sõnum |
heix85
03.02.2023 08:34:14
Mis siin imestada, Eestis on Euroopa liidu kõrgeim inflatsioon.
_________________ Cry me a river! |
Kommentaarid: 28 loe/lisa |
28 |
Kommentaarid: 373 loe/lisa |
313 |
av.
03.02.2023 20:57:47
US beta koodi pole kellelgi üle?
Kommentaarid: 8 loe/lisa |
euforia
04.02.2023 09:22:14
Millise beta?
Kommentaarid: 29 loe/lisa |
HPN
04.02.2023 10:08:30
Eesti jaemüügis on alati 50-100€ konsoolidele otsa pandud. Nüüd lihtsalt üritatakse veelgi rasvasemat koore kihti riisuda ning pärast nutetakse meedias, kuidas välismaised (EU) veebipoed võtavad kohalikelt kaupmeestelt kliendid ära.
euforia kirjutas: |
Millise beta? |
tsitaat: |
PlayStation 5 System Software Public Beta
Main updates from this System Software Beta Program:
• You can now join Discord voice chats on your PS5.
o Link your Discord account from PS5 settings and use the Discord app on your mobile device or computer to get a Discord voice chat going on PS5. You can also let your Discord friends see when you’re online and what you’re playing.
• VRR (Variable Refresh Rate) is now supported at 1440p resolution
• Update your DualSense wireless controller device software over your wireless connection
• Easily transfer your data from your PS5 console to another PS5 over a local network or LAN cable
• More streamlined inheritance of save data from PS4 games being played on PS5
o When installing a PS4 game on PS5, the system will automatically alert you if you have PS4 save data for the game in your online storage, and ask if you would like to download it. This feature can also be used when installing a PS5 version of the game (if the developer chooses to support the PS4 game’s original save data).
- The way installed games are started has been changed:
o If your PS5 has the download version of a game that you haven’t purchased (such as those that other users on your PS5 have purchased), and if you have the disc version, you can now play the installed download version by inserting the disc (without installing the disc version).
- Similarly, if you’ve installed a game using the disc, and you’ve purchased the download version of the game, you can now play the installed disc version of the game without inserting the disc.
• Feature enhancements to Gamelists, Screen Reader, Game Hub, and more. |
_________________ /digitaalselt allkirjastatud/ |
Kommentaarid: 44 loe/lisa |
43 |
andotoomej
04.02.2023 16:15:27
av. kirjutas: |
US beta koodi pole kellelgi üle? |
EEG9-XRNF-DFCG
Kommentaarid: 13 loe/lisa |
07.02.2023 17:21:48
Kas kellegi on olnud kogemust valjaspoolt Eestit ostetud konsooli ja selle garantiiremondiga? Toimib sarnaselt, kulleriga Prantsusmaale?
Selles teemas tekkis kusimus: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11227328#11227328
_________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..." |
313 |
farik666
08.02.2023 11:28:48
Puldil hakkas stick driftima, saatsin meili support@ee.playstation.com jaanuari algul. Vastust ei ole siiamaani tulnud. Kuna oli kohalikust poest ostetud, siis viisin lõpuks sinna ja sain asja korda.
Kommentaarid: 24 loe/lisa |
22 |
08.02.2023 12:18:58
Tanud vastamast, kuid huvitaks just valismaalt ostetud konsooli garantiiprotsess voi pole seal erinevusi?
313 |
beastbeats
Kommentaarid: 360 loe/lisa |
277 |
08.02.2023 17:48:02
Tanud
313 |
JediMihkel
08.02.2023 20:54:15
Keegi PSVR 2 Müüb juba/eelmüüb?
Kommentaarid: 42 loe/lisa |
38 |
Elpex
08.02.2023 20:59:04
JediMihkel kirjutas: |
Keegi PSVR 2 Müüb juba/eelmüüb? |
Euronics.
Kommentaarid: 117 loe/lisa |
109 |
JediMihkel
08.02.2023 23:37:36
Kas nad hiljuti panid müüki uuesti?
