uus teema   vasta Tarkvara »  Arvutimängude foorum »  Firefall märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3  järgmine
scarface
scarface
sõnum 17.04.2012 20:41:55 vasta tsitaadiga
xpander kirjutas:
keegi oskab öelda mis mootoril mäng tehtud? ja millist gameguard/protection süsteemi kasutatakse?
lihtsalt mõtlen et kas pressib linuxi all ka tööle või ei:D..ei viitsi windowsi selle pärast installima hakata.
canceldatud Project Offseti Offset Engine
Kommentaarid: 44 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 42
Dominus
Dominus
sõnum 19.04.2012 22:26:20 vasta tsitaadiga
Eilne patch oli päris hea. Näitab, et töötavad mängu kallal ja ei unusta huumorit.
Additional metrics added to the game so that we can Big Brother you all. Orwell was right!
Bug Fixes
The denizens of New Eden have become more self-aware and less concerned with the fluttering of butterflies and squirrels.
AKA they will own your face so watch out.
We've made major improvements to the AI servers, but have not lowered their lethality until we have a chance to watch what happens. Expect some tough fights.
Fixed an issue where you think you can deploy a thumper, but nothing ever comes. Forever alone.
Arahna should actually look like they are dead now when they are in fact deceased.
You are no longer able to crouch while you are on the ground trying to stymie your own blood loss.
You should no longer be tempted to risk life and limb via drowning in the river outside Trans Hub due to coralite deposits and supply crates in the water.
Using the scan hammer to turn 360 degrees while in turret mode should no longer be possible.
Engineer drain beam is no longer capable of destroying humanity. Fixed the bug where it was doing double damage.
Sending your thumpers back early will still drain the main resource vein.
Medics no longer have the option of omega-mutant levels of self-regeneration using the healing grenade.
NPC guards should now fight back against Chosen drop pods and lairs that crop up near watchtowers.
You can now highlight points of interest on the world map again.
Changed the thumper location check to prevent placing thumpers in locations that creatures are unable to reach. Sorry mushroom farmers.
Watchtowers are now destroyed by melding, meaning that you won't spawn at a location inside the melding if you die too close.
Fixed issues where the login background would render on top of other UI elements.
Fixed a problem where matchmaker was delaying adding people to a match due to mixed pools of players.
Kommentaarid: 104 loe/lisa Kasutajad arvavad:  :: 4 :: 1 :: 76
karvane
sõnum 28.04.2012 23:53:10 vasta tsitaadiga
Uus 3.5 giga patch lasti välja ja väike kokkuvõte siin:
Link
notes'id ise siin:
http://www.betacake.net/2012/04/27/firefall-april-26th-patch-notes/
Dominus
Dominus
sõnum 29.04.2012 03:50:11 vasta tsitaadiga
Ühte ma ütlen, Red 5 oskab oma mängijatega suhelda ja kriitikat vastu võtta.
aap14
aap14
sõnum 29.04.2012 16:24:40 vasta tsitaadiga
Panen märgi maha. Väga huvitav F2P.
Slow is smooth and smooth is fast
Scart
Scart
sõnum 16.05.2012 13:49:25 vasta tsitaadiga
Sain kutse.
karvane
sõnum 09.08.2012 14:25:11 vasta tsitaadiga
Milestone patch on väljas, palju uut ja huvitavat contenti tundub olema tekkinud, õhtul checkin üle.
Link
skyTronic
sõnum 09.08.2012 14:37:44 vasta tsitaadiga
https://twitter.com/Grummz/status/233233185641742337
"#firefall no more character xp wipes, ever! Play and keep your progress!"
Dominus
Dominus
sõnum 09.08.2012 15:57:33 vasta tsitaadiga
R5 Studios näeb ikka tõsist vaeva, et mängu uuendada ja mängijaid kuulata/informeerida. Tublid.
ottf
sõnum 18.09.2012 10:15:35 vasta tsitaadiga
Sain eile firefalli betasse, videod ja trailerid on ikka suht nutused võrreldes mängu endaga. Ingame pilt ja mäng on wtfomgbbq icon_eek.gif epic!
Isegi beta kohta on see mäng täiesti üle mõistuse ma ei või kui kuradi kõva noh icon_biggrin.gif
Mind on raske impressida ja ma kipun suht iga mängu üle siin HV-s whinema ja rantima kuid firefall on nüüd since cs, hl, wow, wow mmo, ut, sc, quake.. blahblah sarnaste mängude kõrval esimene tõiselt muljetavaldav mäng siiani.
