sõnum |
libe
kvaliteetne mees
24.11.2002 21:52:37
LordVader kirjutas: |
1) igasugu ATI driverid on tuntud selle poolest et driveri mahavotmisega
on probleeme - Wini puhas install abiks. |
oled ikka kindel - kohe 22rmiselt kindel
kui sul probleeme esineb ja veel takkapihta windosa reinstalli soovitad - siis pole muud kui error 255
_________________ ☠ |
Kommentaarid: 82 loe/lisa |
axis
24.11.2002 21:53:04
traks kirjutas: |
aga prooviks tõmba omale powerstrip ja alanda mäluklokk 238 MHz peale, kui ta seal juba pole
BBA on Built By ATi |
Mul on aga 3Drage Tweak. Seal näitab default 249.8 nii core kui ka memory.
Kui ma mälu alandasin 238 siis sain kauem mängida. Proovisin ka 230 siis veel kauem.(NfS HP2)
Kommentaarid: 2 loe/lisa |
traks
Kommentaarid: 337 loe/lisa |
304 |
axis
24.11.2002 21:55:38
Margus kirjutas: |
axis kirjutas: |
Mul on selles kataloogis c:/windows/logfiles/watchdog/ kolm .wdl laiendiga file:
1. 020515_2044_01.wdl
2. 020804_2356_01.wdl
3. 021124_1230_01.wdl
milline neist? |
v6ta notepadiga lahti ja tee copy ja paste siia |
1.
// Watchdog Event Log File
LogType: Watchdog
Created: 2002-05-15 20:44:04
TimeZone: -120 - FLE Standard Time
WindowsVersion: XP
EventType: 0xEA - Thread Stuck in Device Driver
// The driver for the display device got stuck in an infinite loop. This
// usually indicates a problem with the device itself or with the device
// driver programming the hardware incorrectly. Please check with your
// display device vendor for any driver updates.
ShutdownCount: 2
Shutdown: 0
EventFlag: 1
EventCount: 1
BreakCount: 1
BugcheckTriggered: 1
DebuggerNotPresent: 1
DriverName: ati2dvag
DeviceClass: Display
DeviceDescription: RADEON 7500
HardwareID: PCI\VEN_1002&DEV_5157&SUBSYS_013A1002&REV_00
Manufacturer: ATI Technologies Inc.
DriverFixedFileInfo: FEEF04BD 00010000 0006000D 000A17CE 0006000D 000A17CE 0000003F 00000008 00040004 00000003 00000004 00000000 00000000
DriverCompanyName: ATI Technologies Inc.
DriverFileDescription: ATI Radeon WindowsNT Display Driver
DriverFileVersion: 6.13.10.6094
DriverInternalName: ati2dvag.dll
DriverLegalCopyright: Copyright (C) 1998-2002 ATI Technologies Inc.
DriverOriginalFilename: ati2dvag.dll
DriverProductName: ATI Radeon Family
DriverProductVersion: 5.1.2600.0
2.
LogType: Watchdog
Created: 2002-08-04 23:56:54
WindowsVersion: XP
ShutdownCount: 107
Shutdown: 0
EventCount: 2
BreakCount: 2
EventFlag: 1
3.
LogType: Watchdog
Created: 2002-11-24 12:30:23
WindowsVersion: XP
ShutdownCount: 297
Shutdown: 0
EventCount: 3
BreakCount: 3
EventFlag: 1
DeviceDescription: 3D Prophet 8500 Series
HardwareID: PCI\VEN_1002&DEV_514C&SUBSYS_00021681&REV_00
Manufacturer: Hercules Technologies
DriverFixedFileInfo: FEEF04BD 00010000 0006000D 000A1816 0006000D 000A1816 0000003F 00000008 00040004 00000003 00000004 00000000 00000000
DriverFileVersion: 6.13.10.6166
axis
24.11.2002 21:56:13
traks kirjutas: |
axis kirjutas: |
Kui ma mälu alandasin 238 siis sain kauem mängida. Proovisin ka 230 siis veel kauem.(NfS HP2) |
aga jooksis ikka lõpuks kotti ? |
Nagu ikka!
