stepzter
08.09.2005 00:09:31
| Ho Ho kirjutas: |
| Nope, 128GiB on neil maksimum. |
Nope, 1TiB. Nii Inteli kui ka AMD praegused protsessorid toetavad 40bitist füüsilist aadressiruumi. (Virtuaalne on 48 bitti)
| Kommentaarid: 26 loe/lisa |
26 |
Ho Ho
08.09.2005 00:26:30
| stepzter kirjutas: |
| Ho Ho kirjutas: |
Nope, 1TiB. Nii Inteli kui ka AMD praegused protsessorid toetavad 40bitist füüsilist aadressiruumi. (Virtuaalne on 48 bitti) |
Võibolla ma ei väljendunud piisavalt hästi. Pidasin silmas et XP 64bit ei toeta nii palju mälu.
Ma ei tea kui usaldusväärne see just on kuid....
http://en.wikipedia.org/wiki/Windows_XP_64-Bit_Edition
Microsoft Windows XP Professional x64 Edition released on April 25, 2005 by Microsoft is a variation of the typical 32-bit Windows XP operating system for x86 personal computers. It is designed to use the expanded 64-bit memory address space provided by the AMD64 architecture (referred to as EM64T by Intel in their implementation) and other future 64 bit processors. This increases the maximum allocatable system memory (RAM) past the 32-bit limit of 4 GB, though it is i[currently limited to 128 GB[/i] (237 bytes) of physical memory and 16 TB (244 bytes) of virtual memory. It is currently only available for sale to original equipment manufacturers (OEMs).
Minu teada ei näidata virtuaalmälu my computer'i properies'i all. Kui eksin siis palun vabandust.
[edit]
Tundub et wikipedia jutt on õige:
http://www.microsoft.com/windowsxp/64bit/evaluation/top5.mspx
Large memory support
Windows XP Professional x64 Edition supports up to 128 gigabytes (GB) of RAM and 16 terabytes of virtual memory, enabling applications to run faster when working with large data sets. Applications can preload substantially more data into virtual memory, allowing rapid access by the 64-bit processor.
86 |
stepzter
08.09.2005 01:40:02
| Hea tähelepanek. Võib vabalt olla, et nende leheküljetabelite struktuur ei võimalda suuremaid aadresse salvestada. Järjekordselt üks (vaieldava väärtusega) punkt avatud lähtekoodiga lahendustele.
26 |
Jaan
08.09.2005 13:33:48
Re: future processing |
| omnibook kirjutas: |
Nüüd saab siis arutamiseks uus ajastu.
Mõtleme end ajast ette ja mis võiks meid oodata 10- 50 aasta pärast.
Kuna saavad tavakasutajad kasutada 10Ghz protsessoreid? Milliseks muutub reaalsus mängides 2GB graafikakaartiga?
Kas protsessorigigant Intel on veel 20 aasta pärast turuliider või omab turgu "kolmas firma" oma hämmastava tehnoloogiaga.
Kuna tuleb makroprotsessorite ajastu mis suudavad sekundis arvutada rohkem kui kõik tänapäeva olemasolevad protsessorid aastaga? |
imho tulevik on optliste sedmete taga.
uurige seda lehte : http://atomchip.com/index.html
123 |
Ho Ho
08.09.2005 19:56:13
The CPU's next 20 years
http://www.computerworld.com/hardwaretopics/hardware/story/0,10801,104436,00.html
The road ahead isn't about 8-GHz Xeons or 32-core Opterons. It won't be about hardware at all. It will be about the $100,000 commercial development suites that will perform automated, distributed build, run, observe and optimize cycles until native code flows through every possible combination of processor types. And for another $50,000, tools will instrument a commercial application to optimize itself based on changing deployment environments. In this scenario, it might take Microsoft Corp. three months just to build a major release of Windows, harnessing the off-hours cycles of every machine on its Redmond, Wash., campus, but the result would be an operating system that could chop a big shop's system requirements by a third or more.
