praegune kellaaeg 02.04.2026 19:18:58
Rajareits
29.07.2004 11:09:26
Media Player jamab.. |
Kõik palylistid, mis ma kustutan, jäävad media palyeris playlistide alla alles, kaustast kusutvad. Kuidas saaks neid playliste kustutada? Edit playlistiga saab ainult playlistidest laule kustutada, aga mitte palylisti ennast. Oskab keegi aidata?
Jama on nii MP 9 ja 10-ga.
| Kommentaarid: 74 loe/lisa |
69 |
Rajareits
29.07.2004 12:13:41
| Anyone?
69 |
bigbossu16
29.07.2004 17:51:26
ei oska kahjuks
| Kommentaarid: 6 loe/lisa |
Bad Sector
29.07.2004 22:08:38
WMP helpist:
To delete a playlist:
Click Media Library, and then, in the Contents pane, expand My Playlists.
Click the playlist you want to delete, and then do one of the following:
Click the Delete button, and then click Delete Playlist.
Right-click the playlist you want to delete, and then click Delete.
If prompted, choose one of the following options:
Delete from Media Library only
Delete from Media Library and my computer
Note
When a playlist is selected in Media Library, the Select Playlist Options button is displayed at the bottom of the Details pane. You can click the button to display a menu of playlist options that contains the following commands: Edit Playlist, Delete Selected, Clear, Sort, Open, Save As, and Copy to CD or Device. The Select Playlist Options button is also available in Now Playing. |
| Kommentaarid: 29 loe/lisa |
25 |
Rajareits
29.07.2004 23:01:36
| Bad Sector, tänud Sulle! Kust Sa selle informatsiooni leidsid?
69 |
Bad Sector
30.07.2004 09:12:36
| Rajareits kirjutas: |
| Bad Sector, tänud Sulle! Kust Sa selle informatsiooni leidsid? |
Mediaplayeri enda helpist loomulikult... see on üldiselt esimene koht kuhu peaks probleemide ilmnemisel vaatama
25 |