(olen juba harjunud)
One
24.11.2002 21:58:22
tsitaat: |
nfs-is loe k6igepealt read me-d seal on kohe 6eldud, et vanemate draiveritega tuleb optionsist special efektid allapoole lasta, sest p6hjas olev uduefekt jooksutab m2ngu + masina vastasel juhul kokku ja erroriks annab mingi ati dll faili errori
Kommentaarid: 1007 loe/lisa |
727 |
traks
304 |
XeStAiSy
24.11.2002 22:08:37
tomba netist originaal catalyst 2.4 DriverVer=10/12/2002, 6.13.10.6200
ja pane inf faili kus on hunnik teisi sarnaseid asju enda kaardi inf filest jupp mis on kaardiga kaasas
"RADEON 8500/RADEON 8500LE" = ati2mtag_R200, PCI\VEN_1002&DEV_514C&SUBSYS_00021681&REV_00
seal on kaks neid
voibolla saad jurast lahti
endal pole seda jama enam
need on sull t66piliesed draiveri jamad sama oli mull ka nedega
LogType: Watchdog
Created: 2002-01-01 12:14:23
WindowsVersion: XP
ShutdownCount: 16
Shutdown: 0
EventCount: 4
BreakCount: 4
EaRecovery: 1
EventFlag: 1
DeviceDescription: RADEON 8500/RADEON 8500LE
HardwareID: PCI\VEN_1002&DEV_514C&SUBSYS_003A1002&REV_00
LogType: Watchdog
Created: 2002-01-05 19:39:04
WindowsVersion: XP
ShutdownCount: 69
Shutdown: 0
EventCount: 13
BreakCount: 13
EaRecovery: 1
EventFlag: 1
DriverFixedFileInfo: FEEF04BD 00010000 0006000D 000A1822 0006000D 000A1822 0000003F 00000008 00040004 00000003 00000004 00000000 00000000
DriverFileVersion: 6.13.10.6178
LogType: Watchdog
Created: 2002-10-28 22:44:22
WindowsVersion: XP
ShutdownCount: 151
Shutdown: 0
EventCount: 16
BreakCount: 16
EaRecovery: 1
EventFlag: 1
DeviceDescription: RADEON 8500/RADEON 8500LE (Microsoft Corporation)
HardwareID: PCI\VEN_1002&DEV_514C&SUBSYS_013A1002&REV_00
DriverFixedFileInfo: FEEF04BD 00010000 0006000D 000A1831 0006000D 000A1831 0000003F 00000008 00040004 00000003 00000004 00000000 00000000
DriverFileVersion: 6.13.10.6193
LogType: Watchdog
Created: 2002-08-08 20:56:04
WindowsVersion: XP
ShutdownCount: 86
Shutdown: 0
EventCount: 14
BreakCount: 14
EaRecovery: 1
EventFlag: 1
DeviceDescription: Radeon 8500
DriverFixedFileInfo: FEEF04BD 00010000 0006000D 000A17A4 0006000D 000A17A4 0000003F 00000008 00040004 00000003 00000004 00000000 00000000
DriverFileVersion: 6.13.10.6052
k6ige rohkem oli jama nendega DriverFileVersion: 6.13.10.6166
ja selle jama vastu aitab viaarena
viimati muutis XeStAiSy 24.11.2002 22:26:29, muudetud 2 korda |
Kommentaarid: 11 loe/lisa |
10 |
axis
24.11.2002 22:25:29
Margus kirjutas: |
seal on kaks neid
need on sull t66piliesed draiveri jamad sama oli mull ka nedega |
Sinu jutt ajas mind päris segadusse!?
Seletaksid äkki lihtsamalt(ma ei ole päris guru)
XeStAiSy
24.11.2002 22:36:04
ok
tomba netist built by ati originaal catalyst 2.4 DriverVer=10/12/2002, 6.13.10.6200
installi see ja vaata kas tunneb kaardi 6ra
kui ei siis otsid 6lesse cd mis kaardiga kaasas oli
inf file sees on midagi sellist "RADEON8500/RADEON8500LE"PCI\VEN_1002&DEV_514C&SUBSYS_000281&REV_00
ja paned sellise rea originaal draiverite inf file sisse
"RADEON8500/RADEON8500LE"PCI\VEN_1002&DEV_514C&SUBSYS_000281&REV_00 jargi v6i selle asemele
draiverid leiad c:\ati\
viimati muutis XeStAiSy 24.11.2002 22:48:58, muudetud 1 kord |
10 |
axis
24.11.2002 22:38:12
3drage foorumis tuulate leidsin ühe teema kus soovitati ühte proge mis näitab mis videokaart on installitud ja mis driverit ta kasutab.