86 |
neros
09.09.2005 02:53:41
Ho Ho, ma ei rääkinud mitte XP 64 bitisest versioonist vaid üldse kui suure mäluhulgaga suudab üks 64bit prose tegelda
(imho suudab linux nagu ka terabaidise mäluga hakkama saada... või ma eksin? Sest seda on ikka 8x rohkem kui wxp toetatud 128GiB )
(ma nüüd olen targemaks saanud vaikselt 4000-nde leheküljeline "entsüklopeediasari" ( ) pole veel esimenegi raamat läbi loetud, aga juba tean rohkem kui oleks omal käel viitsinud ealeski otsida )
_________________ GitHub
.NET Core & Azure baasil lahendused ja arhitektuur - kontakt. |
| Kommentaarid: 48 loe/lisa |
40 |
tanelll
09.09.2005 11:41:40
Pole mõtet nende gigahertzide ja megade üle pead murda. Kui kvanprotsessorid käiku lähevad siis selliseid asju enam ei eksisteerigi. Ja nagu siin varem toodi sisse mõiste reaalsus siis kvantprotsessor suudab seda "reaalsust" paremini hoomata kui meie oma peas. Ja kuvada seda ka meie siladele eristamatult nö päris reaalusest. Kui arvestada tehnloogiaarengut. mis hetkel iga 10a tagant kahekordistub võrreldes inimese "algusest" kuni siis hetke aastaarv miinus 10 siis võib arvata et 10 aastat suudame veel ette mõelda reaalselt aga kas ka 20 selles on küsimus. Jah me võime fantaseerida aga kas ka sellest kasu on. Juhiksin tähelepanu veel sellele, et hetkel see mis meil tehnoloogia arengus toimub on ju lõppkokkuvõttes ikkagi kogu selle algus. Tehnoloogia arengu plahvatuse algus!
edu
tanel
_________________ tk |
| Kommentaarid: 14 loe/lisa |
Ho Ho
09.09.2005 11:48:07
sealse masina ja kvantarvuti vahel oon ainsaks ühiseks jooneks samad tähed nimes, kvantarvutist on asi väga kaugel.
Sama hästi võiks ju teatud kõvakettaid pidada kvantarvutitega seonduvaks
Btw, minu teada kvantarvuti ei sobi eriti hästi paljudeks asjadeks, üheks selliseks peaks olema ka virtuaalreaalsuse simuleerimine.
86 |
tanelll
09.09.2005 11:54:05
Siin tulebki ette see asi et sa ei tea mis siis toiub kui aeg käes on
neros
10.09.2005 00:23:34
tanelll, nõustun. Ka ise usun kvantarvutite tulevikku kui sellisesse (cell... ) Samas, miks ei võiks AMD või Intel tulla kunagi turule (kui Cellidel juba kõva minek on) sarnaste protsessoritega. Väga võimalik, et tulevikus majandavad Inteli ja AMD prosed ning Cellid kõik koos, Cell vaatab, et ahhaa - naabri AMD on idle, laseme tal ka tööd teha. Teise naabri Intel vaatab aga, et ohhoo - ühe põdra külmkapp, mida majandab Cell ei tee praegu midagi, laseme sel natuke renderdada! (Internet 2-ga on see vägagi võimalik)
Ho Ho, miks sa arvad, et ta virtuaalreaalsuse simuleerimiseks ei sobi? võimsust tal ju piisavalt selleks
40 |
Ho Ho
10.09.2005 02:22:15
| madedog kirjutas: |
tanelll, nõustun. Ka ise usun kvantarvutite tulevikku kui sellisesse (cell... ) |
Cellil pole kvantarvutitega vähimatki seost
| madedog kirjutas: |
| Samas, miks ei võiks AMD või Intel tulla kunagi turule (kui Cellidel juba kõva minek on) sarnaste protsessoritega. |
Aga seda nad teevadki. Ainus vahe et neil on kõik tuumad identsed ning täielikult x86(-64)'ga ühilduvad mitte nagu cellil. AMD nelja corega prosed peaks ilmuma järmise aasta esimeses pooles, Intelil teises pooles.
| madedog kirjutas: |
| (Internet 2-ga on see vägagi võimalik) |
Võimalik kuid äärmiselt ebaefektiivne enamus probleemdie lahendusesks. Internetis on ping aka viide lihtsalt liiga suur et midagi mõistlikku teha. Kui kohtvõrgus on viiteaeg enamasti alla ühe millisekundi siis internetis reeglina (kümneid) kordi suurem ning selle täpset väärtust on võimatu ette aimata. Samuti tuleb arvestada et pika maa peale jääb ka valguskaabel suht kehvaks lahenduseks sest seal ei liigu valgus sama kiiresti kui vaakumis. Seega jällegi viide kasvab.
