Skyline
28.02.2005 08:46:06
Viiruste eemaldamine |
Niisiis tegin nortoniga online scani ja ledis sellised asjad.
tsitaat: |
C:\WINDOWS\BTGrab.dll is infected with Adware.BetterInternet
C:\WINDOWS\lvmer.dll is infected with Adware.CWSIEFeats
C:\WINDOWS\naz.scr is infected with W32.HLLW.Niklas
C:\WINDOWS\n_mqpkmj.txt is infected with Adware.CWSIEFeats
C:\WINDOWS\n_mwkqov.dat is infected with Adware.CWSIEFeats
C:\WINDOWS\n_nxlzpm.log is infected with Adware.CWSIEFeats
C:\WINDOWS\n_tiqwnk.txt is infected with Adware.CWSIEFeats
C:\WINDOWS\n_toyddp.txt is infected with Adware.CWSIEFeats
C:\WINDOWS\prijc.dll is infected with Adware.CWSIEFeats
C:\WINDOWS\sduuif.exe is infected with Adware.StartPage
C:\WINDOWS\sfee.exe is infected with Adware.EliteBar
C:\WINDOWS\system32\mfcpk.dll is infected with Adware.CWSIEFeats
C:\WINDOWS\system32\msfb.dll is infected with Adware.CWSIEFeats
C:\WINDOWS\system32\noqrm.dll is infected with Adware.CWSIEFeats
C:\WINDOWS\isrvs\sysupd.dll is infected with Download.Trojan
C:\WINDOWS\EliteSideBar\EliteSideBar 08.dll is infected with Adware.EliteBar.B
C:\WINDOWS\Downloaded Program Files\v3.dll is infected with Adware.EliteBar.B
C:\WINDOWS\Downloaded Program Files\CONFLICT.1\v3.dll is infected with Adware.EliteBar.B
C:\Documents and Settings\Kristjan\Local Settings\Temp\iinstall.exe is infected with Adware.Istbar!Dl
C:\Documents and Settings\Kristjan\Local Settings\Temp\optimize.exe is infected with Adware.NetOptimizer
C:\Documents and Settings\Kristjan\Local Settings\Temp\sa44.tmp.exe is infected with Download.Adware
C:\Documents and Settings\Kristjan\Local Settings\Temp\sidefind.exe is infected with Adware.Istbar!Dl
C:\Documents and Settings\Kristjan\Local Settings\Temp\webrebates.exe is infected with Adware.WebRebates
C:\Documents and Settings\Kristjan\Local Settings\Temp\THI3A09.tmp\BTGrab.dll is infected with Adware.BetterInternet
C:\Documents and Settings\Kristjan\Local Settings\Temp\THI363D.tmp\BTGrab.dll is infected with Adware.BetterInternet
Osasid asju ei saa neist eemaldada.Aga usun ,et selle vastu aitab safe mode.
Siin on ka näha "trojan"Küsisksin seda kas piisab selle faili kustutamisest(safe modes) ja ka registri tyhjendamisest?
Ja on ka mitmed failid nakatunud ..kuidas sellest lahti saada.
Kommentaarid: 27 loe/lisa |
20 |
2A
28.02.2005 10:30:18
vaevalt selle ühe trojani kustutamine aitab
Sul ju kõik seal infected with adware...
Kas Windowsisse pääsed ainult läbi Safe Mode'i?
Kui ei, siis lihtsalt AdAware'iga arvuti üle lasta ja siis see trojan maha võtta
Kommentaarid: 86 loe/lisa |
60 |
weyx13
Kangur
28.02.2005 19:21:36
System restore... disable.
Kommentaarid: 2 loe/lisa |
arnis
01.03.2005 21:46:15
Enne mine uninstalli mõned programmid ja
alles siis mine nende failide kustutamise peale.
_________________ Teen kodudes elektriasju korda. 40€/h. Anna murest märku.
Ooteajad väiketööd nädala jooksul, päev+ tööd kuu jooksul.
Ka korteriühistud ja ettevõtted. Auditi ettevalmistused. |
Kommentaarid: 120 loe/lisa |
117 |
Skyline
02.03.2005 23:58:47
Nüüdseks olen saanud kõik välja peale trooja.
Ehk on mõned soovitused?Hakkan foorumit läbi kammima nüüd,vbla leian midagi vajalikku endale.
20 |
weyx13
Skyline
03.03.2005 22:23:05
Jah sealt otsitud abi..nüüd enam-vähem nagu korras.Kuid Internet Exploreri avamisel tuleb ette "error report" ja küsib seda "send" või "don't send" + IE on jube aeglane.(Põmst ise kasutan firefox ,aga tore oleks kui IE ka korda saaks.)
20 |
weyx13
04.03.2005 13:24:33
mida ta "saata" või "mitte saata" tahab? Mis seal täpselt kirjas on? Kas ta ei püüa lihtsalt Microsoftile su probleemist teadet saata?
Skyline
04.03.2005 16:00:17
See tuleb ette igal käivitamisel.
20 |
arnis
04.03.2005 17:18:34
Proovi veel eemaldada asju
C:/windows/Downloaded Program Files
kaustast, võibolla on seal pahareti jäänus
117 |
Skyline
04.03.2005 17:25:28
Seal küll midagi silma ei j22nud..paar macromedia shocwave asja.Sama asi (eelneval pildil) tuleb ka ette kazza käivitamisel.
20 |
arnis
04.03.2005 19:23:16
Kirjutada run dialoogi sfc /scannow
kui sul on WinXP plaat olemas
117 |
Skyline
04.03.2005 20:53:34
arnis kirjutas: |
kui sul on WinXP plaat olemas  |
Ja mis on selle tulemus?
20 |
HacaX
04.03.2005 21:06:59
Win kontrollib oma DLLid/EXEd üle ja kui mingid juhtuvad vigased olema siis kopeerib plaadilt (teada-tuntud) korras olevad.
Isiklikult soovitaks ka register ära puhastada, mõnigi kord aitab ka see...
Kommentaarid: 24 loe/lisa |
22 |
