uus teema   vasta Tarkvara »  Turvalisus »  Viiruste eemaldamine märgi kõik teemad loetuks
Skyline
sõnum 28.02.2005 08:46:06 Viiruste eemaldamine vasta tsitaadiga
Niisiis tegin nortoniga online scani ja ledis sellised asjad.
C:\WINDOWS\BTGrab.dll is infected with Adware.BetterInternet
C:\WINDOWS\lvmer.dll is infected with Adware.CWSIEFeats
C:\WINDOWS\naz.scr is infected with W32.HLLW.Niklas
C:\WINDOWS\n_mqpkmj.txt is infected with Adware.CWSIEFeats
C:\WINDOWS\n_mwkqov.dat is infected with Adware.CWSIEFeats
C:\WINDOWS\n_nxlzpm.log is infected with Adware.CWSIEFeats
C:\WINDOWS\n_tiqwnk.txt is infected with Adware.CWSIEFeats
C:\WINDOWS\n_toyddp.txt is infected with Adware.CWSIEFeats
C:\WINDOWS\prijc.dll is infected with Adware.CWSIEFeats
C:\WINDOWS\sduuif.exe is infected with Adware.StartPage
C:\WINDOWS\sfee.exe is infected with Adware.EliteBar
C:\WINDOWS\system32\mfcpk.dll is infected with Adware.CWSIEFeats
C:\WINDOWS\system32\msfb.dll is infected with Adware.CWSIEFeats
C:\WINDOWS\system32\noqrm.dll is infected with Adware.CWSIEFeats
C:\WINDOWS\isrvs\sysupd.dll is infected with Download.Trojan
C:\WINDOWS\EliteSideBar\EliteSideBar 08.dll is infected with Adware.EliteBar.B
C:\WINDOWS\Downloaded Program Files\v3.dll is infected with Adware.EliteBar.B
C:\WINDOWS\Downloaded Program Files\CONFLICT.1\v3.dll is infected with Adware.EliteBar.B
C:\Documents and Settings\Kristjan\Local Settings\Temp\iinstall.exe is infected with Adware.Istbar!Dl
C:\Documents and Settings\Kristjan\Local Settings\Temp\optimize.exe is infected with Adware.NetOptimizer
C:\Documents and Settings\Kristjan\Local Settings\Temp\sa44.tmp.exe is infected with Download.Adware
C:\Documents and Settings\Kristjan\Local Settings\Temp\sidefind.exe is infected with Adware.Istbar!Dl
C:\Documents and Settings\Kristjan\Local Settings\Temp\webrebates.exe is infected with Adware.WebRebates
C:\Documents and Settings\Kristjan\Local Settings\Temp\THI3A09.tmp\BTGrab.dll is infected with Adware.BetterInternet
C:\Documents and Settings\Kristjan\Local Settings\Temp\THI363D.tmp\BTGrab.dll is infected with Adware.BetterInternet
Osasid asju ei saa neist eemaldada.Aga usun ,et selle vastu aitab safe mode.
Siin on ka näha "trojan"Küsisksin seda kas piisab selle faili kustutamisest(safe modes) ja ka registri tyhjendamisest?
Ja on ka mitmed failid nakatunud ..kuidas sellest lahti saada.
Kommentaarid: 27 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 20
2A
2A
sõnum 28.02.2005 10:30:18 vasta tsitaadiga
Sul ju kõik seal infected with adware...
Kas Windowsisse pääsed ainult läbi Safe Mode'i?
Kui ei, siis lihtsalt AdAware'iga arvuti üle lasta ja siis see trojan maha võtta icon_rolleyes.gif
Kommentaarid: 86 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 60
weyx13
weyx13
sõnum 28.02.2005 12:12:46 vasta tsitaadiga
http://www.intermute.com/spysubtract/cwshredder_download.html
Lase CWShredderiga üle, neid CoolWebSearchi värgid tunduvad ka sees olema
Kangur
sõnum 28.02.2005 19:21:36 vasta tsitaadiga
System restore... disable.
arnis
arnis
sõnum 01.03.2005 21:46:15 vasta tsitaadiga
Enne mine uninstalli mõned programmid ja
alles siis mine nende failide kustutamise peale.
Teen kodudes elektriasju korda. 40€/h. Anna murest märku.
Ooteajad hetkel suured (üle kuu)
Ka korteriühistud ja ettevõtted. Auditi ettevalmistused.
Kommentaarid: 120 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 117
Skyline
sõnum 02.03.2005 23:58:47 vasta tsitaadiga
Nüüdseks olen saanud kõik välja peale trooja.
Ehk on mõned soovitused?Hakkan foorumit läbi kammima nüüd,vbla leian midagi vajalikku endale.
weyx13
weyx13
sõnum 03.03.2005 02:33:42 vasta tsitaadiga
http://securityresponse.symantec.com/avcenter/venc/data/download.trojan.html#removalinstructions
Siit saad abi
Skyline
sõnum 03.03.2005 22:23:05 vasta tsitaadiga
Jah sealt otsitud abi..nüüd enam-vähem nagu korras.Kuid Internet Exploreri avamisel tuleb ette "error report" ja küsib seda "send" või "don't send" + IE on jube aeglane.(Põmst ise kasutan firefox ,aga tore oleks kui IE ka korda saaks.)
weyx13
weyx13
sõnum 04.03.2005 13:24:33 vasta tsitaadiga
mida ta "saata" või "mitte saata" tahab? Mis seal täpselt kirjas on? Kas ta ei püüa lihtsalt Microsoftile su probleemist teadet saata?
Skyline
sõnum 04.03.2005 16:00:17 vasta tsitaadiga
See tuleb ette igal käivitamisel.
arnis
arnis
sõnum 04.03.2005 17:18:34 vasta tsitaadiga
Proovi veel eemaldada asju
C:/windows/Downloaded Program Files
Skyline
sõnum 04.03.2005 17:25:28 vasta tsitaadiga
Seal küll midagi silma ei j22nud..paar macromedia shocwave asja.Sama asi (eelneval pildil) tuleb ka ette kazza käivitamisel.
arnis
arnis
sõnum 04.03.2005 19:23:16 vasta tsitaadiga
Kirjutada run dialoogi sfc /scannow
Skyline
sõnum 04.03.2005 20:53:34 vasta tsitaadiga
arnis kirjutas:
Ja mis on selle tulemus?
HacaX
HacaX
sõnum 04.03.2005 21:06:59 vasta tsitaadiga
Win kontrollib oma DLLid/EXEd üle ja kui mingid juhtuvad vigased olema siis kopeerib plaadilt (teada-tuntud) korras olevad.
Isiklikult soovitaks ka register ära puhastada, mõnigi kord aitab ka see...
IMO & GPLed
