CnZ
15.07.2026 21:07:41
| etv peal korralik läg, viskab vahepeal pildi mustaks
| Kommentaarid: 14 loe/lisa |
libe
kvaliteetne mees
15.07.2026 21:28:46
vaatan lahja kvaliteediga BBC streami, palju parem kui ETV oma
saab kommentaari ja etv pildi sünkida, siis norm kvali koos parema kommentaariga
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
-Koppel-
15.07.2026 21:46:09
| 2006 oli esimene World cup, mida edastati FullHD kvaliteediga, täna 20. aastat hiljem, on tulemus praktiliselt sama.
| Kommentaarid: 10 loe/lisa |
10 |
libe
kvaliteetne mees
15.07.2026 21:46:48
| -Koppel- kirjutas: |
| 2006 oli esimene World cup, mida edastati FullHD kvaliteediga, täna 20. aastat hiljem, on tulemus praktiliselt sama. |
ameeriklaste probleem, eelmine mm oli 4k
CnZ
15.07.2026 22:05:08
Keegi eelnevalt postitas juba lingi
First things first, this year’s actual production of the World Cup will not be native UHD/4K. It will be natively produced end-to-end in HDR however (HLG specifically, but broadcasters will convert to HDR10/HDR10+/Dolby Vision as they see fit). It is also being natively produced at 60fps (59.94Hz). So this means that the actual world feeds going to all broadcasters (there will be multiple feeds for each broadcaster to pick from) is sourced from a FHD/1080p60 HLG production source.
Many broadcasters worldwide will be making the games available in UHD p50/p60 (depending on local region standard) in some flavor of HDR format, but the resolution will be from an upscale of the FHD production mix. The frame rate conversion process is also generally performed using high-end frame rate conversion hardware, such as that from GrassValley or InSync, so most viewers in 50Hz territories should not be able to distinguish any anomalies in terms of motion processing.
Even though the production mix won’t be performed at native UHD, this does not mean that viewing UHD won’t be worthwhile; the UHD feed is very likely to have the highest picture quality due to a higher bandwidth encoding in addition to the benefits of HDR. The reality is that with a tournament so vast in geographical scope (three countries, 16 cities, of which all camera feeds from the sites will be sent to a central hub in Dallas, TX for mixing), producing everything in native UHD was not a possibility, primarily due to cost and reliability. For previous World Cups, such as Qatar, FIFA’s HBS was able to use dark fiber connections from all host sites directly to their centralized hub, so native UHD production workflows were possible. But to do something similar for this Cup would have been prohibitive given the economics of things.
With that caveat out of the way… 😄 In terms of the ‘best’ available regions to watch the games at home? Top of mind it will likely be in countries where football is a highly prioritized past time and the matches will be airing at a time where audiences are likely to be available to watch. Brazil is one such country. While the country as a whole (and its citizens) may not have the best access to the games in UHD, Globo is the rights holder and will be going for bragging rights on their own platform as they will be competing with service providers who will also want to deliver a premium experience to their customers. Bein platforms in the middle east will also very likely be a good source for high quality feeds. In the States, we have Fox, which isn’t too bad, but generally not the best compared to other worldwide consumer transmissions either. Tbh, most platforms in the EU will likely be stingy with performance, based on previous experience.
EU, nagu ikka, kõiges kõige pasem
15.07.2026 22:54:19
| hullumaja. Argentiina lihtsalt ei lähe Inglaste värava alt minema, lihtsalt löövad ja löövad, kuniks sisse saavad.
131 |
15.07.2026 23:09:29
| time123 kirjutas: |
| Kas keegi on veel hädas veebist etv ja etv2 striimimisega? Vaatan telkust ainult jalgpalli ja mida suurem mäng, seda rohkem läägab ja pilt seisab vahepeal. Elisa kaabel 100/100. Brave brauser on lootusetu juhtum ERR-i lehel, aga laiendusteta Chrome ka sujuvat esitust ei võimalda. Kas õnnetusehunnik rahvusringhäälingu mure? |
jah....ungaris vahtisin slaidivärki
15.07.2026 23:12:13
Tehtud...käskisin värava lüüa kuniks alt sõõki võtan...check....sõin....löödi teine...check
Tiktokarid vaja veel koju saata, siis võib turniiril joone alla tõmmata
SSD
15.07.2026 23:15:05
Jaa, kõik sujus. Sain ühesr eurost 9
267 |
krr
| Kommentaarid: 65 loe/lisa |
61 |
somnambuul
18.07.2026 23:40:50
| Kas Inglismaa mängib hästi või Prantsusmaa halvasti?
