uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AGP disabletud? märgi kõik teemad loetuks
superior
sõnum 01.09.2005 21:07:56 AGP disabletud? vasta tsitaadiga
Field Value
North Bridge Properties
North Bridge VIA VT8377A Apollo KT400A
Revision 80
Package Type 664 Pin HSBGA
Package Size 3.5 cm x 3.5 cm
Process Technology 0.22 um
Core Voltage 2.5 V
In-Order Queue Depth 4
Memory Controller
Bank Interleave 4-way
Memory Timings
CAS Latency (CL) 2T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 6T
Command Rate (CR) 2T
Memory Slots
DRAM Slot #1 256 MB (PC3200 DDR SDRAM)
AGP Controller
AGP Version 3.05
AGP Status Disabled
AGP Device nVIDIA GeForce4 MX 440 with AGP8X
AGP Aperture Size 128 MB
Supported AGP Speeds 1x, 2x, 4x, 8x
Fast-Write Not Supported
Side Band Addressing Supported, Disabled
Chipset Manufacturer
Company Name VIA Technologies, Inc.
Product Information http://www.via.com.tw/en/products/chipsets
Driver Download http://www.viaarena.com/?PageID=2
Problems & Suggestions
Problem AGP is disabled. This may cause performance penalty.
Problem AGP aperture size is more than half of the system memory size. This may cause performance penalty.
Everest väidab niimoodi :S
Kuidas enableda seda?
Kommentaarid: 139 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 130
Mirage
sõnum 02.09.2005 10:08:42 vasta tsitaadiga
Emaplaadi AGP/chipset draiverid peal? icon_wink.gif
Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
Kommentaarid: 81 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 74
Riivo
Riivo
sõnum 02.09.2005 14:13:43 vasta tsitaadiga
http://www.viaarena.com/Driver/VIA_HyperionPro_V500A.zip
proovi seda, peaks aitama
Cooler(-10)
sõnum 03.09.2005 18:03:24 vasta tsitaadiga
See jah miski via jama. Endal oli ka sellega probleeme, et agp4 ei läind tööle. Kuskilt guru3d lehelt saad miski fixi mis asja korda teeb.
Kommentaarid: 15 loe/lisa Kasutajad arvavad:  :: 2 :: 5 :: 5
Mirage
sõnum 05.09.2005 08:46:01 vasta tsitaadiga
Cooler(-10) kirjutas:
Piisab agp draiverite pealelaskmisest icon_rolleyes.gif see ongi kogu fix icon_wink.gif