Teine suur probleem tekib andmemahtudega. Näiteks kui keegi tahaks míngit mängu mängida mis kasutab ray tracingut siis renderdamise teise arvutisse andmiseks tuleks ka kogu stseen koos kõigi modelite ja tekstuuridega sinna teise masinasse saata. Kuna eeldame et tegu on tulevase generatsiooniga siis see võtab reeglina üsna suure mälumahu(oletame ~4-16GiB). Nüüd kujutage ette mis võrku läheks tarvis mis suudaks selliseid andmemahte läbi lasta. Ainus varaiant oleks mitme kiuline fiiberoptika kuid selle seadmed maksavad vähemalt praegu hingehinda. Samuti tuleks sel juhul arvestada community võrkude puhul et kõik inimesed liigutavad pea pidevalt gigabaitide kaupa infot. Niikaua kuni hunnik minisatelliite kosmosesse ei saadeta siis sellises mahus andmevahetus jääb eri mandrite vahel ära.
Taoline hajus ressursi kasutamine oleks mõttekas ainult lühikese maa tagant, näiteks ühe kodu piires. kaugemale on mõtet saata ainult selliseid asju mille vastust oodatakse minimaalselt alles mõnekümne sekundi pärast.
Minu arvates oleks mõttekam ja tõenäoliselt sama ressursi puhul odavam üks blade serveri laadne kas igas kodus või siis paari kodu peale kokku, umbes nagu praegu käib interneti jagamine.
Pealegi Internet2 pole päris see mida sa arvad:
http://en.wikipedia.org/wiki/Internet_2
Mislabeling of Internet2
Some sources go so far as to suggest Internet2 is a network wholly separate from the Internet. This is misleading since Internet2 is in fact a consortium and not a computer network. |
Kui pead Internet2 all silmas midagi muud siis täpsusta
| madedog kirjutas: |
| Ho Ho, miks sa arvad, et ta virtuaalreaalsuse simuleerimiseks ei sobi? |
http://en.wikipedia.org/wiki/Quantum_computer#The_power_of_quantum_computers
| This dramatic advantage of quantum computers is currently known to exist for only those three problems: factoring, discrete log, and quantum physics simulations. |
Kui sa just kvanttasandil ei hakka virtuaalreaalsust simuleerima siis kvantarvutitest selleks kasu pole. Teoreetiliselt oleks küll võimalik vast enamus probleeme nendele kolmele "funktsioonile" taaandada kuid selle efektiivusest ei jääks sel juhul halligi alles.
Eelmise quote jätkuks veel huvitavat:
However, there is no proof that the advantage is real: an equally fast classical algorithm may still be discovered (though this is considered unlikely). There is one other problem where quantum computers have a smaller, though significant (quadratic) advantage. It is quantum database search, and can be solved by Grover's algorithm. In this case the advantage is provable. This establishes beyond doubt that (ideal) quantum computers are superior to classical computers.
Consider a problem that has these four properties:
* The only way to solve it is to guess answers repeatedly and check them
* There are n possible answers to check
* Every possible answer takes the same amount of time to check
* There are no clues about which answers might be better. Generating possibilities randomly is just as good as checking them in some special order
An example of this is a password search for an encrypted file.
For problems with all four properties, it will take an average of (n+1)/2 guesses to find the answer using a classical computer. The time for a quantum computer to solve this will be proportional to the square root of n. That can be a very large speedup, reducing some problems from years to seconds. It can be used to attack symmetric ciphers such as 3DES and AES. But it is also easy to defend against. Just double the size of the key for the cipher. There are also more complicated methods for secure communication, such as using quantum cryptography.