Firefallil on täiesti tõsine võimalus saada järgmiseks suureks hitiks mida mängitakse üle maailma.
DeTHiCa.
DeTHiCa.
sõnum 05.12.2012 09:20:33 vasta tsitaadiga
see NV mingi beta toimumas.
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 136
thargun
sõnum 05.12.2012 11:10:19 vasta tsitaadiga
Oi kurja, kui hea see kõik näib.
Kuna ka open betat oodata võib? Järgmine aasta?
Timberg
ööKARU
Timberg
sõnum 06.12.2012 10:21:05 vasta tsitaadiga
sai ise millalgi betat mängitud ja mängu kohta nii palju, et näeb tõesti ilus välja, ei taha mingit ulmearvutit jne.
küll aga on mängul teatud onboard helikaartidega tõsiseid probleeme. nt minu helikaardiga heli mängu ei saanudki. suhtlesin suppordiga. väga asjalik ja kiire support oli, aga nad ise tunnistasid ka, et jah... teatud onboard helikaartidega on väga sitad lood. ilma helita seda mängu mängima ei hakanud.
liikumine mängus oli sujuv ka jne.
crazyxman
sõnum 06.12.2012 14:11:25 vasta tsitaadiga
Üks mäng mida mängida tahaks aga nvidia 8600m GS ei jooksuta välja icon_sad.gif
simCa
sõnum 06.12.2012 18:07:13 vasta tsitaadiga
Iga inimene kellel oli beta ligipääs sai 5 uut invite. Enda omad jagasin laiali sõpradele aga kellel huvi on siis peaks saama redditist. http://www.reddit.com/r/firefall/comments/y1k67/the_big_firefall_trading_beta_keys_thread/?sort=new
Mäng ise on muidu täitsa tore. Kena graafika, jookseb sujuvalt, erinevad classid jne. Ainukene puudus ongi see, et tegevust ja contenti on natukene vähe veel aga eks nad töötavad selle kallal hetkel. Mängul tasub kindlasti silma peal hoida.
Metsjeesus
Metsjeesus
sõnum 06.12.2012 19:03:42 vasta tsitaadiga
crazyxman kirjutas:
Kommentaarid: 108 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 94
TeaMeTzu
sõnum 16.12.2012 12:00:21 vasta tsitaadiga
M: Ainulaadsed Eesti disain sisustuselemendid - TESSERA
Hardi
Hardi
sõnum 22.12.2012 01:55:55 vasta tsitaadiga
Mul üks beta key ära anda, kui huvi kellelgi.
EDIT: ei huvita vist kedagi, aga siin siis info:
kes ära võtab andku märku siis.
EDIT: läinud paistab
viimati muutis Hardi 22.12.2012 02:26:05, muudetud 1 kord
Kommentaarid: 84 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 70
Ertai
Ertai
sõnum 22.12.2012 02:08:10 vasta tsitaadiga
võeti vist ära,omaarust sain jaole, aga juba lännu 10 minutiga..
Kommentaarid: 51 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 47
scarface
scarface
sõnum 22.12.2012 19:32:51 vasta tsitaadiga
Kahele esimesele kes oma maili siia lisavad saadan kutsed.
1 on lännu.
OTSAS!
viimati muutis scarface 22.12.2012 20:44:39, muudetud 1 kord
Bobert
Bobert
sõnum 22.12.2012 21:18:14 vasta tsitaadiga
edit: nad saatsid ise mulle beta key ja lisaks veel 5 invite, nii et kellel soovi on siis andke aga julgelt märku, kõik 5 on alles veel
kriist
kriist
sõnum 22.12.2012 23:23:28 vasta tsitaadiga
Mul ka pakkuda 3 kutset. Kel huvi saatke PS´i email.
Kommentaarid: 104 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 93
Metsjeesus
Metsjeesus
sõnum 23.12.2012 18:31:34 vasta tsitaadiga
Paluks kutset, minu kasutaja @gmail.com, aitäh!
Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine
DeTHiCa.
DeTHiCa.
sõnum 23.12.2012 18:51:19 vasta tsitaadiga
keegi veel võtmeid jagab?
tavaline email invitation vast ei funka, mul juba konto olemas vanast weekend betast aga sisse ei lase logida. tahaks sellele kontole lihtsalt uue võtme lisada.
kriist
kriist
sõnum 23.12.2012 19:19:03 vasta tsitaadiga
Mul kaks invi on, aga neid saab ainult e-mailile saata. Kui soov viska see PS´i.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Firefall mine lehele eelmine  1, 2, 3  järgmine