| Kommentaarid: 60 loe/lisa |
54 |
19.07.2026 01:07:03
Kaitset ei mängi keegi
Ainuke kes püüab ja saab hakkama, on inglaste väravavaht
Prantsuse kaitse ja keskendumine täielik null
Mõttetu mäng kui pool võistkonda ära vahetatud ja pape mängib vaid selle jaoks, et väravat saada või res.sööte
Kui inglased selle maha mängivad ja pähe saavad, siis on nad eriti tublis
Noh jah....see oli omapärane mäng.....tihti sellist ei näe......
SSD
19.07.2026 01:14:22
4-6 juba nagu tennis.
267 |
commer
| Kommentaarid: 940 loe/lisa |
723 |
SSD
19.07.2026 19:18:08
No kes-keda?
Mina olen Argentiina poolt.
267 |
CnZ
HPN
19.07.2026 20:20:11
| Ma lihtsalt loodan, et kohtunik mängu ära ei otsusta. Pea kõiki Argentina mänge on saatnud kohtunike draama. Täna võiks ilma selleta hakkama saada.
| Kommentaarid: 48 loe/lisa |
47 |
SSD
19.07.2026 20:22:43
CnZ, Ära ole kade! Ta on selle nimel ka vaeva näinud!
267 |
1dumbpcuser
19.07.2026 20:54:52
| HPN kirjutas: |
| Ma lihtsalt loodan, et kohtunik mängu ära ei otsusta. Pea kõiki Argentina mänge on saatnud kohtunike draama. Täna võiks ilma selleta hakkama saada. |
Kusagilt internetist on meelde jäänud väide, et Argentiina ja Mehhiko on sel MM-il ainsad riigid, kelle vastu pole VAR otsuseid teinud.
_________________ M: MSI B660M MORTAR
O: AM5 ITX emaplaat |
97 |
19.07.2026 20:58:44
Argentiina võtab ära
Aga ameerika sitt, mingi tom impossible avab finaali... Poolaja sitt kestab lubatud 20 asemel kindlasti 30 minutiliseks...tagatjärele vibutad näpou vä?
Siis hakkavad sooja tegema....mul homme äratus 5.59
Donald võiks end põlema panna
viimati muutis jeesus188 19.07.2026 20:59:06, muudetud 1 kord |
19.07.2026 20:58:58
ma eilse mängu juures vaatasin, et seal löödi üks värav olukorrast, kus pall selge veaga kätte saadi
kumb meeskond see oli, ei mäleta. aga selge jala peale astumine ja siis kiire rünnak.
_________________ - londiste
viimati muutis londiste 19.07.2026 21:01:07, muudetud 3 korda |
217 |
19.07.2026 20:59:59
| londiste kirjutas: |
ma eilse mängu juures vaatasin, et seal löödi üks värav olukorrast, kus pall selge veagta kätte saadi
kumb meeskond see oli, ei mäleta. aga selge jala peale astumine ja siis kiire rünnak. |
Tegelikult polnud nii, aga las olla
CnZ
19.07.2026 21:00:36
| jeesus188 kirjutas: |
Donald võiks end põlema panna |
sa vist kuulud ka nende hulka, kel testosteeroni tase on ämbrisse kukkunud? selline vanaema möla
libe
kvaliteetne mees
19.07.2026 22:14:11
tra see poolaja piix ära ka lõppeb?
19.07.2026 23:20:30
| CnZ kirjutas: |
sa vist kuulud ka nende hulka, kel testosteeroni tase on ämbrisse kukkunud? selline vanaema möla  |
Mis probleem?
Hispaania hea.....argentiina mõttttttetu kollane ja punane otsa.....lähvad pennelite peale vist nüüd
-Koppel-
20.07.2026 00:05:06
| Hispaania oli tohutult parem. Aga martinez kaitses Argentiina väravat nagu metslane.
10 |
SSD
20.07.2026 00:05:16
Igav mäng oli.
Mõlemad panustasid kaitsele.
Napp 0-1 või 1-0, kuidas soovite - jama.
267 |
7 :: |
364 |
Aeron
20.07.2026 00:14:26
Ebasümpaatne mäng Argentiinalt.