There are currently no other practical problems known where quantum computers give a large speedup over classical computers. Research is continuing, and more problems may yet be found.
| madedog kirjutas: |
| võimsust tal ju piisavalt selleks |
Jah, võimsust on kuid nagu ma quotesin siis ainult kolme probleemi lahendamiseks
Mul on kahju kui ma kellegi ilusad helesinised unistused helgest tulevikust purustasin.
86 |
tanel_76
10.09.2005 19:33:23
näiteks Nvidia vaatab praegu selle poole, et oma gpu'sid tulevikus kasutada
cpudena, panen siia ühe asja mille kirjutasin küll inglisekeelsena ning Gelato-keskse,
kuid tegemist siis nvidia gpu'dega:
i recently met daniel wexler from nvidia in spain - he's working with larry gritz and wrote a lot of stuff for the Gelato renderer.
here's what he told:
the thing behind gelato is simply using gpu efficiently. right now 3GhZ P4 using SSE will give you roughly 6 GFLOPS raw performance (from intel P4 optimization manual), while GeForce FX 5900 (NV35) will give you 20 GFLOPS (equivalent 10 GHz P4) and getting faster: NV35 = 3x improvement over NV30 (in 6 months), NV40 = 4-8x improvement over NV35. So, you see: gelato is simply using the gpu power, it's optimized for NV chips. In 2014 theoretically we will see something like this if things are evolving at current speed:
CPU: 100GHz (current 3,4)
memory frequency: 44Ghz (1,2Ghz)
bus bandwith: 160Gb/sec (4GB/sec)
hard disc size: 30 TB (200Gb)
pixel fill rate: 270GP (3300 Mpixels/sec)
vertex fill rate: 127GV (356 Mvertex/sec)
graphics flops: 10TF (40 GFlops/sec)
graphics bandwith: 3TB (30 GB/sec)
frame buffer size: 32GB (256 MB)
so you can see, CPU potential growth is 30x performance,
GPU is 250x performance growth!
so, as he said, the earth simulation center (world's fastest supercomputer) that occupies the space of 4 tennis courts on 3 floors will be a single CONSUMER semiconductor chip in 2014.
ps. see pole kiidulaul nvdia aadressil, ilmselt varsti on näha kas see plaan neil ka õnnestub
_________________ Davinci Resolve
Quadro FX3700 / FX5800
viimati muutis tanel_76 10.09.2005 19:48:52, muudetud 3 korda |
| Kommentaarid: 6 loe/lisa |
silver010
10.09.2005 19:45:23
kas videokaardi protsessorit ja keskprotsessorit(cpu) annab üldse niimoodi võrrelda? tavaprotsessor peaks mõnda teist asja, paremini oskama vast
| Kommentaarid: 45 loe/lisa |
42 |
tanel_76
10.09.2005 19:48:02
sellest oli ka juttu, nvidia gpu'd kasutavad miskeid loogikamooduleid - neid aetakse kiiremaks
Quadro FX3700 / FX5800 |
Ho Ho
11.07.2006 18:29:28
| kas videokaardi protsessorit ja keskprotsessorit(cpu) annab üldse niimoodi võrrelda? |
Ei. Teoreetiliste maksimumvõimsuste võrdlemine ei näita suurt midagi. Võtke kasvõi top500.org lahti ning võrrelge max ja peak. See juures arvestage et tegu on suhteliselt sünteetilise testiga ning reaalses olukorras ei pruugi sarnaseid tulemusi saavutada.
Superarvutitel saavutatakse ülioptimeeritud koodiga 50-80% teoreetilisest maksimumist, tava prosedel ~30-50%. Videokaardil mingite üldotstarbeliste asjade arvutamine on äärmiselt ebaefektiivne.
Kui mõni arvab et Cell oma mitme tuumaga millel on erinev käsustik on raske progeda võrreldes x86'ga siis videokaarte progeda millekski üldotstarbeliseks on kordades raskem. Igasugustest limiitidest ei hakka esialgu parem rääkimagi.
