uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  ati radeon 7000 + minu arvuti... märgi kõik teemad loetuks
Autist
sõnum 02.10.2005 13:59:56 ati radeon 7000 + minu arvuti... vasta tsitaadiga
Tere... Kavatsen sõbra käest osta ati radeon 7000 videokaardi, aga pole kindel, kas see mu mitte heale ning vanale arvutile üldse sobib...
Aida 32'st võetud andmed: (pole kindel, mida täpselt kopida, nii et panen mitu erinevat siis....
Motherboard Properties
Motherboard ID <DMI>
Motherboard Name Compaq Deskpro EP/SB Series
Front Side Bus Properties
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 100 MHz
Effective Clock 100 MHz
Bandwidth 800 MB/s
Memory Bus Properties
Bus Type SDR SDRAM
Bus Width 64-bit
Real Clock 100 MHz
Bandwidth 800 MB/s
Motherboard Manufacturer
Company Name Hewlett-Packard Company
Product Information http://www.compaq.com
BIOS Download http://support.hp.com
CPU Properties
CPU Type Intel Pentium III, 550 MHz (5.5 x 100)
CPU Alias Katmai, A80525
CPU Stepping kC0
Original Clock 550 MHz
L1 Code Cache 16 KB
L1 Data Cache 16 KB
L2 Cache 512 KB (Built-In, Half-Speed)
CPU Physical Info
Package Type 242 Contact SEC Cartridge
Package Size 12.82 cm x 6.28 cm x 1.64 cm
Transistors 9.5 million
Process Technology 5M, 0.25 um, CMOS
Die Size 128 mm2
Chipset Properties
Motherboard Chipset Intel 82440BX/ZX
In-Order Queue Depth 4
CAS Latency 3T
RAS To CAS Delay 3T
RAS Precharge 3T
Memory Slots
DRAM Slot #1 64 MB (SDRAM)
DRAM Slot #2 64 MB (SDRAM)
DRAM Slot #3 64 MB (SDRAM)
AGP Properties
AGP Version 1.00
AGP Status Enabled
AGP Aperture Size 64 MB
Supported AGP Speeds 1x, 2x
Current AGP Speed 2x
Fast-Write Not Supported
Side Band Addressing Supported, Disabled
Chipset Manufacturer
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/chipsets.htm
Driver Download http://support.intel.com/support/chipsets/index.htm
Suured tänud.
eShelobik
eShelobik
sõnum 02.10.2005 14:11:09 vasta tsitaadiga
peaks töötama ilusti see radeon 7000
Kommentaarid: 296 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 263
Riivo
Riivo
sõnum 02.10.2005 14:20:01 vasta tsitaadiga
99% et töötab
-vodafone-
-vodafone-
sõnum 03.10.2005 16:01:50 vasta tsitaadiga
100% et töötab kui kaart katski ei ole
Kommentaarid: 247 loe/lisa Kasutajad arvavad:  :: 1 :: 3 :: 217
