikeelse kasutajaliidese pakett
Eestikeelse kasutajaliidese pakett Windows XP Professionali või Windows XP Home Editioni jaoks muudab suurema osa Windows XP kasutajaliidesest eestikeelseks.
145 :: |
12 |
CommandsRef
| Kommentaarid: 15 loe/lisa |
15 |
borru
03.09.2004 13:24:28
PHP tegelitskitele:
mps php designer
Minu raudne lemmik windowsi all, kuna ta ei ruuna mu raali, võtab kettaruumi 1MB jagu, ja on tasuta.
http://www.mpsoftware.dk/software_php.htm
Võimaldab vajadusel ka SQL ja html vaadet kasutada... ehk siis värvib ka need koodid ilustid ära.
screenshot
| Kommentaarid: 13 loe/lisa |
AMD
19.09.2004 21:32:37
What is xine?
xine is a free multimedia player. It plays back CDs, DVDs, and VCDs. It also decodes multimedia files like AVI, MOV, WMV, and MP3 from local disk drives, and displays multimedia streamed over the Internet. It interprets many of the most common multimedia formats available - and some of the most uncommon formats, too.
145 :: |
12 |
paranoid
30.09.2004 22:30:33
BitComet |
Minu meelest parim client BitTorrentile:
BitComet
http://www.bitcomet.com/
20 |
keytron
| Kommentaarid: 58 loe/lisa |
54 |
Ho Ho
26.10.2004 15:00:20
| FSF/UNESCO Free Software Directory. Mõni(enamus?) proge sealt töötab ka wini keskkonnas ning peale selle et nad on tasuta on ka kood saadaval kui kellelgi peaks tahtmist olema.
87 |
tsonn
05.11.2004 15:22:09
väga tugev matemaatikakeskond on scilab http://scilabsoft.inria.fr/ , millega tehakse asju algebrast kuni matemaatiliste mudeliteni.
_________________ elu nagu hernesto |
Adebisi
55 |
tsonn
rait_1
miga
09.02.2005 11:18:17
Leidsin ühe toreda saiti, kus on toodud The 46 Best-ever Freeware Utilities nii, et võite ise ette kujutada, mis seal on. Ise tõmbasin endale parima Trojan Scanner/Trojan Remover'i millel nimeks Ewido Security Suite ja pean tõdema, et see on ikka kuradi asjalik vähemalt siiamaani olen ma kasutanud igasugu trojan remove staffi jne, kuid tundub, et see proge on väga põhjalik...soovitan Ainult väike puudus on ...see kestab 14.päeva, kuid tasub proovimist...ise arvasin, et masin on puhas, sest scannin ja puhastan seda iga paari päeva tagant spysweeper, spyboti etc progedega, kuid võta näpust...leidub ikka kenasti trojaneid ja veel igasugu mudinaid.
| Kommentaarid: 35 loe/lisa |
33 |
muhv
02.03.2005 12:56:30
Üks pisike utiliit, mis lubab suvalise proge system traysse minimeerida (Ctrl + click minimiseerimise nupul akna ülaservas).
Tray It : http://www.teamcti.com/trayit/trayit.htm (for NT/2000/XP/95/98/Me)
_________________ * Tarkus on relv mida ei tohi anda lolli kätte!
* Kõige hullem on vägisi targaks tehtud loll!