Võibolla SM4 ja uuemad toovad juurde midagi mis teeb GPU progemise lihtsamaks kuid ma kahtlen sügavalt et lähema 5-10a jooksul saab videokaartidest midagi sarnast x87'le.
[edit]
Vana teema küll kuid taas aktuaalne. Nimelt on välja tilkunud mõned Inteli plaanid järgmise CPU arhitektuuri kohta:
http://www.dailytech.com/article.aspx?newsid=3218
http://www.tomshardware.com/2006/07/10/project_keifer_32_core/index.html
Eeldusel et artiklitest õigesti aru sain peaks lühidalt öeldes tegu olema arhitektuuriga mis võib turule jõuda juba 2010 aastal tõenöäoliselt 32nm peal. Põhinäitajad on 32 lihtsustatud tuuma, eraldi FPU'd, 24M cache't ning mitu integreeritud mälukontrat. Veelgi lihtsamalt öeldes on tegu Sun'i Niagara'ga sarnase arhitektuuriga.
Prose koosneb kaheksast moodulust, iga moodul omab nelja lihtsustatud tuumast, 3M cachest, ühest mälukontrast ning tõenäoliselt ühest FPU'st. Nood lihtsustatud tuumad suudavad tõenäoliselt mitut threadi paralleelselt jooksutada, ehk siis umbes sama mis Inteli vanal HT. Moodulite omavaheline suhtlus käib üle R5xx või Celli laadse ringbus'i mis on prosesse sisse ehitatud. Seal pakuti summaarseks mälu läbilaskeks ~100BGB/s kuid minu arvates peaks see olema vähemalt 2x suurem kui võetakse kasutusse DDR3 2GHz efektiivse sagedusega.
86 |
stepzter
11.07.2006 22:22:23
| Ho Ho kirjutas: |
| Nood lihtsustatud tuumad suudavad tõenäoliselt mitut threadi paralleelselt jooksutada, ehk siis umbes sama mis Inteli vanal HT. |
8 moodulit x 4 tuuma x 4 threadi minu andmetel.
| Ho Ho kirjutas: |
| Seal pakuti summaarseks mälu läbilaskeks ~100BGB/s kuid minu arvates peaks see olema vähemalt 2x suurem kui võetakse kasutusse DDR3 2GHz efektiivse sagedusega. |
Kasutusele võetakse FB-DIMM. Praegune 2 kanaliga DDR kontroller on viikude arvult võrreldav umbes 6 FB-DIMM kanaliga, mis annavad umbes 4x rohkem ribalaiust. DDR tehnoloogiaga peaks olema andmeedastustakt 6.25GT/s, mitte 2.
26 |
Sakurai
15.07.2006 20:52:18
ooh, esimese postituse juurde siis minnes.. 2 GB video...
Quad SLI.. GTX on 2 GB... ^^
tqz
15.07.2006 21:38:19
| Sakurai kirjutas: |
Quad SLI.. GTX on 2 GB... ^^ |
See 2GB on nelja tuuma peale kokku, ühe tuuma jaoks jääb ikka 512MB
| Kommentaarid: 74 loe/lisa |
71 |
erick
15.07.2006 21:46:15
Mitte päriselt. Quad SLI ühel kaardil on kaks videoprotsessorit, kummagi jaoks 512MB videomälu. Niiet tegelikult on tegu 512MB+512MB+512MB+512MB süsteemiga, kusjuures reaalselt saab tekstuure kasutada siiski maksimaalselt nii palju, kui ühe videoprosega koos olevasse mällu mahub.... ehk siis "kõigest" 512MB!
EDIT: jõuti ette
96 |
Sakurai
16.07.2006 12:19:06
Aight.. Sain omatud... xD Aga noh, hea et teada sain Tänud et seletasite lahti.
olaviv
19.07.2006 11:09:53
Ma ikka sügavalt kahtlen, et Intel või AMD või kes iganes jõuaks 2010 a välja tuua 32 nm tehnoloogia. Mitte, et see tehniliselt või füüsikaliselt võimatu oleks, kindlasti saab seda teha, kuigi mitte lihtsalt. Pidurdama hakkavad eelkõige majanduslikud asjaolud ja samuti vähenev nõudlus turul. Maailmamajandus üldiselt on langusse minemas ja selles situatsioonis ei kipu firmad ja üksikisikud eriti uusi investeeringuid tegema ning ka arenduse pealt hakatakse kokku hoidma.
