praegune kellaaeg 10.11.2026 00:42:42
MadMan
14.04.2006 00:35:28
SMART raw data analüüs |
kui mul on ports selliseid numbreid:
10 00 01 0B 00 64 64 01 00 00 00 00 00 00 03 07
00 4C 4C 80 11 00 00 00 00 00 04 32 00 64 64 56
02 00 00 00 00 00 05 33 00 FD FD 00 00 00 00 00
00 00 07 0B 00 FD FD 00 00 00 00 00 00 00 08 24
00 FD FD 00 00 00 00 00 00 00 09 32 00 64 64 82
E9 01 00 00 00 00 0A 13 00 FD FD 00 00 00 00 00
00 00 0C 32 00 64 64 3A 01 00 00 00 00 00 C2 22
00 91 64 1F 00 00 00 00 00 00 C3 0A 00 64 64 42
88 DD 02 00 00 00 C4 12 00 FD FD 00 00 00 00 00
00 00 C5 33 00 FD FD 00 00 00 00 00 00 00 C6 31
00 FD FD 00 00 00 00 00 00 00 C7 0B 00 64 64 12
00 00 00 00 00 00 C8 0B 00 64 64 00 00 00 00 00
00 00 C9 0B 00 64 64 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 40 0B 00 1B
03 00 01 7F 01 30 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 81
siis millega seda analüüsida saaks?
Enamus SMART tööriistu tahavad kõvakettale ligi pääseda, kuid antud kettad asuvad PCI RAIDi taga ja pole IDE kaudu nähtavad.
_________________ Ikka Saab
~~NetMusique~~ |
| Kommentaarid: 31 loe/lisa |
29 |
pppd
14.04.2006 11:25:21
smartmontools muidu peaks oskama linuxi all 3ware kontrolleri taga olevad kettaid näha (linux ja 3ware on oletused, tehtud Su varasemates postitustes olnud infi põhjal).
3ware enda knowledgebase mainib selle SMART-info kohta ainult et "To determine the meaning of the SMART data, you will have to download documentation from the web sites of the disk drive manufacturers", mis eriti palju edasi muidugi ei aita.
Üks (väike) lohutus on muidugi ka see, et kuigi 3DM2 ise eriti selle SMART-i info kasutaja jaoks dekodeerimisega vaeva ei näe, peab kontroller ise siiski kõikide ketaste SMART-info üle arvet ja kui mingi parameeter punasesse läheb siis hakkab oma logisse nutma. E-mail notification on igal juhul abiks peale panna
