CnZ
02.09.2004 21:42:42
DELL 21' - Sony Trinitron p1130 |
Tahaks teada, kas on mõttetu 3999.- välja minna selle eest, kui on 2001 oktoobris reliisitud ja garantii 3 kuud.
Või on midagi muud paremat monitori, mida osta?
Kommentaarid: 14 loe/lisa |
Arvo Cobrietti
Kommentaarid: 39 loe/lisa |
37 |
CnZ
02.09.2004 22:46:02
Seal sai ainult 2/5. Või mis?
CnZ
02.09.2004 22:56:12
I cannot recommend this monitor due to reliability problems (see below). The P1130 does have a Sony Trinitron tube, but is manufactured in Mexico, unlike the actual Sony GDM-series monitors, which I've been told are manufactured in Japan. I would not purchase another P1130.
UPDATED:
I'm now on my third P1130 via warranty exchanges. The first one had developed color problems and finally died (no power) eight months after new. I received a refurbished replacement that only lasted a few weeks before developing a focus problem (would get very blurry intermittently). The second replacement was a brand new unit and so far (only had it a few days now) seems to be functioning properly.
About the Author
bhos13
a member of Epinions
Reviews Written: 1
CnZ
02.09.2004 23:06:53
Siin jällegi positiivne: http://www.epinions.com/content_53524336260
Ja nagu aru saan, on tal kineskoop Sony G520 oma. Standartites on pandud 1600 x 1200 @ 85Hz, kuid siin see sepp väidab, et sai 104Hz panna. Ja max reso on ka kirjutatud suurem osa kohtades 1600 x 1200, kuid mõndades jällegi 2048 x 1536.
I'm confused :\
Arvo Cobrietti
03.09.2004 10:22:54
kuna ta seal väidab et 130kHz siis peaks saama küll jah 1600*1200@100 jooksutada, täpsemalt ei viicind uurida, aga kui suur sagedus mingil resol, saab just selle kHz järgi paika panna.
kõige parem on nii, et kohapeal vaatad mõne normi videokaardiga, kuidas pilt on (geomeetria, brightness/contrast, teravus keskel ja servades (kuigi trinil seal nii suurt vahet ei ole nagu shadow maskil, et must ikka musta värvi oleks jne.). kui need paigas, siis tegemist väga hea monitoriga
kui ära hooratud siis kauple hinda alla kõwasti
37 |
Novembre
03.09.2004 10:57:21
CnZ,
Kas plaanid arvutiväravast osta? Neil oli 2tk sees ja ühe neist viisin koju . Arvata võib, et parema nendest. Teisel oli probleemi kokkujooksuga alumises osas. Võib olla annab see paika sättida. Erinevalt Sony G400 saab P1130-l kokkujooksu reguleerida keskel, üleval, all eraldi. Ma ise ka arvasin, et seal on G520 sees. Aga nüüd sügavalt kahtlen selles. G seeria torud on mustad, sellel hall (väljalülitatud) . Kuigi pilt on . See et sony on sees on 100%.
Kasutan 1280x1024@85Hz. Võrreldes G400 silmad kohe puhkavad.
Mulle tundub, et vähemalt see minu oma ei ole eriti piinatud ja on igati heas seisukorras. Võib öelda nagu uus. Aint mõned transportimis kriimud.
Kommentaarid: 108 loe/lisa |
102 |
lisa lemmikuks |