Nõudlus kiiremate prosede järele tõenäoliselt väheneb. Ühest küljest pole enam erilist motivatsiooni olemasolevaid Athlon64/Pentium4/Conroe süsteemi tingimata uuendada. Teisest küljest on ka arvutistehnika eluiga küllaltki pikk, enamik rauda peab 5-10 a vast, kui tingimused normaalsed. Niiet ka raua amortiseerumise ja riknemise tõttu ei teki eriti nõudlust uue raua järele. Kolmandaks, AMD ja Inteli omavaheline hinnasõda juba iseenesest aeglustab arendust. R&D mootoriks on ikka raha, mitte inseneride geniaalsused või planeerijate fantaasialennud. Kui ikka vana tehnoloogia müük pole piisavalt raha sisse toonud, siis järgmist turule ei tooda ning ülejärgmise arendust ei alustata.
Kuid alati jääb võimalus, et koostöös softitegijatega lihtsalt mõeldakse välja vajadus olemasolev raud uuema vastu välja vahetada. Näiteks tuleb välja Vista2, mis töötab ainuld n corega prosedel. Niiet tulevik on segane ja ennustamine on ütlemata tänamatu töö
_________________ digiallkiri |
| Kommentaarid: 44 loe/lisa |
43 |
Tbit
19.07.2006 12:01:32
väga arusaamatu lähenemine, minumeelest ikka mida kiirem raud sul on seda kallimaks saad ajada selle, ostjate probleemi vaevalt tuleb, senikaua kuni uus on parem kui vana on ka ostjaid.
|OSTAN|-> T43 pikk jahutus |
230 |
olaviv
19.07.2006 13:33:07
| Tbit kirjutas: |
| ostjate probleemi vaevalt tuleb, senikaua kuni uus on parem kui vana on ka ostjaid. |
küsimus ongi selles, et palju on neid, kelle jaoks uus on parem, kui olemasolev? Siiani on päris mitu upgrade motivaatorit olnud. Tuli mp3 buum ja 386&486 omanikud vajasid kiiremat arvutit. Siis divx filmid ning p1 oli vaja välja vahetada. Ning 3D mängud ja p2 jäi nõrgaks. Ning muidugi motiveeris kiiremat arvutit ostma iga uus windowsi versioon Aga mis hetkel ja lähitulevikus motiveeriks miljoneid kodu- ja kontoriarvuteid uuemate vastu välja vahetama? Soovitud müüginumbrite saavutamiseks ei piisa fännidest ja poweruseritest, kelle jaoks ükski prose liiga kiire pole. Vaja on, et miljonid omale uut arvutit tahaksid.
Niiet ma pole nii kindel, et ostjaid lõputult jätkuks. USA tarbijad on hetkel rahast üsna lagedad, vaevalt nad ilma tungiva vajaduseta uue arvuti ostavad. Pigem muretsevad selle üle, kuidas järsult kasvanud bensiiniarveid tasuda.
43 |
19.07.2006 19:38:11
on peale mängimise ja misiganes suurte arvutusvõimsustega ülesannete täitmiseks (cad/cam, videotöötlus jms comes to mind first) üldse vaja võimsat protsessorit?
ma ei näe tavakasutaja jaoks juba pikemat aega mingit põhjust cpu upgrademiseks.
_________________ - londiste
216 |
Ho Ho
19.07.2006 21:30:32
| olaviv kirjutas: |
| Ma ikka sügavalt kahtlen, et Intel või AMD või kes iganes jõuaks 2010 a välja tuua 32 nm tehnoloogia. |
Intel plaanib 45nm prosed letti lüüa 2008 aastal. Kaugel see 32nm enam on, ainult üks samm
| olaviv kirjutas: |
| Vaja on, et miljonid omale uut arvutit tahaksid. |
Maailmas on miljoneid servereid ja serveriparke kus pole eales piisavalt arvutusvõimsust.
86 |