Uskumatu, et Argentina lõpus oleks pea-aegu selle pendlitele viinud.
Tore, et nii läks. Mitte et Hispaania fan oleks aga sellise mängu ja käitumisega võikski kotti saada.
_________________ Võib öelda, et ma olen liigselt enesekeskne, aga mind see ei häiri
Tulge kõik HV rahvaga jalkat mängima!| |
| Kommentaarid: 72 loe/lisa |
65 |
-Kaivo-
20.07.2026 06:14:39
| Hea tulemus. Argentiinlased peast ikka väga hälvikud.
| Kommentaarid: 16 loe/lisa |
15 |
HPN
20.07.2026 07:55:50
Teenitud võit Hispaaniale. Ainult esimeses alagrupimängus natuke väristasid jalga. Kõik teised mängud olid hindele 5. Argentina sai teenitult peksa ja mitte ainult finaalmängu eest. FIFA muidugi tassis neid ka mängult mängule. Äärmiselt ebasümpaatne meeskond sel korral. Isegi Messi käitumine võttis kukalt kratsima.
Nüüd tuleb loota, et Infantino suudetakse FIFA juhi kohalt maha võtta.
47 |
Plin500
HV piljardihai
20.07.2026 08:09:36
| Aeron kirjutas: |
Tore, et nii läks. Mitte et Hispaania fan oleks aga sellise mängu ja käitumisega võikski kotti saada. |
+1
Kohtunik oli leebe, Argentiinala jäeti mitmed vead ning kaardid andmata. Ilmselgelt parem võistkond võitis.
| Kommentaarid: 79 loe/lisa |
77 |
CnZ
20.07.2026 08:14:34
Läks nii nagu pidi Eriti veel peale võitu tõuklema tulla argentiinlase poolt Tundub, et lihtsalt nii närvilised olid ja miljardär Messi ei saanudki suurt lõpu-šõud oma karjäärile korraldada
131 |
alpha
20.07.2026 09:49:29
| Hispaaniale teenitud võit. Argentiina esimene löök väravale oli vist alles 117. minutil. Enzo Fernandeze punene täiesti teenitult, oleks pidanud selle juba inglastega mängides saama. Poolaja triangel võiks küll viimaseks korraks jääda. No ja Trump on Trump.
131 |
1dumbpcuser
97 |
HPN
20.07.2026 17:30:23
| Jalgpallis on ka muid aspekte peale väravalöömise ja väravasöötude (2002 sai selle Kahn, kes küll on oma elus väravaid samuti löönud... ka käega, aga põhiamet oli tal siiski väravavaht). Golden Boot läheb parimale väravalööjale.
47 |
1dumbpcuser
20.07.2026 19:38:31
| HPN kirjutas: |
| Jalgpallis on ka muid aspekte peale väravalöömise ja väravasöötude (2002 sai selle Kahn, kes küll on oma elus väravaid samuti löönud... ka käega, aga põhiamet oli tal siiski väravavaht). Golden Boot läheb parimale väravalööjale. |
Ma küsingi, et miks hinnati Rodri kaptenioskuseid kõrgemalt kui Messi puhul? Või mis see kriteerium on?
97 |
7 :: |
364 |
alpha
21.07.2026 09:08:42
| 1dumbpcuser kirjutas: |
| HPN kirjutas: |
Ma küsingi, et miks hinnati Rodri kaptenioskuseid kõrgemalt kui Messi puhul? Või mis see kriteerium on?  |
Mitte kapteniks olemise eest, vaid mängujutimise eest.
HPN
47 |
libe
kvaliteetne mees
21.07.2026 21:04:59
| HPN kirjutas: |
see kuidas rodri trumpi oma meeskonna eest käega seljale toetades ära juhtis
HPN
47 |
time123
30.07.2026 16:12:32
| Keegi rootslasi Tallinnas näinud ka on? Taksojuht ütles, et üks kena rootsi pere sõitis muuseumi, aga ei enamat. Kus need 2k Göteborgi fänni on?
183 |
30.07.2026 18:37:14
Staadionil?
7 :: |
364 |
alpha
30.07.2026 22:04:19
| sitta kanti oli neid
avrn
RedFusion
31.07.2026 08:14:11
Krdi metslased seal Göteburgis, siin peaks 100% olema mitte lihtsalt avaldus/nõue Rootsi alaliidule, vaid ka kriminaalasi
| Kommentaarid: 8 loe/lisa |