* Pole olemas lollikindlaid asju, kuna lollid on kõige leidlikumad! |
| Kommentaarid: 7 loe/lisa |
Elof
175 |
muhv
08.03.2005 11:44:13
Veebitegijatele ja PNG failide kasutajatele väike utiliit, millega saab PNG-s olevat infot muuta (näiteks IE jaoks muuta hall taust värv valgeks või mingiks muuks, vastavalt milline on lehe taust)
TweakPNG: http://entropymine.com/jason/tweakpng/
borru
12.03.2005 21:53:32
Nvu - parim teadaolev WYSIWYG html editor. Vabavara loomulikult.
põhineb samal koodil millel firefox.
daddo
24.05.2005 07:33:18
http://www.hamachi.cc/
idee järgi P2P programmike, lubab p2p-tehnoloogial luua sul üle inetrneti arvutite vahel VPN (LAN) võrke... Enamus nat'e ja firewalle ei peaks segama... seega peaks päris huvitav asjake olema...
ksl
25.05.2005 08:30:39
kui tekib isu ekraani pöörata, siis on sobiv iRotate
kui sul on kaks arvutit (idee järgi suvalise op-süsteemiga, mina proovisin kahe XPpro peal) ja on soov ühe klaviatuuri ja hiirega neid mõlemaid kasutada, siis peaks sobima Synergy
_________________ KES SOOVIB, SEE PROOVIB |
muhv
12.07.2005 19:14:23
Haagi FTP kaust failisüsteemi, nagu kõvaketas või CDROM. näiteks X: -> ftp.ttu.ee
Tasuta jagatakse selleks otstarbeks sellist programmi nagu NetDrive
Installer: http://www.acs.uwosh.edu/novell/netdrive.exe
Veidi infot: http://www.acs.uwosh.edu/novell/netdrive.htm
Kui on vaja faile kustutada, kuid aastad et see on hoops "lukustatud" mingi programmi poolt, siis on kasulik programm Unlocker (freeware)
v6sa
91 |
ZerOZer05
anti66
25.07.2005 13:44:16
http://www.horstmann.com/violet/
A simple UML editor, suitable for students and casual users. GPL Java source code included.
_________________ M: Hanssen S.L.G PROFI x osaline köögiriistade komplekt
M: Compaq Contura Aero 4/25 SERIES 2830, FCC ID: CNT75MBZE (Kõvaketas arvatavasti rikkis) - http://andi.planet.ee/aero/compaq.php |
| Kommentaarid: 8 loe/lisa |
FuN
| Kommentaarid: 32 loe/lisa |
24 |
-vodafone-
23.08.2005 22:02:02
Soft32 Palju häid programme kasulik kõigile
217 |
anti66
26.10.2005 20:36:46
http://www.openworkbench.org/
Projektihaldustarkvara a la MS Project, avab ka MS Projecti XML formaadis faile.
Asterix
| Kommentaarid: 10 loe/lisa |
10 |
droz
21.11.2005 19:41:06
| RoundCube Webmail is a browser-based multilingual IMAP client with an application-like user interface. It provides full functionality you expect from an e-mail client, including MIME support, address book, folder manipulation and message filters. RoundCube Webmail is written in PHP and requires the MySQL database. The user interface is fully skinnable using XHTML and CSS 2. |
minu arvates ülikõva webmail, asi alles alfa aga paljulubav
Yorick
punktiir
| Kommentaarid: 49 loe/lisa |
38 |
alecoqprem
09.03.2006 23:35:06
üks küsimus - kas ma võin nendelt lehtedelt downloaditud freeware'i ka oma lehele üles riputada või peab selleks tootjalt luba küsima vms
24 |
Ho Ho
09.03.2006 23:51:11
| alecoqprem kirjutas: |
üks küsimus - kas ma võin nendelt lehtedelt downloaditud freeware'i ka oma lehele üles riputada või peab selleks tootjalt luba küsima vms  |
Oleneb softi tegijate poolt seatud tingimustest.
Üldiselt eks ta ilus oleks enne järgi küsida. Siis ehk saavad su lehe isegi oma peeglite alla seada ning sellest saavad teisedki kasu
87 |
anti66
13.03.2006 15:23:12
link :: JImageMapper
Selline java utiliit - leidsin Sourceforgest - JImageMapper.
Lihtne asi - Image Map' koostamiseks HTML koodis IMG jaoks.
viimati muutis anti66 12.12.2006 09:55:18, muudetud 1 kord |
