sõnum ![Teata moderaatorile Teata moderaatorile](./images/icon_move_w.gif) |
pots4t4j4
08.10.2015 14:15:55
Tahtsin vahelduseks peale noctua ning AIO lahenduste ka siinmail mitte nii levinud mudelit proovida
Spoiler ![Spoiler](/images/exclamation.gif)
Kommentaarid: 488 loe/lisa |
![](./images/komment/img_10_1.gif) ![](./images/komment/img_10_0.gif) ![](./images/komment/img_10_2.gif) |
396 |
![](templates/HinnaVaatlus/imagesHV/spacer.gif) |
Aeg maha 1p
![rmc rmc](https://foorum.hinnavaatlus.ee/images/avatars/upload/860205b00a059d8d469d933b9d6f6416.jpeg)
10.10.2015 17:25:43
Researchers carve channels into CPU for direct liquid cooling - http://www.pcgamer.com/researchers-have-moved-liquid-cooling-directly-onto-the-chip/
We thought CPU delidding was serious business, but researchers at the Georgia Institute of Technology have just taken CPU cooling a step further. They're looking to make big water cooling blocks a thing of the past by moving liquid cooling directly onto the chip.
By feeding 20 degree Celsius water into the tubes at a rate of 147 ml per minute, the chip operated at a temperature of less than 24 degrees Celsius, while a normal air-cooled model would operate at around 60 degree
![](https://foorum.hinnavaatlus.ee/images/200x40_HV.gif) |
Kommentaarid: 195 loe/lisa |
181 |
![londiste londiste](https://foorum.hinnavaatlus.ee/images/avatars/upload/14e8b2a8ca7fc07a1be7f79f613c69f5.gif)
10.10.2015 18:07:21
pots4t4j4, kuidas see performib?
kust tellisid? meite mail ei paista keegi väga thermalrighti maaletoomisega tegelevat.
_________________ - londiste
Kommentaarid: 238 loe/lisa |
213 |
pots4t4j4
10.10.2015 18:24:15
Pole veel kellata jõudnud jms teste teinud aga tellisin amazon.fr
Ja ma ei tea realtemp pole ka vist mingi parim asi skylake tempi jaoks paneb vist segast
396 |
213 |
Aeg maha 1p
22.12.2015 03:37:21
vahetasin korpuse ja PSU välja ning seoses sellega avastasin oma 212evo ventika rohkem häält tegevat kui tahaks... ei tea, miks "NF-S12B redux-1200 PWM" ei ole hv's leitav? arvutitark jms. kohad müüvad muidu.. mida veel soovitaksite ? push vent lihtsalt
181 |
22.12.2015 03:43:26
toide ei viitsi enam panustada õhu kastist eemaldamisse, tõstes sellega kasti sisetemperatuuri?
või lihtsalt hõredam kast?
213 |
Aeg maha 1p
23.12.2015 00:14:32
londiste, eelmisel olid summutusmatid ja sel on aken, lisaks tegi eelmine toide ka häält.. nüüd on vaikne (ja korpusevendid olid ennist mobo küljes, liikusid, kuidas tahtsid, praegu lasen kontrolleriga 5V peal korpuses olevaid vente... koormuse all CPU 62 ja GPU 72, üle selle pole näinud, suur osa ajast 52 ja 62 üldse)
praegune toide on nii ka, jah, et ava ülespoole = kui passiivis on, siis liigub õhk ülespoole, ehk GPU peale, a kui vent tööle läheb, siis puhutakse tagant välja ikka..
edit: puhub miski läbi 212EVO ribide paremini kui Noctua?
181 |
S.W.A.T.
Kommentaarid: 18 loe/lisa |
17 |
pots4t4j4
26.12.2015 17:02:53
Vaata kasti max jahutuse kõrgus järgi ja osta mõni tower sinna.
396 |
SilQ
![SilQ SilQ](https://foorum.hinnavaatlus.ee/images/avatars/upload/fd1513219964f1e66d11be9354c5c9d2.jpg)
27.12.2015 10:33:43
S.W.A.T., Kui seal Ninja3 peal on siis mahuvad kõik ära. Vali mis meeldib.
_________________ If you can’t explain it simply, you don’t understand it well enough – Albert Einstein |
205 |
Evil
Hull
![Evil Evil](https://foorum.hinnavaatlus.ee/images/avatars/upload/d1a2276cb6055f0a6d12ac4004352f0b.jpg)
29.01.2017 18:28:56
Väike jahutuste võrdlus:
Kui keegi freezer64 mäletab, siis see on see väiksem jahutus. Suurem on be quiet dark rock pro 3.
Mahub kasti küll. Kast on 2000-ndate algusest suvaline mid tower. Datagate-i kiri on ka peal veel. Originaalis tuli see kast celeron 1,2ghz, 256mb mälu ja geforce 2ti-ga.
Kui kedagi huvitab miks need nipukad, siis põhjus lihtne. Silent wings vendid ei hakanud selle dfi peal tööle. 4-pin emaplaadi 3-pin otsikutes ei teinud midagi.