Mul ütleb et YOUR OP IS LISTING MORE THAT ONE VIDEOCARD INSTALLED. Ja näiab et peal on radeon 7500(minu vana kaart) ja radeon 8500. Ja driveriks r6probe.
Veitsa imelik
Proge nimi on WIYP.[/url]
axis
24.11.2002 22:39:41
Mul on sellest kohast screenshot ka aga ma ei oska seda siia lisada
One
24.11.2002 22:41:27
axis kirjutas: |
Veitsa imelik
Proge nimi on WIYP.[/url] |
sa ikke v6tsid eelmise kaardi draiverid maha, v6i veelgi parem tegid format c? v6i siis v2hemalt panid windowsi uuesti p22le.... praegu paistab, et sellise teate peale v6iksid sa bill gates'ile maili saata ja temalt aru p2rida
727 |
traks
24.11.2002 22:43:11
axis kirjutas: |
Veitsa imelik
normaalne normaalne normaalne
davai ati draiveritele, ati control panelile, rage3d tweakile uninstall kohe, restart, siis mine registrisse surfima, märgusõnaks radeon ja ära kõhkle midagi selle saadana nimelist kustutamast
_________________ The greatest trick the devil ever pulled
was convincing the world glossy widescreen is the way to go. |
304 |
axis
24.11.2002 22:46:57
voltc kirjutas: |
axis kirjutas: |
Veitsa imelik
sa ikke v6tsid eelmise kaardi draiverid maha, v6i veelgi parem tegid format c? v6i siis v2hemalt panid windowsi uuesti p22le.... praegu paistab, et sellise teate peale v6iksid sa bill gates'ile maili saata ja temalt aru p2rida |
Asi oli nii et enne võtsin 7500 masinast ära siis panin 8500 sisse siis võtsin plaadi lasin sealt driverid peale, siis jooksis kokku masin . Järgmisena lasin kõik vanad driverid maha ja uued peale.
ning siis algasid kõik probleemid.
axis
24.11.2002 22:48:08
Tundub et tegin alguses kõik valesti
axis
24.11.2002 22:51:07
traks kirjutas: |
axis kirjutas: |
Veitsa imelik
davai ati draiveritele, ati control panelile, rage3d tweakile uninstall kohe, restart, siis mine registrisse surfima, märgusõnaks radeon ja ära kõhkle midagi selle saadana nimelist kustutamast |
SEDA MA OLEN TEINUD 2X.
Aga kui registrist otsin "radeon 7500" siis annab ta päris palju tulemusi. Aga ma ei taha ise kustutad kuna olen suht algaja!
XeStAiSy
10 |
traks
304 |
axis
24.11.2002 22:58:08
Margus kirjutas: |
ok
draiverid leiad c:\ati\ |
CD pealt ma küll ei leidnud .inf file
traks
304 |
XeStAiSy
24.11.2002 23:03:29
axis kirjutas: |
Margus kirjutas: |
ok
CD pealt ma küll ei leidnud .inf file |
seal on 6petus kuidas asja teha http://www.rage3d.com/board/showthread.php?s=&threadid=33617598
10 |
axis
24.11.2002 23:06:41
traks kirjutas: |
axis kirjutas: |
Aga kui registrist otsin "radeon 7500" siis annab ta päris palju tulemusi. Aga ma ei taha ise kustutad kuna olen suht algaja! |
kõige hullem, mis juhtuda saab on wini reinstall, aga ma olen 99% kindel, et sellenimeliste kirjete kustutamise tulemusena seda teha ei tule. Do It! |
Otsing leidis järgmiste Key-de alt radeon 7500, kas need key-d tuleks ära kustutada.
HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Windows/CurrentVersion/Reinstall/0000
HKEY_LOCAL_MACHINE/System/ControlSet001/Enum/PCI/VEN_1002&DEV_5157&SUBSYS_013A1002&REV_00/4&618BA55&0&0008
axis
24.11.2002 23:33:51
Olgu siis teema lõpetatud!
traks
304 |