Nad olid selle ära kaotanud seal vahepeal ja alles paar päeva tagasi ei suutnud leida.
38 |
heix85
28 |
JediMihkel
09.02.2023 01:13:47
Ja ongi tagasi ilmunud, vägev! Aitäh!
38 |
Vahur
21.02.2023 11:24:42
Sony Centeri (Miterassa) PS5 ootejärjekord jõudis minuni, aga ise enam ei taha. Küsitakse €599,99 ning soovikorral kulleri või Smartposti eest €7. Kellel huvi saatku PS.
Kommentaarid: 456 loe/lisa |
386 |
Albert4584
21.02.2023 17:48:49
Heh, hakkab pihta...
Euronicsist PSVR2 prillid eelteelitud. Raha makstud, ilusti kenasti kirjas, mis vahemikus pakiautomaati saabub... Ja siis tuleb üks ilus kiri posti: "Tarnija on süüdi, meie ei tea midagi, tõenäoliselt kunagi ikka tuleb, aga unustage ära see kuupäev, millal lubasime kauba kohale toimetada."
No mida pekki sa siis üldse paned sinna e-poodi müüki, kui sul ei ole asi kindel? Masendav.
Ma ainult selle pärast tegingi Euronicsiga kunagi diili, et neil lubatud kuupäevad kirjas... Oleks otsinud mujalt.
Kommentaarid: 2 loe/lisa |
beastbeats
277 |
Albert4584
21.02.2023 18:06:55
sorri, väga vabandan... küllap vist ja aitüma tevitamast! Ma ei tulnud selle peale esimese hooga... järgmine kord targem.
Samas - eks see ole seotud ka PS5ga mingil määral. Usutavasti või pigem loodetavasti (ikka ju hea meel kui kellelgi teisel läheb ka essusti) ma ei ole ainus.
Fixed
21.02.2023 19:37:28
Albert4584 kirjutas: |
Samas - eks see ole seotud ka PS5ga mingil määral. Usutavasti või pigem loodetavasti (ikka ju hea meel kui kellelgi teisel läheb ka essusti) ma ei ole ainus. |
Ei ole sa ainus. Tegin samuti psvr2 eeltellimuse Euronicsist ja täpselt sama kiri, et lubatud ajaks ma kaupa ei saa. Lubati heal juhul uue nädala alguseks aga ise ei usu, et siiski saab.
Kommentaarid: 36 loe/lisa |
34 |
heretic666
22.02.2023 18:43:21
Ma ainult selle pärast tegingi Euronicsiga kunagi diili, et neil lubatud kuupäevad kirjas... Oleks otsinud mujalt. |
Vahest tarnija ise andis kindla kuupäeva ja nüüd hüpati alt? Ei pruugi pood ka süüdi olla
Väikeriigi võlu ja valu
Kommentaarid: 70 loe/lisa |
68 |
Dj-E
22.02.2023 19:11:36
See on ju tüüpiline Euronics. Siit ka enne läbi käinud teemad, et ei tasu sealt kunagi midagi pre-orderdada, sest nagunii ei saabu asi lubatud ajaks.
Kommentaarid: 22 loe/lisa |
21 |
tann84
22.02.2023 20:12:22
Igatahes Miterassa on oma lubaduse täitnud. Tõin just oma kaua oodatud VR2 komplekti koju.
Ja esimeseks kogemuseks valisin RE: Village’i. Saab taaskord Lady Dimitrescu‘st külastada, seekord siis VR mode’is
_________________ PSN: karl877 |
Kommentaarid: 45 loe/lisa |
keimps1
22.02.2023 21:16:21
tann84 kirjutas: |
Ja esimeseks kogemuseks valisin RE: Village’i. Saab taaskord Lady Dimitrescu‘st külastada, seekord siis VR mode’is |
Äge, kuulan huviga muljeid, kel käes. Mõttes ka endal mingi aeg aga kas õigustab end
Kommentaarid: 137 loe/lisa |
124 |