Kommentaarid: 231 loe/lisa |
193 |
xheix1712
![xheix1712 xheix1712](https://foorum.hinnavaatlus.ee/images/avatars/upload/87046ff0d57f74bc1dced0d5836e04fc.jpg)
Kommentaarid: 194 loe/lisa |
174 |
softis
![softis softis](https://foorum.hinnavaatlus.ee/images/avatars/upload/a6666b4c81bb8ccfcd284c9e13874460.jpg)
29.01.2017 21:25:46
Evil kirjutas: |
Peaks üles otsima samal teemal pildi, mis ma tegin algse Silver Arrow ja 212+ võrdluseks omal ajal
Kommentaarid: 21 loe/lisa |
21 |
caramis
![caramis caramis](https://foorum.hinnavaatlus.ee/images/avatars/upload/b853fb81eaedb76d22a710d0a27bba74.jpg)
31.01.2017 00:05:44
softis kirjutas: |
Evil kirjutas: |
Peaks üles otsima samal teemal pildi, mis ma tegin algse Silver Arrow ja 212+ võrdluseks omal ajal ![icon_biggrin.gif](images/smiles/icon_biggrin.gif) |
mul oli ka kunagi SA SB-E Extreme. hilisemas confis käis ka korra uuesti läbi, jahutas 4.5GHz 2500k passiivselt ära, sest korpuses oli korralik õhuvool (Silverstone RV05). korralik jurakas on
_________________ 3D-printimine mahus kuni 350x350x400, küsi lisa! |
Kommentaarid: 155 loe/lisa |
133 |
Evil
Hull
31.01.2017 00:25:52
Mulle meeldib see radeon seal kastis palju rohkem.
193 |
caramis
31.01.2017 00:45:12
Evil kirjutas: |
Mulle meeldib see radeon seal kastis palju rohkem. ![icon_smile.gif](images/smiles/icon_smile.gif) |
ot: |
siis meeldib sulle see pilt ka kindlasti
2900XT ja HD4890
133 |
Andrez
![Andrez Andrez](https://foorum.hinnavaatlus.ee/images/avatars/upload/3b449855935c4d8bb444fda95bab76cd.jpg)
31.01.2017 22:49:39
caramis kirjutas: |
Evil kirjutas: |
ot: |
2900XT ja HD4890
Korralikud leegiheitjad
Aga teemasse. Kas nende hirmraskete jahutuste all emaplaadid ära ei paindu? Mul endal on Silverstone AR-03 kasutusel (kaal 560g + vendid, kuid see tundub täna täisesti tagasihoidlik kaal olema) ja just selle pärast kasutan korpust kus emaplaat on horisontaalselt sees.
Kommentaarid: 84 loe/lisa |
80 |
softis
31.01.2017 23:49:31
Ei paindu ta midagi. Ma pole muidugi mingi õhukese plaadiga proovinud ka (_väidatavalt_ paar põlvkonda vana asrockid nt). Tagaplaat on algselt SA'l üsna korralik.
21 |
caramis
01.02.2017 01:12:27
härrased. olen pikemalt aega otsinud õhkjahutust, mis mahub koos videokaardiga MSi Z97i Gaming AC plaadile. ventikas peab olema 120mm ja võib olla topdown. AIO ja 92mm lahendustega olen kursis
133 |
angel
![angel angel](https://foorum.hinnavaatlus.ee/images/avatars/upload/f4f068e71e0d87bf0ad51e6214ab84e9.jpg)
01.02.2017 18:36:56
caramis kirjutas: |
härrased. olen pikemalt aega otsinud õhkjahutust, mis mahub koos videokaardiga MSi Z97i Gaming AC plaadile. ventikas peab olema 120mm ja võib olla topdown. AIO ja 92mm lahendustega olen kursis |
Noctua poolt midagist? Suht asjalikuma kvaliteedi, jahutus omaduste ja vaikuse poolepealt. Kodulehel neil kenasti ka kirjas, mis jahutus millisele emaplaadile sobib.
Kommentaarid: 175 loe/lisa |
157 |
MaxEvil
![MaxEvil MaxEvil](https://foorum.hinnavaatlus.ee/images/avatars/upload/71338fbd85ba62cbefabb0eee296ca01.gif)
01.02.2017 18:59:15
angel kirjutas: |
caramis kirjutas: |
Noctua poolt midagist? Suht asjalikuma kvaliteedi, jahutus omaduste ja vaikuse poolepealt. Kodulehel neil kenasti ka kirjas, mis jahutus millisele emaplaadile sobib. |
Noctua 120mm jahutused ei sobi enamustele itx plaatidele kui tahad PCIE kasutada, nad ripuvad kõik üle ja jäävad ette väga paljudel plaatidel.
Kommentaarid: 11 loe/lisa |
Lotharius
rallisibul
![Lotharius Lotharius](https://foorum.hinnavaatlus.ee/images/avatars/upload/aa5210faeac9e374a626f979bbf9a279.gif)
24.07.2017 16:44:26
Thermalright True Spirit 140 Direct vs Power osas keegi oma mingit otsest kogemust?
Jäi ka siuke asi silma nagu Cryorig H5 Universal
Kommentaarid: 121 loe/lisa |
113 |
pots4t4j4
24.07.2017 18:10:16
Power jahutusomadustelt parem, omal oli kasutuses aasta jagu, pole ühtegi halba sõna
396 |
-FoX-
![-FoX- -FoX-](https://foorum.hinnavaatlus.ee/images/avatars/upload/053ac50833fd31030d9ccb0f2beed379.png)
30.09.2017 22:53:09
Kas kellelgi juhtub olema Kraken X52/62?
Nimelt oleks vaja teada radika paksust kuna ruum on millimeetrite mäng.
Koduleht väidab et 30mm paks, samas sõber kellel x62 on väidab, et 25mm.
Kuna meie vahemaa on umbes 400km siis ise kastiga kohale minema ei hakka
28mm pressiks veel kasti ära aga 30 enam mitte
_________________ Aita suve, söö lund! |
Kommentaarid: 364 loe/lisa |
6 :: |
305 |
