praegune kellaaeg 13.09.2026 11:38:34
Johnny.B.Goode
09.01.2003 22:39:36
Monitori USB jama |
| Ostsin monitori Samsung 959 NF. Monitor on ühendatud ka arvuti usb pesasse sest sest monitoril oli kaasas ka mingi programm Mouscreen millega pidi siis veel eraldi monitori reguleerida saama. Kui panen programmi tööle ütleb arvuti (mouscreen needs an usb monitor to function no usb monitor was dedected). Milles probleem.
Tõnu
10.01.2003 17:53:11
selle programmiga saad teha täpselt samu häälestusi mis ekraanimenüüst, ainult et hiirega.
help'is on kirjas sellina vastus su küsimusele:
Q) I cannot run the program.
A) Check to ensure the USB port of the monitor is connected to a root port or a hub USB port connected to the computer.
If not connected properly, the MouScreen program will not run, displaying the following message:
#Figure7-1> "No USB Monitor Is Detected" Message
If you see the above message even when the monitor port is duly connected to the computer, this means the operating system does not recognize the USB monitor. In this case, disconnect and then reconnect the USB port before running the program. The operating system will now recognize the USB monitor.
| Kommentaarid: 92 loe/lisa |
89 |
