uus teema   vasta Hinnavaatlus »  Multimeedia- ja helifoorum »  Media Player jamab.. märgi kõik teemad loetuks
Rajareits
Rajareits
sõnum 29.07.2004 12:09:26 Media Player jamab.. vasta tsitaadiga
Kõik palylistid, mis ma kustutan, jäävad media palyeris playlistide alla alles, kaustast kusutvad. Kuidas saaks neid playliste kustutada? Edit playlistiga saab ainult playlistidest laule kustutada, aga mitte palylisti ennast. Oskab keegi aidata? icon_rolleyes.gif
Jama on nii MP 9 ja 10-ga.
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 69
Rajareits
Rajareits
sõnum 29.07.2004 13:13:41 vasta tsitaadiga
Anyone?
bigbossu16
bigbossu16
sõnum 29.07.2004 18:51:26 vasta tsitaadiga
Bad Sector
sõnum 29.07.2004 23:08:38 vasta tsitaadiga
WMP helpist:
To delete a playlist:
Click Media Library, and then, in the Contents pane, expand My Playlists.
Click the playlist you want to delete, and then do one of the following:
Click the Delete button, and then click Delete Playlist.
Right-click the playlist you want to delete, and then click Delete.
If prompted, choose one of the following options:
Delete from Media Library only
Delete from Media Library and my computer
Note
When a playlist is selected in Media Library, the Select Playlist Options button  is displayed at the bottom of the Details pane. You can click the button to display a menu of playlist options that contains the following commands: Edit Playlist, Delete Selected, Clear, Sort, Open, Save As, and Copy to CD or Device. The Select Playlist Options button is also available in Now Playing.
Kommentaarid: 29 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 25
Rajareits
Rajareits
sõnum 30.07.2004 00:01:36 vasta tsitaadiga
Bad Sector, tänud Sulle! Kust Sa selle informatsiooni leidsid?
Bad Sector
sõnum 30.07.2004 10:12:36 vasta tsitaadiga
Rajareits kirjutas:
Mediaplayeri enda helpist loomulikult... see on üldiselt esimene koht kuhu peaks probleemide ilmnemisel vaatama icon_wink.gif
